I know there is a need to put a pullup resistor on the Dallas one wire temp sensor. My questions is where do I put it on a long cable run, near the temp sensor or near the Arduino? Does it matter?
Also, any other suggestions or ideas for placing a temperature sensor about 75 ft. from the Arduino is appreciated.
Adjust the value of the pullup resistor to create a stronger pullup. IE; if you are using 4.7K with a short, I would change it to 2.7K with a longer cable.
Are you using it with or without dedicated power ? The data sheet kind of implies 25 metres with a 5v supply (ie not phantom power) and cat5 twisted pair cabling without couplers is OK.
Personally, I’d suck it and see with the pull up resistor at the arduino end.
