DS18B20 / OneWire not detected on Arduino UNO Q — Zephyr timing / GPIO / RPC issue?
It is a machine --- please be kind to it. Machines can go wrong, and that is not their fault. They do not deserve to be thrown into the trash; rather, they have the right to be repaired and to serve human beings once again.
Beautiful board, a shame to throw it away, let's wait for better times.
-127 is a connection problem.
Please check the wires - soldering is preferred -
If this not works I have no Qlue
@andrisbs may use this little board with DS18B20 sensor.
There is no physical fault. With other boards DS18B20 always works fine.
I have a boiler automation system created with Arduino NANO and 3 x DS18B20 which has been working perfectly for 10 years.
I see so much problems with the Q mentioned here that I would not convert any of my projects to a Q. The platform is not mature (or whatever you call it) yet. I see definitely progress and people behind the scenes are working hard but the Q is just not there yet.
That system would probably work for another 5 or maybe 10 years.
Good luck to the Q developers!
If people like @robtillaart get engaged, the UNO Q will take a good shape soon!
I agree with 100% on this. Right now its kind of in Beta devel and I am just trying things to test what works and what doesn't. Since alot of the zephyr devel affects most of arduino boards I am also seeing different errors on different boards not just the Q.
You're doing a great job, definitely appreciated, otherwise all these issues will pop up later when everyone starts to use the Q. And yes many boards have their oddities.
After the latest updates, the DS18B20 is recognized, shows the correct temperature. Also, the Monitor prints correctly. Thanks to the Q developers, keep it up!
What update are you referring to?
I'm not sure what update might have fixed the DS18B20 problem.
The Monitor print order bug is fixed by updating the arduino-router tool to version 0.7.0:
Can you provide a working sketch? I attempted to used "post #173" and am getting "DS18B20: -0.06 C"
To make the sketch of #173 working, you need to replace the zephyrCommon.cpp file with the following one: This is the path:
C:\Users\GolamMostafa\AppData\Local\Arduino15\packages\arduino\hardware\zephyr\0.52.0\cores\arduino
 * Copyright (c) 2022 Dhruva Gole
 * SPDX-License-Identifier: Apache-2.0
#include <Arduino.h>
#include "zephyrInternal.h"
static const struct gpio_dt_spec arduino_pins[] = {
	DT_FOREACH_PROP_ELEM_SEP(
	DT_PATH(zephyr_user), digital_pin_gpios, GPIO_DT_SPEC_GET_BY_IDX, (, ))};
namespace {
#if DT_PROP_LEN(DT_PATH(zephyr_user), digital_pin_gpios) > 0
 * Calculate GPIO ports/pins number statically from devicetree configuration
template <class N, class Head> constexpr N sum_of_list(const N sum, const Head &head) {
	return sum + head;
template <class N, class Head, class... Tail>
constexpr N sum_of_list(const N sum, const Head &head, const Tail &...tail) {
	return sum_of_list(sum + head, tail...);
template <class N, class Head> constexpr N max_in_list(const N max, const Head &head) {
	return (max >= head) ? max : head;
constexpr N max_in_list(const N max, const Head &head, const Tail &...tail) {
	return max_in_list((max >= head) ? max : head, tail...);
template <class Query, class Head>
constexpr size_t is_first_appearance(const size_t &idx, const size_t &at, const size_t &found,
									 const Query &query, const Head &head) {
	return ((found == ((size_t)-1)) && (query == head) && (idx == at)) ? 1 : 0;
template <class Query, class Head, class... Tail>
									 const Query &query, const Head &head, const Tail &...tail) {
			   1 :
			   is_first_appearance(idx + 1, at, (query == head ? idx : found), query, tail...);
#define GET_DEVICE_VARGS(n, p, i, _) DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(n, p, i))
#define FIRST_APPEARANCE(n, p, i)        \
	is_first_appearance(0, i, ((size_t)-1), DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(n, p, i)),           \
						DT_FOREACH_PROP_ELEM_SEP_VARGS(n, p, GET_DEVICE_VARGS, (, ), 0))
const int port_num = sum_of_list(
	0, DT_FOREACH_PROP_ELEM_SEP(DT_PATH(zephyr_user), digital_pin_gpios,
            FIRST_APPEARANCE, (, )));
#define GPIO_NGPIOS(n, p, i) DT_PROP(DT_GPIO_CTLR_BY_IDX(n, p, i), ngpios)
const int max_ngpios = max_in_list(
	0, DT_FOREACH_PROP_ELEM_SEP(DT_PATH(zephyr_user), digital_pin_gpios, GPIO_NGPIOS, (, )));
#else
const int port_num = 1;
const int max_ngpios = 0;
#endif
 * GPIO callback implementation
struct arduino_callback {
	voidFuncPtr handler;
	bool enabled;
struct gpio_port_callback {
	struct gpio_callback callback;
	struct arduino_callback handlers[max_ngpios];
	gpio_port_pins_t pins;
	const struct device *dev;
} port_callback[port_num] = {0};
struct gpio_port_callback *find_gpio_port_callback(const struct device *dev) {
	for (size_t i = 0; i < ARRAY_SIZE(port_callback); i++) {
		if (port_callback[i].dev == dev) {
			return &port_callback[i];
		if (port_callback[i].dev == nullptr) {
			port_callback[i].dev = dev;
	return nullptr;
void setInterruptHandler(pin_size_t pinNumber, voidFuncPtr func) {
	struct gpio_port_callback *pcb = find_gpio_port_callback(arduino_pins[pinNumber].port);
	if (pcb) {
		pcb->handlers[arduino_pins[pinNumber].pin].handler = func;
void handleGpioCallback(const struct device *port, struct gpio_callback *cb, uint32_t pins) {
	(void)port; // unused
	struct gpio_port_callback *pcb = (struct gpio_port_callback *)cb;
	for (uint32_t i = 0; i < max_ngpios; i++) {
		if (pins & BIT(i) && pcb->handlers[i].enabled) {
			pcb->handlers[i].handler();
#ifdef CONFIG_PWM
#define PWM_DT_SPEC(n, p, i) PWM_DT_SPEC_GET_BY_IDX(n, i),
#define PWM_PINS(n, p, i)        \
	DIGITAL_PIN_GPIOS_FIND_PIN(DT_REG_ADDR(DT_PHANDLE_BY_IDX(DT_PATH(zephyr_user), p, i)),         \
							   DT_PHA_BY_IDX(DT_PATH(zephyr_user), p, i, pin)),
const struct pwm_dt_spec arduino_pwm[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), pwms, PWM_DT_SPEC)};
/* pwm-pins node provides a mapping digital pin numbers to pwm channels */
const pin_size_t arduino_pwm_pins[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), pwm_pin_gpios, PWM_PINS)};
size_t pwm_pin_index(pin_size_t pinNumber) {
	for (size_t i = 0; i < ARRAY_SIZE(arduino_pwm_pins); i++) {
		if (arduino_pwm_pins[i] == pinNumber) {
			return i;
	return (size_t)-1;
#endif // CONFIG_PWM
#ifdef CONFIG_ADC
#define ADC_DT_SPEC(n, p, i) ADC_DT_SPEC_GET_BY_IDX(n, i),
#define ADC_PINS(n, p, i)        \
#define ADC_CH_CFG(n, p, i) arduino_adc[i].channel_cfg,
static const struct adc_dt_spec arduino_adc[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), io_channels, ADC_DT_SPEC)};
/* io-channel-pins node provides a mapping digital pin numbers to adc channels */
const pin_size_t arduino_analog_pins[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), adc_pin_gpios, ADC_PINS)};
struct adc_channel_cfg channel_cfg[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), io_channels, ADC_CH_CFG)};
size_t analog_pin_index(pin_size_t pinNumber) {
	for (size_t i = 0; i < ARRAY_SIZE(arduino_analog_pins); i++) {
		if (arduino_analog_pins[i] == pinNumber) {
			return i;
	return (size_t)-1;
#endif // CONFIG_ADC
#ifdef CONFIG_DAC
#if (DT_NODE_HAS_PROP(DT_PATH(zephyr_user), dac))
#define DAC_NODE       DT_PHANDLE(DT_PATH(zephyr_user), dac)
#define DAC_RESOLUTION DT_PROP(DT_PATH(zephyr_user), dac_resolution)
static const struct device *const dac_dev = DEVICE_DT_GET(DAC_NODE);
#define DAC_CHANNEL_DEFINE(n, p, i)        \
		.channel_id = DT_PROP_BY_IDX(n, p, i),                                                     \
		.resolution = DAC_RESOLUTION,                                                              \
		.buffered = true,        \
static const struct dac_channel_cfg dac_ch_cfg[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), dac_channels, DAC_CHANNEL_DEFINE)};
#endif
#endif // CONFIG_DAC
static unsigned int irq_key;
static bool interrupts_disabled = false;
} // namespace
void yield(void) {
	k_yield();
 *  The ACTIVE_HIGH flag is set so that A low physical
 *  level on the pin will be interpreted as value 0.
 *  A high physical level will be interpreted as value 1
void pinMode(pin_size_t pinNumber, PinMode pinMode) {
	if (pinMode == INPUT) { // input mode
		gpio_pin_configure_dt(&arduino_pins[pinNumber], GPIO_INPUT | GPIO_ACTIVE_HIGH);
	} else if (pinMode == INPUT_PULLUP) { // input with internal pull-up
							  GPIO_INPUT | GPIO_PULL_UP | GPIO_ACTIVE_HIGH);
	} else if (pinMode == INPUT_PULLDOWN) { // input with internal pull-down
							  GPIO_INPUT | GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH);
	} else if (pinMode == OUTPUT) { // output mode
		gpio_pin_configure_dt(&arduino_pins[pinNumber], GPIO_OUTPUT_LOW | GPIO_ACTIVE_HIGH);
void digitalWrite(pin_size_t pinNumber, PinStatus status) {
	gpio_pin_set_dt(&arduino_pins[pinNumber], status);
PinStatus digitalRead(pin_size_t pinNumber) {
	return (gpio_pin_get_dt(&arduino_pins[pinNumber]) == 1) ? HIGH : LOW;
struct k_timer arduino_pin_timers[ARRAY_SIZE(arduino_pins)];
struct k_timer arduino_pin_timers_timeout[ARRAY_SIZE(arduino_pins)];
void tone_expiry_cb(struct k_timer *timer) {
	const struct gpio_dt_spec *spec = (gpio_dt_spec *)k_timer_user_data_get(timer);
	gpio_pin_toggle_dt(spec);
void tone_timeout_cb(struct k_timer *timer) {
	pin_size_t pinNumber = (pin_size_t)(uintptr_t)k_timer_user_data_get(timer);
	noTone(pinNumber);
void tone(pin_size_t pinNumber, unsigned int frequency, unsigned long duration) {
	struct k_timer *timer = &arduino_pin_timers[pinNumber];
	const struct gpio_dt_spec *spec = &arduino_pins[pinNumber];
	k_timeout_t timeout;
	pinMode(pinNumber, OUTPUT);
	if (frequency == 0) {
		gpio_pin_set_dt(spec, 0);
		return;
	timeout = K_NSEC(NSEC_PER_SEC / (2 * frequency));
	k_timer_init(timer, tone_expiry_cb, NULL);
	k_timer_user_data_set(timer, (void *)spec);
	gpio_pin_set_dt(spec, 1);
	k_timer_start(timer, timeout, timeout);
	if (duration > 0) {
		timer = &arduino_pin_timers_timeout[pinNumber];
		k_timer_init(timer, tone_timeout_cb, NULL);
		k_timer_user_data_set(timer, (void *)(uintptr_t)pinNumber);
		k_timer_start(timer, K_MSEC(duration), K_NO_WAIT);
void noTone(pin_size_t pinNumber) {
	k_timer_stop(&arduino_pin_timers[pinNumber]);
	gpio_pin_set_dt(&arduino_pins[pinNumber], 0);
void delay(unsigned long ms) {
	k_sleep(K_MSEC(ms));
//------ original codes----
void delayMicroseconds(unsigned int us) {
	k_sleep(K_USEC(us));
//----- end of original codess-------
//----- codes proposed by @robtillarat----
  //  ignore small values
  if (us <= 1) return;
  //  optional adjust loop here
  // start the clock
  uint32_t start = micros();
  while (micros() - start < us)
    //  empty loop
  return;
//----- end of codes of @robtillart
//----- by Q----
  //  skip small values
  //  0 and 1 will return 2 us due to function call overhead
  //  for the value 2 this overhead is "perfect"
  //           => should be documented
  if (us <= 2) return;
  //  small values can be done with NOP's
  if (us < 7)
    //uint16_t nops = us * 12;   //  might need to adjustment
    uint16_t nops = (us * 18)-3;   //  might need to adjustment
    while (nops--) asm("NOP");
    return;
  if (us < 19)
    uint16_t nops = (us * 23)-13;   //  might need to adjustment
    return;
  if (us < 31)
    uint16_t nops = (us * 25)-7;   //  might need to adjustment
    return;
  if (us < 51)
    uint16_t nops = (us * 26)-20; //  might need to adjustment
    return;
  if (us < 57)
    uint16_t nops = (us * 26)-2; //  might need to adjustment
    return;
  if (us < 81)
    uint16_t nops = (us * 26)+2; //  might need to adjustment
    return;
  if (us < 100)
    uint16_t nops = (us * 27); //  might need to adjustment
    return;
    if (us < 121)
    uint16_t nops = (us * 26); //  might need to adjustment
    return;
  // remember the start of the requested delay
  //  if the delay is longer than the "problem overhead of 100 us"
  //  go to sleep for less long, so we wake up too early
  //  thereby optimizing the support for RTOS scheduling
  if (us > 300) k_sleep(K_USEC(us - 300));
  //  tune the algorithm to be "near perfect"
  //us = us - 5;
  us = us - 4;
  //  empty loop last 300 us until the delay is done
  while (micros() - start < us);
  return;
//----- end of Q
//----- new codes of @robtillarat-------
  //  skip zero milliseconds immediately.
  if (ms == 0) return;
  //  correct k_sleep parameter for "small" values of ms
  if (ms < 1000)
    //  convert milliseconds to microseconds
    uint32_t us = ms * 1000;
    //  adjust for the overhead error
    const uint16_t CORRECTION_K_SLEEP = 100;
    us = us - CORRECTION_K_SLEEP;
    return;
  //  above the 1000 millis the "100 us overhead error" is small
  //  relative error <= 0.01% so just leave it
//--- end of new codes of @robtillarat
unsigned long micros(void) {
#ifdef CONFIG_TIMER_HAS_64BIT_CYCLE_COUNTER
	return k_cyc_to_us_floor32(k_cycle_get_64());
#else
	return k_cyc_to_us_floor32(k_cycle_get_32());
#endif
unsigned long millis(void) {
	return k_uptime_get_32();
#if defined(CONFIG_DAC) || defined(CONFIG_PWM)
static int _analog_write_resolution = 8;
void analogWriteResolution(int bits) {
	_analog_write_resolution = bits;
int analogWriteResolution() {
	return _analog_write_resolution;
#endif
#ifdef CONFIG_PWM
void analogWrite(pin_size_t pinNumber, int value) {
	size_t idx = pwm_pin_index(pinNumber);
	if (idx >= ARRAY_SIZE(arduino_pwm)) {
		return;
	if (!pwm_is_ready_dt(&arduino_pwm[idx])) {
		return;
	value = map(value, 0, 1 << _analog_write_resolution, 0, arduino_pwm[idx].period);
	if (((uint32_t)value) > arduino_pwm[idx].period) {
		value = arduino_pwm[idx].period;
	} else if (value < 0) {
		value = 0;
	 * A duty ratio determines by the period value defined in dts
	 * and the value arguments. So usually the period value sets as 255.
	(void)pwm_set_pulse_dt(&arduino_pwm[idx], value);
#endif
#ifdef CONFIG_DAC
void analogWrite(enum dacPins dacName, int value) {
	if (dacName >= NUM_OF_DACS) {
		return;
	dac_channel_setup(dac_dev, &dac_ch_cfg[dacName]);
	const int max_dac_value = 1U << dac_ch_cfg[dacName].resolution;
	dac_write_value(dac_dev, dac_ch_cfg[dacName].channel_id,
					map(value, 0, 1 << _analog_write_resolution, 0, max_dac_value));
#endif
#ifdef CONFIG_ADC
void __attribute__((weak)) analogReference(uint8_t mode) {
	 * The Arduino API not clearly defined what means of
	 * the mode argument of analogReference().
	 * Treat the value as equivalent to zephyr's adc_reference.
	for (size_t i = 0; i < ARRAY_SIZE(channel_cfg); i++) {
		channel_cfg[i].reference = static_cast<adc_reference>(mode);
// Note: We can not update the arduino_adc structure as it is read only...
static int read_resolution = 10;
void analogReadResolution(int bits) {
	read_resolution = bits;
int analogReadResolution() {
	return read_resolution;
int analogRead(pin_size_t pinNumber) {
	int err;
	uint16_t buf;
	struct adc_sequence seq = {.buffer = &buf, .buffer_size = sizeof(buf)};
	size_t idx = analog_pin_index(pinNumber);
	if (idx >= ARRAY_SIZE(arduino_adc)) {
		return -EINVAL;
	 * ADC that is on MCU supported by Zephyr exists
	 * only 16bit resolution, currently.
	if (arduino_adc[idx].resolution > 16) {
		return -ENOTSUP;
	err = adc_channel_setup(arduino_adc[idx].dev, &arduino_adc[idx].channel_cfg);
	if (err < 0) {
		return err;
	seq.channels = BIT(arduino_adc[idx].channel_id);
	seq.resolution = arduino_adc[idx].resolution;
	seq.oversampling = arduino_adc[idx].oversampling;
	err = adc_read(arduino_adc[idx].dev, &seq);
	if (err < 0) {
		return err;
	 * If necessary map the return value to the
	 * number of bits the user has asked for
	if (read_resolution == seq.resolution) {
		return buf;
	if (read_resolution < seq.resolution) {
		return buf >> (seq.resolution - read_resolution);
	return buf << (read_resolution - seq.resolution);
#endif
void attachInterrupt(pin_size_t pinNumber, voidFuncPtr callback, PinStatus pinStatus) {
	struct gpio_port_callback *pcb;
	gpio_flags_t intmode = 0;
	if (!callback) {
		return;
	if (pinStatus == LOW) {
		intmode |= GPIO_INT_LEVEL_LOW;
	} else if (pinStatus == HIGH) {
		intmode |= GPIO_INT_LEVEL_HIGH;
	} else if (pinStatus == CHANGE) {
		intmode |= GPIO_INT_EDGE_BOTH;
	} else if (pinStatus == FALLING) {
		intmode |= GPIO_INT_EDGE_FALLING;
	} else if (pinStatus == RISING) {
		intmode |= GPIO_INT_EDGE_RISING;
		return;
	__ASSERT(pcb != nullptr, "gpio_port_callback not found");
	pcb->pins |= BIT(arduino_pins[pinNumber].pin);
	setInterruptHandler(pinNumber, callback);
	enableInterrupt(pinNumber);
	gpio_pin_interrupt_configure(arduino_pins[pinNumber].port, arduino_pins[pinNumber].pin,
								 intmode);
	gpio_init_callback(&pcb->callback, handleGpioCallback, pcb->pins);
	gpio_add_callback(arduino_pins[pinNumber].port, &pcb->callback);
void detachInterrupt(pin_size_t pinNumber) {
	setInterruptHandler(pinNumber, nullptr);
	disableInterrupt(pinNumber);
#ifndef CONFIG_MINIMAL_LIBC_RAND
#include <stdlib.h>
void randomSeed(unsigned long seed) {
	srand(seed);
long random(long min, long max) {
	return rand() % (max - min) + min;
long random(long max) {
	return rand() % max;
#endif
#ifdef CONFIG_GPIO_GET_DIRECTION
unsigned long pulseIn(pin_size_t pinNumber, uint8_t state, unsigned long timeout) {
	struct k_timer timer;
	int64_t start, end, delta = 0;
	k_timer_init(&timer, NULL, NULL);
	k_timer_start(&timer, K_MSEC(timeout), K_NO_WAIT);
	if (!gpio_is_ready_dt(spec)) {
		goto cleanup;
	if (!gpio_pin_is_input_dt(spec)) {
		goto cleanup;
	while (gpio_pin_get_dt(spec) == state && k_timer_status_get(&timer) == 0)
	if (k_timer_status_get(&timer) > 0) {
		goto cleanup;
	while (gpio_pin_get_dt(spec) != state && k_timer_status_get(&timer) == 0)
		goto cleanup;
	start = k_uptime_ticks();
		goto cleanup;
	end = k_uptime_ticks();
	delta = k_ticks_to_us_floor64(end - start);
cleanup:
	k_timer_stop(&timer);
	return (unsigned long)delta;
#endif // CONFIG_GPIO_GET_DIRECTION
void enableInterrupt(pin_size_t pinNumber) {
	if (pcb) {
		pcb->handlers[arduino_pins[pinNumber].pin].enabled = true;
void disableInterrupt(pin_size_t pinNumber) {
	if (pcb) {
		pcb->handlers[arduino_pins[pinNumber].pin].enabled = false;
void interrupts(void) {
	if (interrupts_disabled) {
		irq_unlock(irq_key);
void noInterrupts(void) {
	if (!interrupts_disabled) {
		irq_key = irq_lock();
		interrupts_disabled = true;
int digitalPinToInterrupt(pin_size_t pin) {
	struct gpio_port_callback *pcb = find_gpio_port_callback(arduino_pins[pin].port);
	return (pcb) ? pin : -1;
I have several sketches working with AppLab. The simplest one:
#include "Arduino_RouterBridge.h"
#include "MsgPack.h"
#include <OneWire.h>
#include <DallasTemperature.h>
// ===== DS18B20 =====
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
  sensors.begin();
  Monitor.begin();
  // ===== Temperatūras sūtīšana =====
      sensors.requestTemperatures();
      float tempC = sensors.getTempCByIndex(0);
      Monitor.println(tempC, 1);  //  1 decimal
The suggested changes to the #155 zephyrCommon.cpp file have been saved.
Interestingly, after AppLab Updates, I can't open a second AppLab window on a Windows computer.
About the Monitor print order bug.
I had earlier scrambled text when printing using Monitor. For example in thread
: https://forum.arduino.cc/t/ds18b20-works-in-loop-but-fails-as-an-independent-thread-in-uno-q post #4
I uploaded the latest updates to my UNO Q and thought that the order bug is over.
I opened Arduino App Lab -0.50 board shell and issued command "apt list". It lists many arduino files and it prints that arduino-router 0,7,0 is installed.
arduino-router/stable,now 0.7.0 arm64 [installed]
I tried @andrisbs latest code # 197 and monitor printed to App Labs Serial Monitor and Arduino IDE 2.3.8 Serial Monitor:
Printing is as scrambled as before.
I there something I should know and do to print unscrambled text?
It's hard for me to comment on updates, I'm not a big computer expert. When I turned on my UNO Q on 28.02. I simply performed all the updates that were automatically offered. I was pleasantly surprised that AppLab Monitor and DS18B20 worked properly.
Thank you for your reply and code.
I reply to my self about the Monitor print order bug.
Copy of Home Climate Monitoring in App Lab.
Original sketch and added Monitor.begin(); to setup() and to the end of the loop() Monitor.print() commands. .
  unsigned long currentMillis = millis(); // Get the current time
  if (currentMillis - previousMillis >= interval) {
    // Save the last time you updated the values
    // Read temperature in Celsius from the sensor
    float celsius = thermo.getTemperature();
    // Read humidity percentage from the sensor
    float humidity = thermo.getHumidity();
    Bridge.notify("record_sensor_samples", celsius, humidity);
    Monitor.print("Temperature : ");Monitor.println(celsius);
    Monitor.print("Humidity    : ");Monitor.println(humidity);Monitor.println();
Run in App Lab and nine lines prints fine to App Labs Console Serial Monitor:
In the middle of the image I uploaded the same code from Arduino IDE 2.3.8.
Printing stopped a little moment and after uploading the printing began again but scrambled.
My Arduino_RouterBridge library version is 0.3.0 Dec 15, 2025. Maybe it should be updated too.
Actually this is not a problem with Modulino shieds and programs but I try to use DS18B20 as temperature sensor witch didn't work in App Lab.
In Arduino IDE i can hack delayMicroseconds() in zephyrCommon.cpp to work with OneWire library and upload the working .ino sketch to microcontroller.
I hope that a new release of Arduino Zephyr will be released soon.
