DS18B20 SDcard Data Logger with RTC
Hay fellas,
I´ve a problem with my code.
i´m trying to read and to log the temperature datas from the DS18B20.
The serial print isnt the problem, but when i try to log the temperature the serial print says that it isn´t possible to open the txt-file.
When i´m logging the temperature from the DS3231 everything is fine. It doesnt work with the DS18B20.
Is there someone who could help me?
Thanks
//========Set the time for the RealTimeClock (RTC) with Set_RTC_Time.ino first==========
//For the RTC and the SD-Card-Connector
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
//For the DS18B20
#include <OneWire.h>
#include <DallasTemperature.h>
File myFile;
DS3231  rtc(SDA, SCL);
int pinCS = 53; // Pin 10 on Arduino Uno
//=====DS18B20======
// Data wire from the DS18B20 is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a OneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass OneWire reference to Dallas Temperature
DallasTemperature sensors(&oneWire);
  pinMode(pinCS, OUTPUT);
  // SD Card Initialization
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  rtc.begin();
  //=======DS18B20=======
  pinMode(ONE_WIRE_BUS, OUTPUT);
  sensors.begin(); //Start up the library
  Serial.print(rtc.getDateStr());
  Serial.print(",");
  Serial.print(rtc.getTimeStr());
  Serial.print(",");
  //======DS18B20=========
  sensors.requestTemperatures(); //Call sensor to request the Temperature
  Serial.println(String(sensors.getTempCByIndex(0)) + "°C"); //Output the values on the monitor
  myFile = SD.open("test_ds13b20.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(rtc.getDateStr());
    myFile.print(",");
    myFile.print(rtc.getTimeStr());
    myFile.print(",");
    myFile.println(String(sensors.getTempCByIndex(0)) + "°C"); //Save the values on the SD-Card
    myFile.close(); // close the file
  // if the file didn't open, print an error:
  else {
    Serial.println("error opening txt-file");
  delay(3000);  //Wait for 3 sec
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
//For the DS18B20
File myFile;
  if (SD.begin())      Serial.println("SD card is ready to use.");
  else    Serial.println("SD card initialization failed");
  rtc.begin();
  Serial.print(",");
  Serial.print(",");
String DalasTemp=String(sensors.getTempCByIndex(0)) + "°C";
  Serial.println(DalasTemp); //Output the values on the monitor
  if (myFile) {
    myFile.print(",");
    myFile.print(",");
    myFile.println(DalasTemp); //Save the values on the SD-Card
  else {
Im sorry, it´s still not working
Provide the link to the libraries you are using, as it is giving a compilation error when I use my libraries.
your SD don't work, at all, not even for DS3231, bc
must be:
SD.begin(pinCS)
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
//For the DS18B20
  if (SD.begin(pinCS))      Serial.println("SD card is ready to use.");
  rtc.begin();
  char Log[40];
  sprintf(Log, "%s,%s,%.01f°C", rtc.getDateStr(), rtc.getTimeStr(), sensors.getTempCByIndex(0));
  Serial.println(Log); //Output the values on the monitor
  File myFile = SD.open("test_ds13b20.txt", FILE_WRITE);
  if (myFile) {
    myFile.println(Log); //Save the values on the SD-Card
  else {
Yea but in this code without the DS18B20 its working and i dont why ... :frowning:
//Set the time for the RealTimeClock (RTC) with Set_RTC_Time.ino first
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
File myFile;
  if (SD.begin())
  } else
    return;
  rtc.begin();
  Serial.print(",");
  Serial.print(",");
  Serial.println(int(rtc.getTemp()));
  myFile = SD.open("test_01.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(",");
    myFile.print(",");
    myFile.println(int(rtc.getTemp()));
  else {
    Serial.println("error opening test.txt");
  delay(3000);  //Wait for 3 seconds
did you open the file on SD ? what contai it?
The file is empty
The file name for SD can only be up to 8 digits long.
Ou, yes thats the solution thank you so much :slight_smile:
Do you know how i can send the Arduino to sleep between the sampling (when i increase the time between two samples)?
See the simulated project here.
I added a routine to read and print data recorded on SD cards (readSD()).
#include <SD.h>
#include <SPI.h>
#include "DS3231.h"
//For the DS18B20
File myFile;
  if (SD.begin())  {    // SD Card Initialization
  else  {
    return;
  rtc.begin();
  Serial.print(",");
  Serial.print(",");
  myFile = SD.open("test_ds.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(",");
    myFile.print(",");
  else {
  readSD();
void readSD() {
  myFile = SD.open("test_ds.txt", O_READ);    //If no exist, create file
  if (myFile) {
    Serial.println("test_ds.txt listing");
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  else {
    Serial.println("error opening test_ds.txt");
