You have worked a lot to put your experiences; whereas, I have made a tiny contribution putting them in bullet form.
AI did this version in 10 milliseconds.
Setting up a workspace for electronics requires the right tools and techniques to avoid the "grief" of fragile connections and short circuits. Here is a summary of the best practices for handling wiring, specifically for sensors like the DS18B20.
1. Wire Preparation Basics
To connect a sensor, you must strip roughly 10mm of the insulating sheath to expose the conductors. However, the method you choose matters:
- Avoid using teeth or knives: These methods often score or damage the delicate metal strands, making them prone to snapping.
- Use Wire Strippers: Automatic strippers are ideal. A "pro tip" is to cut the insulation and pull it back slightly without removing it entirely—using the loose bit of plastic to twist the internal strands together.
2. Handling Different Wire Types
The way you treat a wire depends on its internal structure:
- Solid Core: Stiff enough to be pushed directly into a breadboard.
- Stranded Wire: Very flexible and fragile. These must be twisted to prevent stray strands from causing short circuits.
3. Secure Terminations
For a reliable connection, you shouldn't leave bare stranded wire loose. Use these methods instead:
- Crimping: The gold standard for finished projects; it provides a professional, secure mechanical bond.
- Soldering: A solder pot is efficient if you have a high volume of wires to "tin" (coat in solder).
- Wago Connectors: Excellent for temporary or reusable connections. These "cage clamp" terminals are secure, certified, and prevent shorts.
4. Pro-Tips for Connections
- The "Point" Method: When using breadboards or female headers, cut the tip of the wire at an angle. This creates a point that makes it much easier to slide into the connector.
- Consistency: Taking the time to do these basics correctly prevents the frustration of intermittent signals or broken hardware later on.
AI will make us all redundant.
Rest assured that none of my contributions are generated from AI.
That's nice however it did not address the OP problem.
Unfortunately, the AI has not addressed the issue of human safety, particularly the fact that improper use of tools can lead to serious injury to the user.
Good suggestions and nice formatting. AI is pretty handy for formatting.
Probably, but it takes a human to make a proper mess like that.
for now i am just trying to test every sensor with the project and see how the connectivity works and all... later i will put them properly. thanks.
I see strands sticking out but for a simple quick test it looks OK. While I have no clue what your project is about if it is anything involving safety I would not be using anything other than true and not Chinese off the boat counterfeit parts.
Just My Take
Ron
It might work but its not good.
- The wire is exposed and could touch other exposed wires and cause a short-circuit
- It could easily pull apart
Suggest you read the suggestion from @jim-p again.
Don't scare me now, how do i even know what is chinese or not??
i have to use parts available near my campus because shipping takes like a week. But thanks, i will keep that in mind... and i will tape it soon just wanted to ask if it looks correct before insulating. And my project doesn't evolve with something dangerous mostly i will use it to collect various data from seas and all.
yes yes, i will tape it now, thanks.
its not just the tape. Its how you twist the wires together so they won't easily pull apart.
See if they have “wire nuts” that can be used to connect two or more wire ends, plus they are insulated. May need to check a home hardware type store or a place that sells electrical wiring stuff.
Agreed, it's all in the details.
Wago type connectors make for quick easy joints that can be taken apart as easily as being made.
They come with a built in test point.
Again, care is needed to make sure the wire is properly in place before closing the locking lever.
The Chinese have got in on the act and turn out some convincing copies.
It doesn't matter much at low voltages, but some tests have shown problems that would put me off using clones for mains voltages.
The genuine ones are marked clearly with Wago.
For heavier jobs, Cembre do some nice screw down types. Transparent to make sure everything is in place.
Heavy leaf protection to avoid damage to wiring.
Not easy to find for retail users though.
This time, the formatting and moderation are done by ChatGPT: what is the rating out-of-10?
- Agreed — it’s all in the details.
- Wago-type connectors:
- Make quick, easy joints.
- Can be taken apart as easily as they are made.
- Come with a built-in test point.
- Require care to ensure the wire is properly seated before closing the locking lever.
- Clones (mostly Chinese copies):
- Some are convincing replicas.
- At low voltages, they may not pose significant issues.
- However, tests have shown problems at higher (mains) voltages.
- Therefore, clones are not recommended for mains applications.
- Genuine connectors:
- Clearly marked with “Wago”.
- For heavier-duty applications:
- Cembre offers good screw-down type connectors.
- Transparent design allows visual confirmation of proper wiring.
- Include heavy leaf protection to prevent wire damage.
- Not easily available for retail users.
Yes but put some tape on it so you don't accidentally short it to something.
