DS3231 RTC is consistently unable to set year correctly
Hello everyone. I am using DS3231 RTC with the library by Andrew Wickert.
Until now, my DS3231 has been working perfectly. Its battery is still good and time persists over power cycles. However, just now it's randomly lost the ability to correctly save the year.
void setClockData(){
  rtc.setSecond(second);
  rtc.setMinute(minute);
  rtc.setHour(hour);
  rtc.setDate(day);
  rtc.setMonth(month);
  rtc.setYear(2025);
  Serial.println(rtc.getYear());
I'm calling this function from elsewhere in my code. The second, minute, hour, etc variables are just global integers. At this stage, I've hardcoded in year 2025 to test the RTC. When this function is called, the println statement seen in that snippet outputs "73". This is consistent across reuploading the sketch and fiddling with wires. Attempting to set 2024 results in 72, 2025 = 73, 2026 = 74, and so on. All other values are still behaving as expected.
Any ideas?? I'm completely lost.
Instead of:
rtc.setYear(2025);
Use:
rtc.setYear(2025 - 2000);  // Store as offset from 2000
Now, rtc.getYear() should return 25 when you set 2025.
If you need the full year, modify your print statement like this:
Serial.println(rtc.getYear() + 2000);  // Convert offset back to full year
Please post your full sketch
Ok, sure. I'm still wondering though, why did the behaviour suddenly change? Passing in 2025 used to work.
It's quite long, but here you go.
53% storage space, 44% dynamic memory on an Uno.
Post it here in code tags to avoid the need to visit another site
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
#include <DS3231.h>
#include "icons.h"
// LCD
// const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 7, d7 = 8;
// hd44780_pinIO lcd(rs, en, d4, d5, d6, d7);
hd44780_I2Cexp lcd;
// LCD RGB
const int red_pin = 9;
const int green_pin = 10;
const int blue_pin = 11;
int colour[3] = {255, 255, 255};
// RTC
DS3231 rtc;
int year = 2025;
int month = 2;
int day = 2;
int hour = 22;
int minute = 20;
int second = 0;
bool dst = false;
// Encoder
const int enc_a = 3;
const int enc_b = 2;
const int enc_sw = 13;
unsigned long last_inc_read_time = micros();
unsigned long last_dec_read_time = micros();
int pause_length = 25000;
volatile int counter = 0;
// Program
bool inputs[2] = {false, false}; // States of the input buttons at each loop.
bool btn_lock[2] = {false, false}; // Button lock for each of the input buttons.
bool held = false;
bool timer_active = false;
bool world_clock = false;
int screen = 0;
bool just_entered = true;
bool stopwatch_running = false;
int stopwatch_begin = 0; // Timestamp of the most recent starting of the stopwatch.
int stopwatch_total = 0; // Total time on the stopwatch. Enables resuming from a pause without the pause time being a part of the total.
// Screens
#define CLOCK_FACE 0
#define OPTIONS_MENU 1
#define TIMER_MENU 2
#define STOPWATCH 3
#define ALARM_MENU 4
#define WORLD_CLOCK_MENU 5
#define COLOUR_MENU 6
#define CLOCK_SETUP 7
#define DISPLAY_OFF 8
///// END VARIABLES
  pinMode(red_pin, OUTPUT);
  pinMode(green_pin, OUTPUT);
  pinMode(blue_pin, OUTPUT);
  pinMode(enc_a, INPUT_PULLUP);
  pinMode(enc_b, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(enc_a), readEncoder, CHANGE);
  attachInterrupt(digitalPinToInterrupt(enc_b), readEncoder, CHANGE);
  pinMode(13, INPUT_PULLUP);
  int status;
  status = lcd.begin(16, 2);
  if(status){ // Non-zero result indicates failure to initialise LCD
    hd44780::fatalError(status); // Blink status code using onboard LED
  // Setup user data e.g. their selected colour, modes, RTC time, etc.
  analogWrite(green_pin, 255);
  rtc.setClockMode(false);
  getClockData();
  processInput();
  // Each screen's function manages inputs to process within its own context, inputs that change the active screen, and its own rendering
  switch(screen){
    case CLOCK_FACE:
      clockFace();
    case OPTIONS_MENU:
      optionsMenu();
    case STOPWATCH:
      stopwatch();
    case COLOUR_MENU:
      colourMenu();
    case CLOCK_SETUP:
      clockSetup();
    case DISPLAY_OFF:
      displayOff();
void enterScreen(int new_screen, bool expire_input){ // expire_input - index of input to expire in inputs[]
  screen = new_screen;
  if(expire_input > -1){ // Expire the input that was used to enter the new screen, so that it does not trigger any actions in the new screen
    inputs[expire_input] = false;
  lcd.clear(); // No leftovers from the previous screen!
void processInput(){
  // PROCESS BUTTONS
  // will need to be updated to support long/short pressing. Short press: action happens upon release, after short hold. Long press: action happens during hold, after a specified time has passed
  inputs[0] = false; inputs[1] = false;
  // Reading is currently inverted - LOW is pressed, HIGH is released.
  if(digitalRead(enc_sw) == LOW && btn_lock[0] == false){
    btn_lock[0] = true;
    inputs[0] = true;
  }else if(digitalRead(enc_sw) == HIGH && btn_lock[0] == true){
    btn_lock[0] = false;
    Serial.println("Unlocked");
  // READ ENCODER ROTATION
  static int last_counter = 0;
  if(counter != last_counter){
    last_counter = counter;
void optionsMenu(){
  static int prev_selected;
  if(just_entered){
    counter = 0; // Reset counter so that scrollable menu starts on option 0 (back)
    prev_selected = 1; // selected will initially be 0, therefore this will trigger an initial render of the menu
    just_entered = false;
    // Load initial icons (the selected option will have its icon dynamically updated later)
    //for(int i = 0; i < 8; i++){
      //lcd.createChar(i, icon_lookup[i*2]);
    lcd.createChar(0, icon_lookup[0]);
    lcd.createChar(1, icon_lookup[1]);
  static const char *option_names[8] = {"Back", "Timer", "Stopwatch", "Alarm", "World Clock", "Colours", "Clock Setup", "Display Off"};
  int selected = counter % 8;
  if(selected < 0){
    selected = 8 - abs(selected);
  if(inputs[0] == true){
    switch(selected){
      case 0:
        enterScreen(CLOCK_FACE, 0);
      case 2:
        enterScreen(STOPWATCH, 0);
      case 5:
        enterScreen(COLOUR_MENU, 0);
      case 6:
        enterScreen(CLOCK_SETUP, 0);
      case 7:
        enterScreen(DISPLAY_OFF, 0);
    //lcd.noCursor(); // Disable cursor so it doesn't appear outside of here
    return;
  if(selected != prev_selected){
    //lcd.createChar(selected, icon_lookup[(selected * 2) + 1]); // Invert icon of selected option
    //lcd.createChar(prev_selected, icon_lookup[prev_selected * 2]); // Undo inversion of previously selected option
    lcd.clear();
    //lcd.noCursor();
    lcd.setCursor(4, 1);
    for(int i = 0; i < 8; i++){ // Render icon slots 0-7
      //lcd.write(i);
      if(i == selected){
        lcd.write(1);
      }else{
        lcd.write(0);
    int leftmost_char = 16 - (strlen(option_names[selected]));
    lcd.setCursor(leftmost_char, 0);
    lcd.print(option_names[selected]);
    lcd.setCursor(0, 1);
    //lcd.cursor();
    //lcd.setCursor(selected + 4, 1); // To show the cursor at the selected option.
    prev_selected = selected;
void colourMenu(){
  static int c_menu_stage;
  static int final_hue = 0;
  static int final_lightness = 50;
  if(just_entered){
    counter = 0;
    c_menu_stage = 0;
    lcd.setCursor(1, 0);
    lcd.print("Set Colour");
    lcd.setCursor(1, 1);
    lcd.print("then press");
  if(c_menu_stage == 0){
    final_hue = abs(counter % 360);
    updateColour(final_hue, 50);
  }else if(c_menu_stage == 1){
    constrain(counter, 0, 100);
    //final_lightness = counter; brightness effect doesn't look very good
    updateColour(final_hue, final_lightness);
  } // Add display contrast?
  analogWrite(red_pin, colour[0]);
  analogWrite(green_pin, colour[1]);
  analogWrite(blue_pin, colour[2]);
      c_menu_stage = 1;
      counter = 50;
      lcd.print("Set Brightness");
      // c_menu_stage = 2; For changing contrast
      enterScreen(OPTIONS_MENU, 0);
      return;
void clockSetup(){
  static int s_menu_stage;
  if(just_entered){
    s_menu_stage = 0;
    counter = hour;
    lcd.print("Set");
    lcd.print("Time");
  switch(s_menu_stage){
    case 0:
      timeSelector(&second, &minute, &hour);
    case 1:
      dateSelector(&day, &month, &year);
      Serial.print("Updated year: ");
      Serial.println(year);
    case 2:
      // DST setting menu - turn the dial to toggle between on or off (counter % 2)? This case can't be reached for now
  // Process inputs
      case 0:
        lcd.print("Date");
        counter = year;
        Serial.print("Setting counter to year: ");
      case 1:
        Serial.print("Saving year: ");
        setClockData(); // Save changes to RTC
        return;
      case 2:
        // DST choice completed - achieve it by setting the RTC time forward or back by 1h
        return;
    s_menu_stage += 1;
// Both this and date selector take pointers and update the values directly, and hence don't need to return anything
void timeSelector(int* secondP, int* minuteP, int* hourP){
  static int ts_menu_stage;
  switch(ts_menu_stage){
    case 0:
      counter = constrain(counter, 0, 23);
      *hourP = counter;
    case 1:
      counter = constrain(counter, 0, 59);
      *minuteP = counter;
    case 2:
      *secondP = counter;
  // Rendering
  char time_string[9];
  snprintf(time_string, sizeof(time_string), "%02d:%02d:%02d", *hourP, *minuteP, *secondP); // Change snprintf to string functions (strcpy, strcat) if running out of code space
  lcd.setCursor(8, 0);
  lcd.print(time_string);
  int indicator_loc = 8 + ((ts_menu_stage % 3) * 2) + (ts_menu_stage % 3);
  lcd.setCursor(6, 1);
  lcd.print("          "); // Clear existing ^^
  lcd.setCursor(indicator_loc, 1);
  lcd.print("^^");
  // Process inputs
      case 0:
        inputs[0] = false;
        counter = *minuteP;
      case 1:
        inputs[0] = false;
        counter = *secondP;
      case 2:
        ts_menu_stage = 0;
        return;
    ts_menu_stage += 1;
void dateSelector(int* dayP, int* monthP, int* yearP){
  static int ds_menu_stage;
  switch(ds_menu_stage){
    case 0:
      counter = constrain(counter, 2024, 2100);
      *yearP = counter;
    case 1:
      counter = constrain(counter, 1, 12);
      *monthP = counter;
    case 2:
      counter = day_constrain(counter, *monthP, *yearP); // Different range depending on which month is selected.
      *dayP = counter;
  // Rendering
  char date_string[11];
  snprintf(date_string, sizeof(date_string), "%02d/%02d/%d", *dayP, *monthP, *yearP);
  lcd.setCursor(6, 0);
  lcd.print(date_string);
  int indicator_loc = 12 - ((ds_menu_stage % 3) * 2) - (ds_menu_stage % 3);
  if(ds_menu_stage == 0){
    lcd.print("^^^^");
  }else if(ds_menu_stage < 3){
    lcd.print("^^");
  // Process inputs
      case 0:
        inputs[0] = false;
        counter = *monthP;
      case 1:
        inputs[0] = false;
        counter = *dayP;
      case 2:
        ds_menu_stage = 0;
        return;
    ds_menu_stage += 1;
void stopwatch(){
  static int prev_selected = 0;
  static bool update_menu = false;
  if(just_entered){
    counter = 0;
    prev_selected = 1;
    // Load icons
    for(int i=0; i<6; i++){
      lcd.createChar(i, sw_icon_lookup[i]);
    // Swap to pause icon if we are re-entering the stopwatch screen after it has been running in the background
    if(stopwatch_running){ // Better way of doing this that isn't just overwriting the work we did in the for loop above?
      lcd.createChar(2, sw_icon_lookup[6]);
      lcd.createChar(3, sw_icon_lookup[7]);
    lcd.createChar(6, icon_lookup[4]); // Check the lookup index later once main menu swapped over to raised icon selection indicator
  int selected = counter % 3;
  if(selected < 0){
    selected = 3 - abs(selected);
    // Process inputs
    switch(selected){
      case 0: // Back button
        return;
      case 1: // Start or pause stopwatch
          // Add runtime until now to the total
          lcd.createChar(2, sw_icon_lookup[2]); // Swap to play icon
          lcd.createChar(3, sw_icon_lookup[3]);
        }else{
          // Set start time to now
          stopwatch_running = true;
          lcd.createChar(2, sw_icon_lookup[6]); // Swap to pause icon
      case 2: // Reset stopwatch
        stopwatch_total = 0; // Will this need to be a long? Intend to enable stopwatch to support up to 23:59:59 of total runtime
    update_menu = true;
  // Render stopwatch time string
  lcd.setCursor(4, 0);
    // total + calculated time since start
    lcd.print("12:34:56");
  }else{
    if(stopwatch_total == 0){
      lcd.print("00:00:00");
    }else{
      // stopwatch_total
      lcd.print("01:01:01");
  // Render stopwatch controls menu
  if(selected != prev_selected || update_menu){
    for(int i=0; i<3; i++){
      if(i == selected){
        lcd.write(i*2 + 1);
      }else{
        lcd.write(i*2);
    lcd.setCursor(11, 1);
    switch(selected){
      case 0:
        lcd.print(" Back");
      case 1:
          lcd.print("Pause");
        }else{
          lcd.print("Start");
      case 2:
        lcd.print("Reset");
void clockFace(){
  static bool show_colon = false;
  static unsigned long colon_last_millis = 0;
    return;
  getClockData();
  Serial.print("Year: ");
  char time_str[6];
  if(show_colon){
    snprintf(time_str, 6, "%02d:%02d", hour, minute); // Look into snprintf to assign the hour and minute values as required
  }else{
    snprintf(time_str, 6, "%02d %02d", hour, minute);
  if(millis() - colon_last_millis > 1000){
    show_colon = !show_colon;
    colon_last_millis = millis();
  lcd.print(time_str);
  char date_str[6];
  snprintf(date_str, 6, "%02d/%02d", day, month);
  lcd.setCursor(10, 1);
  lcd.print(date_str);
  if(timer_active){
    // Render timer, bottom left
  if(world_clock){
    // Render world clock, top right
  }else{
    // Render seconds progressbar, top right
void displayOff(){ // What about interrupts for the button here, so the MCU can sleep while display is off?
  if(just_entered){
    lcd.noDisplay();
    analogWrite(red_pin, 0);
    analogWrite(green_pin, 0);
    analogWrite(blue_pin, 0);
    lcd.display();
void readEncoder() {
  static uint8_t old_AB = 3;
  static int8_t encval = 0;
  static const int8_t enc_states[] = {0, -1, 1, 0, 1, 0, 0, -1, -1, 0, 0, 1, 0, 1, -1, 0};
  old_AB <<= 2;
  if(digitalRead(enc_a)) old_AB |= 0x02; // Add current state of pin A
  if(digitalRead(enc_b)) old_AB |= 0x01; // Add current state of pin B
  encval += enc_states[(old_AB & 0x0f)];
  if(encval > 3){ // Four steps forward
    int change_value = 1;
    if(micros() - last_inc_read_time < pause_length){
      change_value *= 3;
    counter += change_value;
    encval = 0;
  }else if(encval < -3){ // Four steps backward
    int change_value = -1;
    if(micros() - last_dec_read_time < pause_length){
      change_value *= 3;
    encval = 0;
void getClockData(){
  second = rtc.getSecond();
  minute = rtc.getMinute();
  bool twelveHour, pmHour;
  hour = rtc.getHour(twelveHour, pmHour);
  day = rtc.getDate();
  bool centuryBit;
  month = rtc.getMonth(centuryBit);
  year = rtc.getYear();
  rtc.setHour(hour);
  rtc.setDate(day);
  year = 2026;
  rtc.setYear(2026);
void updateColour(float hue, float lightness) {
  // Implement changing Lightness to allow for different shades. Hue = pick colour, Lightness = pick shade, Sat will always be 1
  hue = hue / 360;
  double r, g, b;
  lightness = lightness / 100.0;
  static const float saturation = 1;
	if (saturation == 0){
		r = g = b = lightness; // achromatic
	}else{
    auto q = lightness < 0.5 ? lightness * (1 + saturation) : lightness + saturation - lightness * saturation;
		auto p = 2 * lightness - q;
		r = hue2rgb(p, q, hue + 1 / 3.0);
		g = hue2rgb(p, q, hue);
		b = hue2rgb(p, q, hue - 1 / 3.0);
	uint8_t red = static_cast<uint8_t>(r * 255);
	uint8_t green = static_cast<uint8_t>(g * 255);
	uint8_t blue = static_cast<uint8_t>(b * 255);
  colour[0] = red;
  colour[1] = green;
  colour[2] = blue;
  Serial.print("Red = ");
  Serial.print(red);
  Serial.print(" Green = ");
  Serial.print(green);
  Serial.print(" Blue = ");
  Serial.println(blue);
double hue2rgb(double p, double q, double t){
	if (t < 0) t += 1;
	if (t > 1) t -= 1;
	if (t < 1 / 6.0) return p + (q - p) * 6 * t;
	if (t < 1 / 2.0) return q;
	if (t < 2 / 3.0) return p + (q - p) * (2 / 3.0 - t) * 6;
	return p;
int day_constrain(int value, int month, int year){
  if(value < 1) return 1;
  int month_max = 31;
  switch(month){
    case 2:
      month_max = 28;
      if(year % 4 == 0){ // Check leap year
        if(year % 100 == 0){
          if(year % 400 == 0){
            month_max = 29;
        }else{
          month_max = 29;
    case 4:
    case 6:
    case 9:
    case 11:
      month_max = 30;
  if(value > month_max) return month_max;
  return value;
Sorry, I just thought posting it here would make the single post become really huge and be annoying to scroll past, I didn't realise it adds a scrollbar automatically
Not only that, it can be copied with a single mouse click for examination in the IDE
You sure? Same library?
The RTC chip stores the year as two BCD digits, so has a range of 0 .. 99.
Anything beyond that is a matter of software. Post any sketch where it worked the way you want it to, and specify the library.
a7
Yep, that's the whole solution, thanks.. I feel stupid for even posting this now lol. I tried it with a previous version of the sketch and it does indeed have the same behaviour. Just now I changed the whole RTC setting code and I was so scared about breaking things that I made up this issue out of thin air
