DS3231 RTC is regularily resetting to 00:00:00 (Arduino Uno project)
J-M-L:
There is no extra Resistor or diode in your jack setup ?
There was not, initially, but I installed a 10k resistor on the A0 input from the jack yesterday evening.
And this morning, both system's clocks reset again... With the new code and the extra resistor. :frowning:
There must be another flaw...
[EDIT]
I also noticed that, when the hour at which the system is supposed to allow the opening when a jack is inserted (7AM) is reached, it doesn't... until I open a serial monitor console, and then it refreshes the time and system is up. It's as if time was "frozen" outside of the opening hours (7-22). When I open a console before 7AM, time shows every 500ms, as programmed, but the time reading stays the same (whereas before it did change)...
[EDIT2]
I've decided to take the RTC out of the equation by using a programmable power socket instead, that will turn the whole Arduino & electric strike on and off, with a simple code running. This is a bid disapointing but this is an emergency call... :slight_smile:
