ok so im trying to integrate a DS3234 into my project, using a mega 2560 with an ITDB02-5 and I missing something in the set up. using a DS3234 library that I will link bellow. but here is the section of code...
#include <UTouch.h>
#include <avr/pgmspace.h>
#include <UTFT.h>
#include <tinyFAT.h>
#include <UTFT_tinyFAT.h>
#include <EEPROM.h>
#include <RTClib.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SPI.h>
#include <DS3234.h>
//******** Declare Touch/LCD/RTC **********
UTFT myGLCD(ITDB50, 38, 39, 40, 41); //sets LCD pins - change to your screen pin-out and aspect
UTouch myTouch(6,5,4,3,2); //sets touch pins - change to your set up (default is usually 6,5,4,3,2)
UTFT_tinyFAT myFiles(&myGLCD);
DS3234 RTC(8);
//******** Call Fonts **********
extern uint8_t arial_bold[];
extern uint8_t Sinclair_S[];
extern uint8_t SevenSegmentFull[];
void Draw_Clock(int clock_x, int clock_y){
DateTime now = rtc.getTimeStr();
Hours = now.hour();
Minutes = now.minute();
Seconds = now.second();
Day = now.day();
Month = now.month();
Year = now.year();
Weekday = now.dayOfWeek();
Current_time = (Hours + ":" + Minutes);
myGLCD.setFont(SevenSegmentFull);
myGLCD.setColor(0,255,255);
myGLCD.setBackColor(0,0,0);
and the error for that section
.ino: In function 'void Draw_Clock(int, int)':
.ino:864:18: error: 'rtc' was not declared in this scope
DS3234.cpp (8.96 KB)
DS3234.h (2.8 KB)
Or is there an easier way / better lib to use?
Please post your complete code.
Have you tried to write a code just using the DS3234 and serail terminal to debug?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Tom....
the whole code is to big to post, ill see if I can attach. ok its there. and right now the circuit is fairly simple. the itdb02-5 is on the mega with a mega shield from itead. the ds3234 is as follows...
mosi - pin 51
moso - pin 50
sclk - pin 52
ss - pin 8
vcc - 5v
ground and sqw are grounded
AquaPorn.ino (124 KB)
If this is your object instantiation,
DS3234 RTC(8);
then it should be in lower case to match
K I matched it so now its DateTime = RTC.getTimeStr(); and this is the new error code for that line
Arduino: 1.6.1 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
AquaPorn.ino: In function 'void Draw_Clock(int, int)':
AquaPorn.ino:864:33: error: invalid conversion from 'char*' to 'uint32_t {aka long unsigned int}' [-fpermissive]
In file included from AquaPorn.ino:34:0:
C:\Program Files (x86)\Arduino\libraries\RTClib/RTClib.h:7:5: error: initializing argument 1 of 'DateTime::DateTime(uint32_t)' [-fpermissive]
DateTime (uint32_t t =0);
Well, that is a straightforward type mismatch, so look at the method's return type and what type you are assigning it to. Actually, not just the type, but what it "is".
Im sorry but I don't understand...
jlyman28:
does rtc.getTimeStr() return a DateTime data type? Look at the documentation and/or function prototype.
My understanding was that it gets the time from the rtc and stores it as a string
jlyman28:
Then why are you expecting it to return a DateTime type? Because, that is what type you are making the variable "now". If you want a string, make "now" a string type.
I did have it as DateTime now = RTC.now();
And the error showed up saying now is not defined. Sorry I can't post actual error for that one I'm on my phone at the moment.
Ok so on a reconsideration I decided to take a step back and just try to get this to work on its own and receive either garbage...all zeros for time and date or random numbers that don't work. Anyone have a reliable library with example sketch to load the time?
thanks that work great, its keeping track of the time now, just need to set the correct time and date lol
FWIW, instead of including Hennings library as attachments in post 1, you could just have said, using this library DS3234 - Rinky-Dink Electronics.
Doing it this way, in 6 months time when somebody else has the same problem you did, they will always be downloading the LATEST version from Henning, not the outdated version you attached.
Regards,
Graham
I have tried may libraries and Im not sure what im doing wrong. I cant get the time to load on to this thing. the code I just tried is
#include <Time.h>
#include <DS3234.h>
//This section retrieves the system time (unix) in a more manageable h,m,s... format
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by Unix time_t as ten ASCII digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync message
// T1262347200 //noon Jan 1 2010
void loop(){
if(Serial.available() )
processSyncMessage();
if(timeStatus() == timeNotSet)
Serial.println("waiting for sync message");
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void processSyncMessage() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of header & 10 ASCII digits
char c = Serial.read() ;
Serial.print(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
setTime(pctime); // Sync Arduino clock to the time received on the serial port
/* Then the user needs to open terminal and run the following command:
sudo echo "T$(($(date +%s)+60*60-5))" >/dev/tty.usbmodem1421
where -5 is the time zone adjustment from GMT and tty.usbmodem1421 is your serial port
/* This was the original way to manually set the RTC time:
[code]
how ever all I get back in the serial moniter is waiting for sync message. for some reason it looks like im not talking to the rtc.
In the serial monitor, you need to send T1428167490 which is approximately about now.
Regardless of if you are ACTUALLY talking to the RTC, the sync message should go away once you send a string like the one suggested.
Regards,
Graham
this is confusing the hell out of me...that code did work and message went away, date was right but was 4 hours ahead of time. then running a different sketch the time was no longer there. I installed the above library you linked to and ran the sample sketch for easy and get this
xxxxxxxxx 00.00.200 -- 00:00:00 -- Internal temp: 0.00c
4hours ahead means you are not in the UK !!
just remove (46060) from the number.....
But down to the ACTUAL problem you are having...... Do you have a battery connected to your module?
What I would suggest is change the time print routine to explicitly use the rtc components of time.
Example:
Serial.println(rtc.getTimeStr(FORMAT_LONG);
// Serial.print(hour());
// printDigits(minute());
// printDigits(second());
// Serial.print(" ");
// Serial.print(day());
// Serial.print(month());
// Serial.print(year());
// Serial.println();
I am thinking you have 'borrowed' the DS1307 set time example, and substituted DS3234.h in the include??
I am not sure the syntax are the same.
But let me know what happens with this? Also, is there any chance you crossed your miso/mosi wires? Or might I suggest you do. We WILL fix this, I have no doubt
Regards,
Graham
I do have a battery installed, I have crossed and recrossed miso and mosi several times with same results.
// DS3234_Serial_Easy
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// A quick demo of how to use my DS3234 library to
// quickly send time and date information over a serial link
// Connections:
// | Arduino | | chipKit |
// | DS3234 | Uno | Mega | Due | Leonardo | Bobuino | Uno32 | uC32 | Max32 |
// | DIN | D11 | D51 | D75 | D16 | D11 | D11 | D11 | D51 | -> MOSI
// | DOUT | D12 | D50 | D74 | D14 | D12 | D12 | D12 | D50 | -> MISO
// | SCLK | D13 | D52 | D76 | D15 | D13 | D13 | D13 | D52 |
// | CS | User selectable (Set to D8 by default in this demo) |
// Note that the SPI pins are only available on the ICSP header
// on the Arduino Due and Arduino Leonardo.
// Boards with SPI Master/Slave Select jumpers should be set to the Master position.
// ICSP header pinout: +---+---+
// 1 - MISO | X | X | 2 - Vcc
// 3 - SCLK | X | X | 4 - MOSI
// 5 - Reset | X | X | 6 - GND
#include <DS3234.h>
// Init the DS3234
DS3234 rtc(8);
// Initialize the rtc object
rtc.begin();
// Setup Serial connection
#ifdef __AVR_ATmega32U4__
while (!Serial) {}; // wait for serial port to connect. Needed for Arduino Leonardo only
#endif
// The following lines can be uncommented and edited to set the time and date in the DS3234
// rtc.setDOW(SATURDAY); // Set Day-of-Week to SATURDAY
// rtc.setTime(11, 15, 0); // Set the time to 12:00:00 (24hr format)
// rtc.setDate(4, 4, 2015); // Set the date to January 25th, 2014
// Send Day-of-Week
Serial.print(rtc.getDOWStr());
Serial.print(" ");
// Send date
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
// Send time
Serial.print(rtc.getTimeStr());
// Send temperature
Serial.print("Internal temp: ");
Serial.print(rtc.getTemp());
Serial.println("C");
// Wait one second before repeating :)
delay (1000);
[code]
