char xStrBuffer[7] = "";
char yStrBuffer[7] = "";
float newXAxis = 0L; // Holds the new value where the dish should point to
float newYAxis = 0L;
Serial.begin(115200); // Start the Serial communication
while(!Serial);
dtostrf(newXAxis,7, 2, xStrBuffer); // Create the x value to print
dtostrf(newYAxis,7, 2, yStrBuffer); // Create the y value to print
Serial << xStrBuffer << endl; // Print only the x value
Serial << xStrBuffer << " -" << yStrBuffer << endl; // Print both x and y values
The result of first print looks like : 123.45 89.99
And the second print looks like : 123.45 89.99 - 89.99
I don't understand why you're seeing those values, because your sketch only uses zeroes, but the reason the serial print is producing unexpected output is probably that your buffers are too small. You're specifying the minimum width as 7 chars, but your buffer is only 7 chars long so you don't have space for the null terminator. I suspect you'll find the terminator is actually ending up in memory occupied by the second buffer and is being clobbered when you use the second buffer. Make your buffers long enough to hold the strings you're creating, and that should take care of it.
You are lying to the dtostrf() function. You do NOT have room for 7 characters plus a terminating NULL in the array. You MUST accept the fact that you need a larger array.
