Dtostrf() problems
Can anyone advise me on this problem? I am trying to print a float value onto a UTFT screen. After reading several articles which all say to use dtostrf() and use the avr-libc library, I have tried this but cannot get any joy.
#include <AVR_RTC.h>
#include <time.h>
#include <UTFT.h>
UTFT myGLCD(SSD1289, 38, 39, 40, 41);
extern uint8_t BigFont[];
int Htime;              //integer for storing high time
int Ltime;                //integer for storing low time
int long Ttime;            // integer for storing total time of a cycle
float frequency;        //storing frequency
String DisplayFreq;
    pinMode(A0,INPUT);
    myGLCD.InitLCD();
    myGLCD.clrScr();
     myGLCD.clrScr();
    myGLCD.print("Frequency of signal",CENTER, 20);
    Htime=pulseIn(A0,HIGH);      //read high time
    Ltime=pulseIn(A0,LOW);        //read low time
    Ttime = Htime+Ltime;
    frequency=1000000/Ttime;    //getting frequency with Ttime is in Micro seconds
    dtostrf(frequency,7, 3, DisplayFreq);
    myGLCD.print(DisplayFreq, CENTER, 40);
    myGLCD.print(" Hz",RIGHT,40);
I get this error
fatal error: util/atomic.h: No such file or directory
#include <util/atomic.h>
I am using an Arduino Due and a SSD1289 UTFT
Any help would be appreciated
Steve
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Please post a complete sketch that illustrates the problem
the output buffer needs to be a c-string, char, not a String (see dstrtof())
I think the fourth argument is supposed to be a character array, not a String. Try:
char DisplayFreq[17];
Thanks Guys,
Unfortunately I am still getting this error:
I think it is to do with the avr-libc, do you now of a library that works? I seem to be having lots of problems with this one.
Is that the full error message copied using the "Copy error messages" button in the IDE ?
Hi HeliBob
Sorry it wasn't, but have pasted it below
Arduino: 1.8.13 (Windows 10), Board: "Arduino Due (Programming Port)"
C:\Users\Anyuser\Documents\Arduino\libraries\AVR_Standard_C_Time_Library\src\timer2.c:6:25: fatal error: util/atomic.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino Due (Programming Port).
option enabled in File -> Preferences.
So the problem is in line 6 of a file in the AVR_Standard_C_Time_Library library you installed. Perhaps that library wasn't tested on the DUE? Maybe you can find a different library for your RTC hardware.
Hi John,
I think you are right, I routed around on google and found this
Thanks for your comment though
Regrards
Steve
