Due Operation Stable?
GoForSmoke:
I don't mind DuPont cabling to header pins on top.
Ok then, but you still end up with some pins that plug easily into your breadboard, and others that require a special cable or other extra work to access. Well, unless you make ALL the pins require cables and extra stuff!
Can nobody offer any opinion about which pins are more important? Is the only opinions everyone is capable of speaking about ways to have all pins, even if they cost more, require cables, increase size, etc?
Using an idea something like this, I envision a new generation, high speed board to be as compatible as possible to the previous generation (I/O and footprint) but additionally have a high density, low profile and surface mount board to board connector underneath. This would allow connection to a shield which would essentially change the format to say, the Mega or Due (or others).
Paul. The board I'm thinking of is basically for me and I really don't care if anyone else uses it. I have a friend that uses the Teensy. As far as he's concerned, it's pretty much a component. Trying to help him out recently got my interest going again.
Basically, a raw chip with a provision for power and crystal if desired. Probably a communication header to for ease of start up. All this stuff would have to be enabled via jumper. Truly optional. The pins would be wire for wire as they come off the chip. No effort to break them down by function. I doubt that will appeal to many but that isn't my concern. I have no illusions of it sticking on a breadboard. I've seen a couple others with this interest but that's about it. More about being truly able to prototype a circuit.
But, let's be honest. With through hole components going the way of the dinosaur it is getting harder and harder to do the component level stuff. The breadboard is also probably getting to be less useful except to stick pre-built circuits on like the Teensy. You don't really need to tie a new product to a breadboard design. Just make it so it can hook up to a breadboard or other components. Who cares if it is physically attached to the breadboard as long as you have jumpers? Seriously?
I would imagine any manufacturer trying to make the new product as compatible as possible to the needs of the masses. Just to elaborate a bit more ... say the new board was just a tiny "core" board with several bottom B-B connectors and micro-USB programming port (just enough components to allow programming and verify its operation (led).
Then develop various cards it snaps into that provide the power regulator(s) and other necessary components to make it compatible with the new format.
  • Teensy 4.0
  • Due/Mega
  • UNO
  • Embedded (this core board is already compatible with this - all I/O are available)
"Embedded (this core board is already compatible with this - all I/O are available)"
Can you clarify this? Sorry, I read it as real product called "Embedded" since the other are real too.
I think it is time to start putting "down on paper" the old fashioned laundry list.
Mainly because I see some conflicting stuff.
Minor example - I do not foresee full blown I/O board "for masses" as a design requirement.
As far as "Using an idea something like this, I envision a new generation..." that is nothing new.
Still uses .1 headers for devices build "ceramic substrate style" ( sorry I forgot the real marketing name for the technology) which was "new stuff " about 30 years or maybe even more ago.
BTW I quit watching after stuff started moving around, too distracting.
Hi Vaclav, was just thinking out loud. Just an idea for a new Arduino product to be as compatible as possible with the most variety board formats. Nothing new really, as the Intel® Edison module is an example that can be plugged into a breakout board, Arduino format board, or the user could embed it into his own product. So how about a new low-cost "teensy" core module that would have the same versatility (hint-hint).
dlloyd:
A new Teensy is definitely in the works. But (probably) not with an Edison-style connector.
It wouldn't be a 'Teensy' anymore but it could span two bread boards.
ArthurD:
Actually 5V is a vintage voltage, standard is 3.3V (Due, Zero, 101, Tian, even Raspberry Pi) -
many modern boards go down to just 1.8V .
If you have issues with pin or signal levels: use level shifters!
HTH!
:sunglasses:
Hi there,
Yes, i am aware of the trends and the level shifters and related parts. But level shifters add more complexity, complexity that is not needed on the 5v boards, and that means there are more problems that can come up.
For example, any level shifter or related 3.3v to 5v solution requires one important connection...one more important than all the other connections on the whole board almost. That is, the connection from the level shifter (or clamp) to the +3.3v supply. If that connection becomes undone for any reason such as a jumper wire pulling out unexpectedly, the whole protection scheme goes down the drain. That's because level shifters and external clamps rely on using the 3.3v to limit the voltage getting to the ARM chip i/o pin. Without that connection there could still be 5v getting to the pin and thus a failure.
That means a plug in jumper (commonly used on Uno and others) is not a good idea as it should be a soldered connection, soldered right from the shifter to the Due board.
So that's a very critical connection that is important for the Due board when using external 5v peripherals.
If you can find 3.3v peripherals, all the better, but they are not as widely available as the 5v ones, at least not yet.
A low impedance clamp would help here rather than a clamp that relies on the 3.3v supply, but that has to be designed properly too so that it clamps even over temperature extremes.
These problems add complexity and risk where there was none before.
5 volt signals really are obsolete now. Pretty much everything runs on 3.3V or lower these days. 3.3V signals and chips without 5V tolerance are the norm now.
For example, buy any color TFT display (like ST7735 or ILI9341) or motion sensor chip (MPU9050, LSM303D, etc), or GPS module, or wireless chip (ESP8266, nRF8001, etc), or flash memory chip, or SD card, or numerous other chips! They all use 3.3V signals. Almost all new microcontrollers do too.
A few (like Teensy 3.2) have 5V tolerant inputs, but even that is no longer the norm! Most chips made in the last 10+ years are incompatible with 5V signals, unless you put a special buffer chip in front of them, as is done on products sold to Arduino users.
If I break a working circuit, it won't work.
I can just feel the leet now.
