Due Serial.avaible not working (solved)
Hello, i just bought Due for faster calculations.I was using apc220 (wireless data transfering module) with 2 nano it work fine but in due not working.
It working if i hold down reset button and if i send something in serial port it taking data
Any idea?
the most important idea is to provide sufficient information
Hello Newbee,
Welcome to the Arduino forum. I and the other people here want to help you but to do that we need certain bits of information. Without the correct information it is difficult or impossible to give you the help and advice you need. To help us to help you please read General guidance andHow to use this forum and provide the information asked for. Being new here you might think this is asking too much or having rules for the sake of rules, that is not the case. If you don't follow the guidelines all that happens is there is a long exchange of message while we try to get you to tell us what we need in order to help you, this is frustrating for you and frustrating for us.
Common mistakes for people posting here the first time:
Code problems:
Not posting any code while expecting us to work out what is wrong with your code; we are to look into a glas-sphere and can only find problems in code we can see.
Posting a snippet of code in the belief that the problem is in the code snippet. It is almost always the case that the problem is not where you think it is but elsewhere in the code, hence we need all the code.
Not correctly formatting code. Before posting code use Tools / auto format at the top of the IDE, or use control T. Once you've done that use edit / copy for forum.
Posting code without code tags (</>), these are explained in the instructions linked to above. Using code tags makes the code easier to read. Not using code tags means some of the code gets interpreted as HTML with the result that it is displayed with smiley faces and other stuff that should not be there.
Asking for complete code; we are not here to write code for you, we are here to help you if you get stuck writing code yourself. If you really want someone to write code for you please click on 'report to moderator' and ask them to move this to 'Gigs and Collaborations' and indicate how much you are willing to pay.
Schematics:
The language of electronics is a schematic or circuit diagram. Long descriptions of what is connected to what are generally useless. A schematic is a drawing of what connects to what, please make one and photograph it. We don't mind if it's hand drawn, scruffy and does not use the correct symbols. We do mind if you don't at least try to post a schematic. Please read How to post an image
Questions:
Not being clear about what is being asked, for example not asking a question at all or asking a vague question like 'please help' or some such thing.
About us:
Those of us answering questions have a wide variety of backgrounds and electronics knowledge, some though working in electronics, some through electronics as a hobby, some both. Most of us are not trained as teachers so probably miss the finer points of how to teach and explain things effectively. We are not, with the odd exception, employees or representatives of Arduino.
Please also remember we are volunteers doing this for free in our spare time and are more inclined to help people who make it easy for us to provide help by providing the information we ask for.
About you:
We only know about you what you tell us; we need to know your level of experience with electronics or microcontrollers, if we don't know then we can't tailor our answer to your level of knowledge. We also don't know if you have problems with English or language or communications in general unless you tell us. We can be sympathetic about problems we know about, but if you don't tell us we don't know.
Thank you.
This is the programming section of the forum, and yet you seem to have forgotten something.
thanks but i m not new in arduino so please if u dont have idea to fix this problem do not reply this post..
Hey, if you don't want any help, don't post any code.
Oh, Wait.
Here is a solution i wish this post will help someone.
all need to plug UART TX to RX3 (15) pin on Due board , also here is a code you have to use another Serial
Serial.begin(19200);
Serial3.begin(19200);
while(Serial3.available()>0)
char inChar = Serial3.read();
String s= (String) inChar;
s.c_str();
Serial.println(s);
This is a lot simpler:
     Serial.println(inChar);
If this doesn't work you have a hardware issue or a data rate issue. May be a wiring diagram would help us?
dont worry about simpler, i have lot of string manupilation on orjinal code.
Just get idea how its work
Check diagram for pins
Should work but I would use a very simple program to test it out before adding a lot of other stuff.
