eaaasy question..
why do we need a resistor (220Ohms) to the MIDI output?? ::slight_smile:
thanks
alright then, any place where I can read more info about the MIDI I/O circuits?
I know there is lot of info out there, but for some reason most of them mention the resistor (220Ohm) but without explaining why it should be used..
thanks
I think I remember that Midi works with some optocouplers? Might be there to limit the current, or as a pull-up, I don't know. Any specific reason why you don't want that resistor to be around?
And .. errrr... what made you think that this is an easy question????
Eberhard
hi wayoda,
I've already put a 220 Ohms resistor at my MIDI output (following some examples). However, I would like to know exactly what I'm doing :slight_smile:
I thought it was easy because I can't find any info...
w
Hi w,
here is a link for a page full of midi schematics http://home.concepts-ict.nl/~nctnico/midi.htm
On one of these pages it says that a midi-interface works by switching a current of ~5mA on and of.
(Switching currents as opposed to switching a Voltage-level is used in areas where there is a lot of (electronic) noise from the outside, like when a band is playing on stage.)
So the 220Ohms is there to limit the current to (roughly) 5 mA. As there is usually an Led on the other end of the Midi-Controler-circuit, I think a current from 3-20mA would be acceptable.
And here is the "official" midi-schematic
http://www.midi.org/about-midi/electrical.shtml
I guess it's the midi-out section you are interested in. This has actually two resitors (plus another one on the midi-in receiver side).
But using only one resistor should be fine.
Eberhard
oh, i see..
thanks Eberhard :slight_smile:
