I'm new to programming arduino and need some feedback.
I am working on a simple program to turn a relay on and off. I'm using a DS18B20 temp sensor and the onewire.h library.
As you can see, I've set pin 2 as an output high to a relay when the temp >x and low when the temp is <x. I've done some testing on the bench and it seems to work just fine.
Based on the code sections below, can anyone see any issues with what I am trying to accomplish?
Well, it won't compile. It's missing braces and the loop function. All that temperature getting and printing and the if statements should probably go in loop or they'll only be executed once.
That was just one portion of the entire code. It is basically the Dallas Semiconductor onewire library with my "IF" statement.
Here is the entire code:
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr*, HEX);*
if (OneWire::crc8(addr, 7) != addr[7]) {*
Serial.println("CRC is not valid!");*
return;*
Serial.println();*
// the first ROM byte indicates which chip*
switch (addr[0]) {*
case 0x10:*
Serial.println(" Chip = DS18S20"); // or old DS1820*
type_s = 1;*
break;*
case 0x28:*
Serial.println(" Chip = DS18B20");*
type_s = 0;*
break;*
case 0x22:*
Serial.println(" Chip = DS1822");*
type_s = 0;*
break;*
default:*
Serial.println("Device is not a DS18x20 family device.");*
return;*
ds.reset();*
ds.select(addr);*
ds.write(0x44, 1); // start conversion, with parasite power on at the end*
delay(1000); // maybe 750ms is enough, maybe not*
// we might do a ds.depower() here, but the reset will take care of it.*
present = ds.reset();*
ds.select(addr); *
ds.write(0xBE); // Read Scratchpad*
Serial.print(" Data = ");*
Serial.print(present, HEX);*
Serial.print(" ");*
for ( i = 0; i < 9; i++) { // we need 9 bytes*
_ data = ds.read();_ _ Serial.print(data*, HEX); Serial.print(" "); } Serial.print(" CRC="); Serial.print(OneWire::crc8(data, 8), HEX); Serial.println(); // Convert the data to actual temperature*
* // because the result is a 16 bit signed integer, it should* * // be stored to an "int16_t" type, which is always 16 bits*
* // even when compiled on a 32 bit processor._ int16_t raw = (data[1] << 8) | data[0]; if (type_s) { _ raw = raw << 3; // 9 bit resolution default*
* if (data[7] == 0x10) { // "count remain" gives full 12 bit resolution*
* raw = (raw & 0xFFF0) + 12 - data[6]; } } else { byte cfg = (data[4] & 0x60); // at lower res, the low bits are undefined, so let's zero them*
* if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms*
* else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms*
* else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms*
* //// default is 12 bit resolution, 750 ms conversion time*
* } celsius = (float)raw / 16.0; fahrenheit = celsius * 1.8 + 32.0; Serial.print(" Temperature = "); Serial.print(celsius); Serial.print(" Celsius, "); Serial.print(fahrenheit); Serial.println(" Fahrenheit"); if (fahrenheit > 51) digitalWrite (2, HIGH); if (fahrenheit < 48) digitalWrite (2, LOW); }*_
