is there like an easy way to create a gui for interacting with the ardu?
something without programming c. I know some visual basic.
I tell you what id imagine:
in excel i create buttons and a textfield, in a field i put in like a new timer setting. on pressing the button the timersetting gets changed. maybe that button+textfield gets translated into a simple serial command like (like in serial X + enter change variable X, then put in new value that just visualized in excel), but without the need of a terminal software.
is this possible, do you have maybe some sources?
Or r there better ways?
It doesnt have to be excel, just a userfriendly way to visualize the serial output with buttons and text fields for changing specific variables
in case this has been asked a 1000 times, how to i properly search the forum?
searching for gui results in 10000 hits with 99,9999% gui(de)
This is a commonly asked question. And I had been in a similar position a few months ago. I am glad to be able to say that I managed to make a GUI with very little effort using Visual Basics.
From my experience:
Communication with the Arduino requires programmed on-board code that can understand Serial data sent through the Port. For example, when the Arduino get 100 bytes from the Serial.read() do "this".
You would need to access some sort of library that allows you to send data through the Ports. Since you are familiar with visual basics, I recommend looking at this reference SerialPort Class (System.IO.Ports) | Microsoft Learn . Visual Basics 2010 Express contains the libraries needed to use the SerialPort Class.
Glad I helped. Unfortunately I do not have any example codes currently. There are however examples on the website I posted previously. I can basically tell you what you have to do:
You first have to define a new class of using SerialPort(), like so "Port = New SerialPort()". Then define the class definitions of Port, like "Port.PortName = SetPortName("COM3")", etc. Once you've defined what you need as shown in here SerialPort Constructor (System.IO.Ports) | Microsoft Learn , you want to open the port with "Port.Open()". And "Port.Close()" when your done.
In terms of the Arduino Code, I would look for "Arduino Serial Communication".
Stuff like this makes me want to create a instructional video (don't count on it, I am super lazy). However, you can toss me a PM if you have specific questions.
You'd have to do a bit more work to build the GUI, of course, but since the Arduino project basically grew up out of Processing (and Wiring), and many people have interfaced the Arduino to the PC using Processing (meaning there is plenty of example code) - it might be worth looking into.
Here you go ;o)
... snipped from an old visual basic project.
It's not usable without the wiring and circuit setup, but it may inspire you on single task .. like communicating and such. Without delving too much into details I faintly recall that the code drives 2 motors that positions an infrared rang-finder to measure 'distances to' an object (effectively taking a 3d picture).
Public Class Form1
Private mForward, mBackward, mSingleStep, mStop, mFullTurn As Boolean
Private mSteps, mWaitTime, mRepeats As Integer
Private mStepString As String = ""
Private mWaitString As String = ""
Private mRepeatString As String = ""
Private currentStepper As Integer = 0
' Private current
Private saveBool(3, 1) As Boolean
Private saveByteValues(3, 1) As Byte
Private startUpBypass As Boolean = True
Private mBytesToSend(4) As Byte ' 5 bytes
'Private recievedBytes(4) As Byte
Private code As Integer
Private value(3) As Byte
Private recepValue As Integer
Private dix As Collections.Generic.List(Of String)
Private RangeData As Collections.Generic.List(Of Single)
Private bool_Automate As Boolean = True
Private val As Single
Private Res_2 As Single
Private refTable As New Collections.Generic.List(Of Single)
Private binWriter As IO.BinaryWriter
Private data_Initiated As Boolean = False
'Private ev As ev
Public Sub New()
' This call is required by the designer.
InitializeComponent()
For Each p In My.Computer.Ports.SerialPortNames
If p = "COM15" Then
SerialPort1 = My.Computer.Ports.OpenSerialPort("COM15")
SerialPort1.Encoding = New System.Text.ASCIIEncoding
If Not SerialPort1.IsOpen = True Then
SerialPort1.Open()
End If
End If
Next
saveBool(0, 1) = True
saveBool(1, 1) = False
saveBool(2, 1) = True
saveBool(3, 1) = False
saveByteValues(0, 1) = 1 'Repeat
saveByteValues(1, 1) = 10 'wait
saveByteValues(2, 1) = 1
saveByteValues(3, 1) = 0
'0 - first stepper
'1 - second stepper
'2 - What's up Doc
'3 - Pause
'4 - Done
dix = New Collections.Generic.List(Of String)
dix.Add(" forward")
dix.Add(" backward")
dix.Add(" What's up Doc?") '2
dix.Add(" Pause")
dix.Add(" Done")
dix.Add(" Measure")
RangeData = New Collections.Generic.List(Of Single)
Button5.Enabled = False
'elBut = Button5
For x As Integer = 0 To 300 '- 0.002 * x
Val = CSng((108 * 113 / (x + 2000 / (x * x))))
refTable.Add(Val)
' Debug.Print(x.ToString & ") " & val.ToString)
Next
End Sub
Private Sub testRefTable(ByRef RangeOutput As Single)
' Res_1 = 0
Res_2 = 0
Dim slvd As Boolean = False
Dim slv As Boolean = True
Dim frac As Single
For x As Integer = 0 To 299
If slv Then
If refTable(x + 1) <= RangeOutput And RangeOutput < refTable(x) Then
frac = (RangeOutput - refTable(x)) / (refTable(x + 1) - refTable(x))
Me.Res_2 = x + frac ' (RangeOutput - refTable(x)) / (refTable(x + 1) - refTable(x)) 'interpolates
Debug.Print("res_2 " & Res_2.ToString)
Exit For
End If
End If
Next
'Stop
End Sub
'forward
'kode(0)
Private Sub RadioButton1_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton1.CheckedChanged
If RadioButton1.Checked Then
mForward = True
mBackward = False
End If
End Sub
'backwards
'kode(0)
Private Sub RadioButton2_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton2.CheckedChanged
If RadioButton2.Checked Then
mForward = False
mBackward = True
End If
End Sub
'mSingleStep
'kode(0)
Private Sub RadioButton3_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
If RadioButton3.Checked Then
mSingleStep = True
mFullTurn = False
End If
End Sub
'kode(0)
'full step
Private Sub RadioButton4_CheckedChanged_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton4.CheckedChanged
If RadioButton4.Checked Then
mSingleStep = False
mFullTurn = True
End If
End Sub
Private Function StringToByte(ByVal streng As String) As Byte
StringToByte = 0
Try
StringToByte = CType(streng, Byte)
Catch ex As Exception
Debug.Print("StringToNumber error : " & ex.Message)
StringToByte = 0
End Try
Return StringToByte
End Function
'number of step/turns
'kode(3 & 4)
Private Sub TextBox1_KeyUp(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles TextBox1.KeyUp
mStepString = TextBox1.Text
If e.KeyCode = Keys.Return Then
If Not mStepString = "" Then
mSteps = CType(mStepString, Integer)
'If 250 < mSteps Then
' mSteps = 250
'ElseIf mSteps < 0 Then
' mSteps = 0
'End If
End If
End If
End Sub
'number of repeat times
'kode(1)
Private Sub TextBox3_KeyUp(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles TextBox3.KeyUp
'Dim str As String
mRepeatString = TextBox3.Text
If Not mRepeatString = "" Then
mRepeats = CType(mRepeatString, Integer)
If 250 < mRepeats Then
mRepeats = 250
ElseIf mRepeats < 0 Then
mRepeats = 0
End If
'doTurns()
End If
End If
End Sub
'kode(2)
'rest-time
Private Sub TextBox4_KeyUp(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles TextBox4.KeyUp
mWaitString = TextBox4.Text
If Not mWaitString = "" Then
mWaitTime = CType(mWaitString, Integer)
If 250 < mWaitTime Then
mWaitTime = 250
ElseIf mWaitTime < 0 Then
mWaitTime = 0
End If
'doTurns()
End If
End If
End Sub
'mSteps
Private Sub TextBox1_LostFocus(ByVal sender As Object, ByVal e As System.EventArgs) Handles TextBox1.LostFocus
' mSteps = 250
' mSteps = 0
'End If
End If
End Sub
Private Function StepsToBytes(ByVal steps As Integer) As Byte()
Dim litl As Integer = steps
Dim big As Integer = 0
Dim res(1) As Byte
While 255 < litl
litl = litl - 256
big = big + 1
End While
res(0) = CType(litl, Byte)
res(1) = CType(big, Byte)
StepsToBytes = res
End Function
'mRepeats:
Private Sub TextBox3_LostFocus(ByVal sender As Object, ByVal e As System.EventArgs) Handles TextBox3.LostFocus
mRepeats = 250
mRepeats = 0
End If
mBytesToSend(1) = CType(mRepeats, Byte)
End If
End Sub
'mWaitTime
Private Sub TextBox4_LostFocus(ByVal sender As Object, ByVal e As System.EventArgs) Handles TextBox4.LostFocus
mWaitTime = 250
mWaitTime = 0
End If
mBytesToSend(2) = CType(mWaitTime, Byte)
End If
End Sub
Private Sub LoadStepper(ByVal first As Boolean)
End Sub
Private Sub ReadForm()
If RadioButton1.Checked Then 'forward
saveBool(0, currentStepper) = True
End If
If RadioButton2.Checked Then 'backwards
saveBool(1, currentStepper) = True
End If
If RadioButton3.Checked Then 'mSingleStep
saveBool(2, currentStepper) = True
End If
If RadioButton4.Checked Then 'full step
saveBool(3, currentStepper) = True
End If
' forw single
If RadioButton1.Checked And RadioButton3.Checked Then 'forward
mBytesToSend(0) = 0
' full
ElseIf RadioButton1.Checked And RadioButton4.Checked Then
mBytesToSend(0) = 2
' backw single
ElseIf RadioButton2.Checked And RadioButton3.Checked Then 'backwards
mBytesToSend(0) = 1
' backw full
ElseIf RadioButton2.Checked And RadioButton4.Checked Then 'fullStep
mBytesToSend(0) = 3
End If
mBytesToSend(1) = StringToByte(TextBox3.Text) ' CType(Repeat, Byte)
mBytesToSend(2) = StringToByte(TextBox4.Text) ' CType(mWaitTime, Byte)
saveByteValues(0, currentStepper) = mBytesToSend(1)
saveByteValues(1, currentStepper) = mBytesToSend(2)
Dim bts(1) As Byte
'TextBox1
Dim stps As Integer = CType(TextBox1.Text, Integer)
bts = Me.StepsToBytes(stps)
mBytesToSend(3) = bts(0) 'least significant
mBytesToSend(4) = bts(1) ' most significant
saveByteValues(2, currentStepper) = mBytesToSend(3)
saveByteValues(3, currentStepper) = mBytesToSend(4)
End Sub
Private Sub Send4Bytes()
'Stop
SerialPort1.Write(mBytesToSend, 0, 5)
End Sub
Private Sub SerialPort1_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
'Debug.Print("Data recieved")
Dim val1, val2 As Byte
'dataStandard:
'first byte is code (for the dix)
'next four is an integer (arduin long)
'Debug.Print("BytesToRead " & SerialPort1.BytesToRead)
Debug.Print(" ")
If SerialPort1.BytesToRead = 3 Then
code = SerialPort1.ReadByte
'For i As Integer = 0 To 1
val1 = CType(SerialPort1.ReadByte, Byte)
val2 = CType(SerialPort1.ReadByte, Byte)
' Next
If code = 5 Then
val = CSng(val1 + val2 * 256)
Me.testRefTable(val) 'Res_2 =
If data_Initiated Then
Me.DataWrite(Res_2)
End If
RangeData.Add(Res_2)
End If
'recepValue = System.BitConverter.ToInt16(val, 0)
If code = 4 Then
Beep()
Beep()
'UnDim()
End If
Debug.Print(dix(code))
'Debug.Print("value : " & (val1 + val2 * 256).ToString)
ElseIf 3 < SerialPort1.BytesToRead Then
SerialPort1.DiscardInBuffer()
'Stop
End If
End Sub
'Private Sub UnDim()
' Button5.Enabled = True
' Button2.Enabled = False
'End Sub
Private Sub SerialPort1_ErrorReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialErrorReceivedEventArgs) Handles SerialPort1.ErrorReceived
Debug.Print("error recieving")
End Sub
'stop
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
mBytesToSend(0) = 4
RangeData.Clear()
Send4Bytes()
End Sub
'datawriting
Private Sub StartDataWriter()
Dim Dinf As New IO.DirectoryInfo("H:/ScanFiles")
Dim nbr As Integer = Dinf.GetFiles.Count
Dim str As String = TextBox2.Text & (nbr + 1).ToString
Dim dataFileName As String = "H:/ScanFiles/" & str & ".scn"
Dim fs As IO.FileStream = New IO.FileStream(dataFileName, IO.FileMode.CreateNew) 'Or IO.FileMode.Open
binWriter = New IO.BinaryWriter(fs)
' dataMark = 0
End Sub
Private Sub DataWrite(ByVal value As Single)
'If binWriter.BaseStream.
binWriter.Write(value)
End Sub
'go
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
If bool_Automate Then
PrepareRoller()
' RangeData.Clear()
Else
Me.ReadForm()
End If
Send4Bytes()
End Sub
''reset as home
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
mBytesToSend(0) = 5
Me.Send4Bytes()
End Sub
''go home .
Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
mBytesToSend(0) = 6
Me.Send4Bytes()
End Sub
Private Sub RadioButton5_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RadioButton5.CheckedChanged
ReadForm()
If startUpBypass Then
startUpBypass = False
Else
If RadioButton5.Checked Then
currentStepper = 0
Else
currentStepper = 1
End If
RadioButton1.Checked = saveBool(0, currentStepper)
RadioButton2.Checked = saveBool(1, currentStepper)
RadioButton3.Checked = saveBool(2, currentStepper)
RadioButton4.Checked = saveBool(3, currentStepper)
TextBox3.Text = saveByteValues(0, currentStepper).ToString
TextBox4.Text = saveByteValues(1, currentStepper).ToString
Dim myI As Integer = saveByteValues(3, currentStepper) * 256 + saveByteValues(2, currentStepper)
TextBox1.Text = myI.ToString
End If
End Sub
Private Sub PrepareRoller()
mBytesToSend(0) = 0 'forward single
mBytesToSend(1) = 144 ' CType(Repeat, Byte)
mBytesToSend(2) = 10 ' CType(mWaitTime, Byte) ?????
Dim bts(1) As Byte
Dim stps As Integer = 1
End Sub
Private Sub PrepareElevator()
mBytesToSend(0) = 2 'forward full
mBytesToSend(1) = 10 ' CType(Repeat, Byte)
mBytesToSend(2) = 0 'waits 100 milliS
Dim bts(1) As Byte
Dim stps As Integer = 96
End Sub '
'Elevate
Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.Click
PrepareElevator()
Send4Bytes()
Button2.Enabled = True
End Sub
'automate
Private Sub CheckBox1_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckBox1.CheckedChanged
bool_Automate = CheckBox1.Checked
End Sub
'Initiate datacollection
Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.Click
binWriter.Close()
data_Initiated = False
Button6.Text = "Initiate"
Else
data_Initiated = True
'Button6.Enabled = False
StartDataWriter()
Button6.Text = "Stop collecting"
End If
End Sub
Protected Overrides Sub Finalize()
MyBase.Finalize()
binWriter.Close()
End Sub
End Class
'kode(0)
'kode(1)
'forward/backward & singlestep/full : kode(0)
' 0-4 implies start
'forward singlestep 0
'backwards singlestep 1
'forward fullStep 2
'backwards fullStep 3
'stop 4
'reset as home 5
'go home ... is calculated in arduino 6
'Internal to arduino:
'FirstStepper load variables 10
'second stepper load variables 11
'first stepper save variables 12
'second stepper save variables 13
' det kan forventes at når steper er stoppet
'at der kan ske et skift, altså at ved stop
'bliver variables saved. Ligeledes at et skift
'autoatically implies a stop
'skift stepper 14
'number of repeats: kode(1) byte
'wait 100 millis : kode(2) byte
'number of steps : kode(3) & kode(4) integer/Long
Hello..
I am making a project on electronic voting machine using RFID technology.
The programs are executed using the Arduino software.
I need to create a GUI for the whole project. Is it possible to create the GUI using LabVIEW or MATLAB interfacing it with the arduino program???
sorry for openning this old thread but it is left unanswered.
We have a solution for this. By using our solution you are
able to create UI for any electronic device. The UI is stored
in your device (arduino) and after you connect to your device
via bluetooth from your smartphone the arduino sends the description
of the UI to the smartphone (android). Now the android application
generates the UI and start sending/receiving string commands.
We have just launched this project and it is in BETA. So if you
have any questions/suggestions feel free to contact me.
We have also a new forum for this project: https://visiduino.io/sk/forum/
I am preparing one with USB connectivity and one with ethernet connection, this night I update the website with new gauge GPS and Map and the public also the first tutorial
