Ebyte LoRa E220-400T22D Connection Problem
Using 2 Lora E 220-400T22D and two ESP32-WROOM-32, I first tried fixed transmission, but it didn't work, then I tried transparent transmission, and now I'm trying the code I shared here, but it worked once, but I can't figure out why it doesn't work now. I am sharing my wiring and code. Can you help me? Have a nice day.
// ESP32_02_sendTransparentTransmission
 * EBYTE LoRa E220
 * send a transparent message, you must check that the transmitter and receiver have the same
 * CHANNEL ADDL and ADDH
 * Pay attention e220 support RSSI, if you want use that functionality you must enable RSSI on configuration
 * configuration.TRANSMISSION_MODE.enableRSSI = RSSI_ENABLED;
 * and uncomment #define ENABLE_RSSI true in this sketch
 * You must uncommend the correct constructor.
 * by Renzo Mischianti <https://www.mischianti.org>
 * https://www.mischianti.org
 * E220		  ----- WeMos D1 mini	----- esp32			----- Arduino Nano 33 IoT	----- Arduino MKR	----- Raspberry Pi Pico   ----- stm32               ----- ArduinoUNO
 * M0         ----- D7 (or GND) 	----- 19 (or GND) 	----- 4 (or GND) 			----- 2 (or GND) 	----- 10 (or GND)	      ----- PB0 (or GND)        ----- 7 Volt div (or GND)
 * M1         ----- D6 (or GND) 	----- 21 (or GND) 	----- 6 (or GND) 			----- 4 (or GND) 	----- 11 (or GND)	      ----- PB10 (or GND)       ----- 6 Volt div (or GND)
 * TX         ----- D3 (PullUP)		----- TX2 (PullUP)	----- TX1 (PullUP)			----- 14 (PullUP)	----- 8 (PullUP)	      ----- PA2 TX2 (PullUP)    ----- 4 (PullUP)
 * RX         ----- D4 (PullUP)		----- RX2 (PullUP)	----- RX1 (PullUP)			----- 13 (PullUP)	----- 9 (PullUP)	      ----- PA3 RX2 (PullUP)    ----- 5 Volt div (PullUP)
 * AUX        ----- D5 (PullUP)		----- 18  (PullUP)	----- 2  (PullUP)			----- 0  (PullUP)	----- 2  (PullUP)	      ----- PA0  (PullUP)       ----- 3 (PullUP)
 * VCC        ----- 3.3v/5v			----- 3.3v/5v		----- 3.3v/5v				----- 3.3v/5v		----- 3.3v/5v		      ----- 3.3v/5v             ----- 3.3v/5v
 * GND        ----- GND				----- GND			----- GND					----- GND			----- GND			      ----- GND                 ----- GND
#define FREQUENCY_433
#include "Arduino.h"
#include "LoRa_E220.h"
// ---------- esp8266 pins --------------
//LoRa_E220 e220ttl(RX, TX, AUX, M0, M1);  // Arduino RX <-- e220 TX, Arduino TX --> e220 RX
//LoRa_E220 e220ttl(D3, D4, D5, D7, D6); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX AUX M0 M1
//LoRa_E220 e220ttl(D2, D3); // Config without connect AUX and M0 M1
//#include <SoftwareSerial.h>
//SoftwareSerial mySerial(D2, D3); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX
//LoRa_E220 e220ttl(&mySerial, D5, D7, D6); // AUX M0 M1
// ---------- Arduino pins --------------
//LoRa_E220 e220ttl(4, 5, 3, 7, 6); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX AUX M0 M1
//LoRa_E220 e220ttl(4, 5); // Config without connect AUX and M0 M1
//SoftwareSerial mySerial(4, 5); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX
//LoRa_E220 e220ttl(&mySerial, 3, 7, 6); // AUX M0 M1
// ------------- Arduino Nano 33 IoT -------------
// LoRa_E220 e220ttl(&Serial1, 2, 4, 6); //  RX AUX M0 M1
// ------------- Arduino MKR WiFi 1010 -------------
// LoRa_E220 e220ttl(&Serial1, 0, 2, 4); //  RX AUX M0 M1
// ---------- esp32 pins --------------
// LoRa_E220 e220ttl(&Serial2, 15, 21, 19); //  RX AUX M0 M1
//  ESP32
#define RXD1 16
#define TXD1 17
LoRa_E220 e220ttl(&Serial2, 18, 21, 19);  //  RX AUX M0 M1
//LoRa_E220 e220ttl(&Serial2, 22, 4, 18, 21, 19, UART_BPS_RATE_9600); //  esp32 RX <-- e220 TX, esp32 TX --> e220 RX AUX M0 M1
// ---------- Raspberry PI Pico pins --------------
// LoRa_E220 e220ttl(&Serial2, 2, 10, 11); //  RX AUX M0 M1
// ---------------- STM32 --------------------
//HardwareSerial Serial2(USART2);   // PA3  (RX)  PA2  (TX)
//LoRa_E220 e220ttl(&Serial2, PA0, PB0, PB10); //  RX AUX M0 M1
// test structure
struct __attribute__((packed)) Struct1 {
  int16_t seq;  // sequence number
  float temperature;
  float humidity;
  float pressure;
Struct1 struct1 = { 0, 25.6f, 50.9f, 100.0f };  // test values
  Serial2.begin(9600, SERIAL_8N1, RXD1, TXD1);  // for LoRa E220  delay(500);
  // Startup all pins and UART
  e220ttl.begin();
  //  If you have ever change configuration you must restore It
  Serial.println("\nESP32 I'm going to send message!");
  // Send message
  //ResponseStatus rs = e220ttl.sendMessage("Hello, world?");
  // transmit structure and print vales transmitted
  ResponseStatus rs = e220ttl.sendMessage(&struct1, sizeof(struct1));
  Serial.print("temperature ");
  Serial.println(struct1.temperature);
  Serial.print("humidity ");
  Serial.println(struct1.humidity);
  Serial.print("pressure ");
  Serial.println(struct1.pressure);
  // Check If there is some problem of succesfully send
  Serial.println(rs.getResponseDescription());
    // If something available
    if (e220ttl.available() > 1) {
      // read the structure message
#ifdef ENABLE_RSSI
      ResponseStructContainer rc = e220ttl.receiveMessageRSSI(sizeof(Struct1));
#else
      ResponseStructContainer rc = e220ttl.receiveMessage(sizeof(Struct1));
#endif
      // Is something goes wrong print error
      if (rc.status.code != 1) {
        Serial.println(rc.status.getResponseDescription());
        // Print the data received
        Serial.print("ResponseDescription ");
        Serial.println(((Struct1*)rc.data)->temperature);
        Serial.println(((Struct1*)rc.data)->humidity);
        Serial.println(((Struct1*)rc.data)->pressure);
#ifdef ENABLE_RSSI
        Serial.print("RSSI: ");
        Serial.println(rc.rssi, DEC);
#endif
    if (Serial.available()) {
      String input = Serial.readString();
      e220ttl.sendMessage(input);
