EEprom corruption on Arduino UNO
Hey guys,
Here on the forum there are several cases of eeprom memory corruption, mainly in the Arduino Uno (atmega328p).
In some cases, random values ​​or ff are displayed in some eeprom addresses.
I would like a comprehensive discussion of these cases.
First of all, has anyone ever had this problem and how did they solve it?
And what causes this problem? Is it in the power supply, electrical noise?
And what can be done at the software and hardware level to avoid this problem?
And the BOD should be disabled or enabled at what voltage level to reduce this problem?
Please provide links to reports of this problem on the forum
Most reported problems with EEPROM turn out to be misunderstandings of how many bytes each data type takes to store and/or use of the wrong function to store data longer than a single byte
https://forum.arduino.cc/t/eeprom-strange-error/1131883
It was a shame that the full sketch was not posted in that case and there was very little detail of the electrical environment so all bets are off
Hi, @aless81
Your reference is to a Mega, different animal to a UNO.
Why do you want to discuss it?
Do you have a project in mind?
Is it do to with this thread?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
I can only tell you about the software side
  1. Store a CRC32 in last 4 bytes of EEPROM; calculate it over length() - 4 bytes. Verify each time that you want to read a variable.
  2. Store data 3 times and use best-of-three; if at least 2 variables of the 3 match, use that one.
