EEPROM Read(I think) error
Hello, I am making this project to expand on a school project, and I was having some problems with it switching modes. I want it to be able to switch modes between a data bank for different things, and the other is a small game box. I have removed some code to simplify it, so apologies if you see any integers or Booleans you cant find. this code does compile on my computer, and my error is that when I try to get it to switch modes, i am using EEPROM, it does not seem to read it in this sketch for some reason. it does show the EEPROM value at 4, the address I am using as 1, as it should, but the program does not work. Thank you for any help.
int versions;
bool bank = false;
int banks;
// Data Bank Code
const char* User1 = "DroneMaster278";
const char* User1pass = "31.5x2=Awesome!";
unsigned long lockstart = 0;
unsigned long lockoutend;
String lastcommand;
char CurrentUser;
int value1;
int left = 3;
int tries = 3;
int minute = 0;
int fails;
int t;
bool Lockdown;
bool lock2 = false;
bool ask = true;
void (*resetFunc)(void) = 0;
bool serialconnected = false;
void Version() {
  if (serialconnected == true) {
    Serial.print("Version ");
    Serial.print(1.);
    Serial.println(versions);
LiquidCrystal_I2C lcd(0x27, 16, 2);
#include <EEPROM.h>
  EEPROM Key
  100 = Game 1 High Score
  101 = Game 2 High Score
  102 = Game 3 High Score
  104 = Lockdown 1=on 2=off.
  103 = Refresh Rate
  105 = Game 1 Seconds
  106 = Game 2 Seconds
  107 = Game 3 Seconds
  108 = Game 1 Minutes
  109 = Game 2 Minutes
  110 = Game 3 Minutes
  111 = Sound 1 = On 2 = Off
  112 = Lights 1 = On 2 = Off
  113 = Version
  114 = developer mode 1=on 2=off
  115 = sensitivity
int EEPROMLIGHTS = 112;
int EEPROMSOUND = 111;
int minutes1 = 2;
int seconds1 = 59;
int minutes2 = 2;
int seconds2 = 59;
int minutes3 = 2;
int seconds3 = 59;
int rrate = 5;
int refreshrate = 300;
int EEPROMG1HS = 100;
int EEPROMG2HS = 101;
int EEPROMG3HS = 102;
int EEPROMLockdown = 104;
int EEPROMRR = 103;
int EEPROMG1S = 105;
int EEPROMG2S = 106;
int EEPROMG3S = 107;
int EEPROMG1M = 108;
int EEPROMG2M = 109;
int EEPROMG3M = 110;
int done = 0;
int finished = 0;
int steps = 16;
int g3highscore = 0;
int g2highscore = 0;
int g1highscore = 0;
int launchint5;
int launchint51;
int launchint52;
int int0;
int triesleft = 2;
// Custom Characters
byte customChar[8] = {
  0b00000,
  0b00000,
  0b11111,
  0b11111,
  0b11111,
  0b11111,
  0b11111,
  0b11111,
// libraries
#define resetpin A1
#define greenbutton A15
#define redbutton A14
#define yellowbutton A13
#define joy1B A12
#define joy1X A11
#define joy1Y A10
#define joy2B A9
#define joy2X A8
#define joy2Y A7
#define flicker 11
#define rotaryB 10
#define rotarybutton 10
#define rotary2 9
#define encoderPinA 9
#define rotary1 8
#define encoderPinB 8
#define buzzer 6
#define touch2 5
#define touch1 4
#define touch3 3
#define led1 53
#define led2 51
#define led3 49
#define led4 47
#define led5 45
#define led6 43
#define led7 41
#define led8 39
#define led9 37
#define led10 35
#define greenB A15
#define yellowB A13
#define redB A14
String command;
String lastCommand;
int game1hs;
int int10;
int int11;
int int12;
int int13;
int int14;
int sense;
bool nosound;
bool Light = false;
bool developermode = false;
// sensor states
int joy2Bs;
int touch1s;
int touch2s;
int touch3s;
int joy1Bs;
int twisters;
int greenBs;
int yellowBs;
int redBs;
int rotaryBs;
int flickers;
int joy1Xs;
int joy1Ys;
int joy2Xs;
int joy2Ys;
int rotary1s;
int rotary2s;
int greenbs;
int yellowbs;
int redbs;
int joy1bs;
int joy2bs;
const char* game1words[24] = { "    Touch It", "    Twist It", "    Click It", "Pres the Joystick", "    Flick It",
                               "Pres the Joystick", "    Touch It", "    Twist It", "Pres the Joystick", "    Flick It",
                               "    Click It", "    Flick It", "Pres the Joystick", "    Touch It",
                               "Pres the Joystick", "    Flick It", "    Click It", "    Touch It",
                               "    Flick It", "    Click It", "    Twist It", "    Click It", "    Flick It",
                               "    Twist It" };
const char* GameSettings[5] = { "High Scores"
                                "   Time"
                                "  Sounds"
                                "  Lights"
                                "   Rules" };
int rlights[30]{
  led8, led2, led4, led6, led7, led8, led5, led3, led1, led2, led1, led10, led9, led4, led10,
  led4, led3, led2, led10, led9, led6, led7, led6, led3, led9, led7, led8, led5, led1, led5
int current1[125]{ 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17,
                   16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6,
                   5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8,
                   7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2,
                   1, 0, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17 };
int current2[125]{ 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17, 16, 15,
                   14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6,
                   5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17,
                   17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17 };
int current3[125]{ 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17, 17, 16, 15, 14,
                   13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1,
                   0, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 16,
                   15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0, 17, 17, 17, 17, 17, 17, 17, 17, 17, 17 };
void timereset() {
  seconds1 = EEPROM.read(EEPROMG1S);
  seconds2 = EEPROM.read(EEPROMG2S);
  seconds3 = EEPROM.read(EEPROMG3S);
  minutes1 = EEPROM.read(EEPROMG1M);
  minutes2 = EEPROM.read(EEPROMG2M);
  minutes3 = EEPROM.read(EEPROMG3M);
void sentcommands() {
  Serial.print("Received: ");
  Serial.println(command);
volatile int encoderPosition = 0;
volatile bool encoderTwisted = false;
void percentagefinished() {
  done = done + 1;
  lcd.clear();
  finished = 100 / steps * done;
  if (developermode == true) {
    lcd.print(finished);
    lcd.print("%");
      Serial.print(finished);
      Serial.println("%");
  delay(random(100, 300));
  if (finished > 10) {
    lcd.backlight();
    digitalWrite(led1, HIGH);
  if (finished > 20) {
    digitalWrite(led2, HIGH);
  if (finished > 30) {
    digitalWrite(led3, HIGH);
  if (finished > 40) {
    digitalWrite(led4, HIGH);
  if (finished > 50) {
    digitalWrite(led5, HIGH);
  if (finished > 60) {
    digitalWrite(led6, HIGH);
  if (finished > 70) {
    digitalWrite(led7, HIGH);
  if (finished > 80) {
    digitalWrite(led8, HIGH);
  if (finished > 87) {
    digitalWrite(led9, HIGH);
  if (finished > 95) {
    digitalWrite(led10, HIGH);
  banks = EEPROM.read(4);
  delay(50);
  if (banks == 1) {
    Serial.println("Data Bank Mode Entered");
    bank = false;
    Serial.println("hi");
  } else if (bank == false) {
    banks = true;
    Serial.println("bye");
    lcd.clear();
    pinMode(touch1, INPUT_PULLUP);
    pinMode(touch2, INPUT_PULLUP);
    pinMode(buzzer, OUTPUT);
    pinMode(joy1X, INPUT);
    pinMode(joy1Y, INPUT);
    pinMode(joy2X, INPUT);
    pinMode(rotaryB, INPUT_PULLUP);
    pinMode(resetpin, OUTPUT);
    pinMode(joy2Y, INPUT);
    pinMode(rotary1, INPUT_PULLUP);
    pinMode(flicker, INPUT);
    pinMode(rotarybutton, INPUT_PULLUP);
    pinMode(rotary2, INPUT_PULLUP);
    pinMode(joy1B, INPUT_PULLUP);
    pinMode(joy2B, INPUT_PULLUP);
    pinMode(greenbutton, INPUT_PULLUP);
    pinMode(redbutton, INPUT_PULLUP);
    pinMode(yellowbutton, INPUT_PULLUP);
    pinMode(touch3, INPUT_PULLUP);
    pinMode(led1, OUTPUT);
    pinMode(led2, OUTPUT);
    pinMode(led3, OUTPUT);
    pinMode(led4, OUTPUT);
    pinMode(led5, OUTPUT);
    pinMode(led6, OUTPUT);
    pinMode(led7, OUTPUT);
    pinMode(led8, OUTPUT);
    pinMode(led9, OUTPUT);
    pinMode(led10, OUTPUT);
    pinMode(greenB, INPUT_PULLUP);
    pinMode(redB, INPUT_PULLUP);
    pinMode(yellowB, INPUT_PULLUP);
    percentagefinished();
    int13 = EEPROM.read(114);
  if (bank == true) {
    value1 = EEPROM.read(1);
    left = EEPROM.read(2);
    fails = EEPROM.read(3);
    lcd.begin(16, 2);
    lcd.clear();
    if (int13 == 1) {
      developermode = true;
    } else developermode = false;
    int14 = EEPROM.read(115);
    sense = int14;
    digitalWrite(resetpin, HIGH);
    lcd.createChar(0, customChar);
    int12 = EEPROM.read(113);
    versions = int12 + 1;
    attachInterrupt(digitalPinToInterrupt(encoderPinA), handleEncoderInterrupt, CHANGE);
    EEPROM.update(113, versions);
    lcd.init();
      Serial.println("Booting Up");
    int10 = EEPROM.read(111);
    if (int10 == 1) {
      nosound = true;
    } else nosound = false;
    int11 = EEPROM.read(112);
    if (int11 == 2) {
      Light = false;
    } else Light = true;
    //Serial.println("bool4 question");
    // pinmodes
    // senor state readers
    touch1s = digitalRead(touch1);
    touch2s = digitalRead(touch2);
    touch3s = digitalRead(touch3);
    joy1Bs = digitalRead(joy1B);
    joy2Bs = digitalRead(joy2B);
    greenBs = digitalRead(greenB);
    rotaryBs = digitalRead(rotaryB);
    redBs = digitalRead(redB);
    yellowBs = digitalRead(yellowB);
    rotaryBs = digitalRead(rotarybutton);
    joy2Xs = analogRead(joy2X);
    joy2Ys = analogRead(joy2Y);
    joy1Xs = analogRead(joy1X);
    joy1Ys = analogRead(joy1Y);
    // screen initialization
    rrate = EEPROM.read(EEPROMRR);
    refreshrate = 1000 / rrate;
    // rrate = refreshrate
    g3highscore = EEPROM.read(EEPROMG3HS);
    g2highscore = EEPROM.read(EEPROMG2HS);
    g1highscore = EEPROM.read(EEPROMG1HS);
    timereset();
    Version();
  if (bank == true) {
    if (value1 == 2) {
      Lockdown = true;
      Serial.print("Please Try Again In ");
      Serial.print(left);
      Serial.println(" Minutes.");
    if (left == 1) {
      Serial.println("SODK");
      Lockdown = true;
    if (Lockdown == false) {
      Serial.println("Please Enter Username");
    if (fails == 1) {
      t = 1;
    if (fails == 2) {
      t = 3;
    if (fails == 3) {
      t = 5;
    if (fails == 4) {
      t = 10;
    if (fails == 5) {
      t = 15;
    if (fails == 6) {
      t = 30;
    if (fails == 7) {
      t = 60;
    if (Lockdown == true) {
      Serial.print("Please Wait ");
      Serial.print(fails);
    delay(750);
      serialconnected = true;
    } else Serial.println("Please Type 'Activate Serial Feedback' to Activate Serial Feedback");
void blankline(int int1) {
  for (int int2 = 0; int2 < int1; int2 = int2 + 1) {
      Serial.println("0");
void handleEncoderInterrupt() {
  int pinAState = digitalRead(encoderPinA);
  int pinBState = digitalRead(encoderPinB);
  if (pinAState == pinBState) {
    encoderPosition++;
    encoderPosition--;
  encoderTwisted = true;
void allon() {
  if (Light == true) {
void alloff() {
    digitalWrite(led1, LOW);
    digitalWrite(led2, LOW);
    digitalWrite(led3, LOW);
    digitalWrite(led4, LOW);
    digitalWrite(led5, LOW);
    digitalWrite(led6, LOW);
    digitalWrite(led7, LOW);
    digitalWrite(led8, LOW);
    digitalWrite(led9, LOW);
    digitalWrite(led10, LOW);
void sensorcheck() {
  yellowbs = digitalRead(yellowB);
  twisters = digitalRead(rotaryB);
  rotary2s = digitalRead(rotary2);
  rotary1s = digitalRead(rotary1);
  redbs = digitalRead(redB);
  joy2bs = digitalRead(joy2B);
  // back();
void lickes() {
  allon();
  if (nosound == false) {
    tone(buzzer, 500, 200);
  delay(200);
  alloff();
int cor7 = 0;
int g1 = 4;
int c2 = 2;
int c = 8;
int epromg1hs = 1;
int epromg2hs = 2;
int epromg3hs = 3;
int counter3 = 0;
int counter2 = 0;
int refreshcounter = 0;
int something;
int rint = 1;
int int3 = 2;
int game = 2;
int cor = 7;
int cor1 = 1;
int cor11 = 4;
int cor2 = 3;
int cor3 = 0;
int cor4 = 0;
int cor41 = 5;
int cor5 = 1;
int cor51 = 0;
int cor52 = 8;
int cor6 = 1;  ///////////////////////////////////////////////////////////////////////////////////////////////////////////////
int cor9 = 1;
int cor91 = 3;
int int1 = 12;
int int7 = 5;
int int6 = 1;
int cor61 = 1;
int int5 = 16;
int int51 = 14;
int int52 = 12;
int int8 = 0;
int game2delay = refreshrate;
int counter = 1;
int game1score = 0;
int cor4g1 = 0;
int g3score;
int game3totalfound = 0;
int refresh = 1000 / refreshrate;
int intrefresh = refreshrate / 1;
int scounter;
bool confirmreset = false;
bool game2over = false;
bool game2s = false;
bool G1HS = false;
bool G2HS = false;
bool G3HS = false;
bool lockdown = false;
bool bool4 = false;
bool backS = false;
bool SaveS = false;
bool newscore = false;
bool refreshnow = false;
bool startup = true;
bool gameselection = false;
bool repeatonce = true;
bool gameover = false;
bool gaming = false;
bool clicked = false;
bool countdown = false;
bool proceedgame1 = false;
bool putina0 = false;
bool first = true;
bool game1 = false;
bool game2 = false;
bool game3 = false;
bool notimer = false;
bool timer = false;
bool settings = false;
bool refreshchange = false;
bool highscores = false;
bool gamesorsettings = false;
bool activategame1 = false;
bool activategame2 = false;
bool activategame3 = false;
bool f1 = true;
bool f2 = true;
bool f3 = true;
bool f4 = true;
bool X1 = true;
bool X2 = false;
bool backRR = false;
bool SaveRR = false;
bool SOUND = false;
bool LIGHTS = false;
bool TIME = false;
bool G1T = false;
bool G2T = false;
bool G3T = false;
void gameboolsreset() {
  bool f1 = false;
  bool f2 = false;
  bool f3 = false;
  bool f4 = false;
void allfalse() {
  backS = false;
  SaveS = false;
  G3T = false;
  G2T = false;
  G1T = false;
  TIME = false;
  game2s = false;
  game2over = false;
  LIGHTS = false;
  SOUND = false;
  G1HS = false;
  G2HS = false;
  G3HS = false;
  backRR = false;
  SaveRR = false;
  bool4 = false;
  newscore = false;
  refreshnow = false;
  repeatonce = false;
  gameover = false;
  gaming = false;
  clicked = false;
  countdown = false;
  putina0 = false;
  first = true;
  game1 = false;
  game2 = false;
  game3 = false;
  notimer = false;
  timer = false;
  settings = false;
  highscores = false;
  startup = false;
  startup = false;
  repeatonce = true;
  gameover = false;
  gaming = false;
  clicked = false;
  countdown = false;
  putina0 = false;
  first = true;
  game1 = false;
  game2 = false;
  game3 = false;
  notimer = false;
  timer = false;
  settings = false;
  highscores = false;
void refreshb() {
  delay(refreshrate);
  lcd.clear();
void back() {
  sensorcheck();
  if ((joy1Bs == LOW && joy2Bs == LOW) || ((redbs == LOW || yellowbs == LOW || greenbs == HIGH || touch1s == HIGH || touch2s == HIGH || touch3s == HIGH) && (timer == false && notimer == false && gaming == false)) && gamesorsettings == false) {
    allon();
    delay(200);
    allfalse();
    gamesorsettings = true;
    lcd.clear();
      Serial.println("Returned to main screen");
    alloff();
  unsigned long currentTime = millis();
  // start screen
    if (startup == true) {
      alloff();
      lcd.setCursor(0, 0);
      lcd.print("Press Any Button");
      lcd.setCursor(0, 1);
      lcd.print("    To Start      ");
      sensorcheck();
      if (repeatonce == true) {
          Serial.println("Start Screen");
        repeatonce = false;
      if (touch1s == HIGH || touch2s == HIGH || touch3s == HIGH || joy1Bs == LOW || joy2Bs == LOW || redBs == LOW || yellowBs == LOW || greenBs == LOW || rotaryBs == HIGH || rotaryBs == HIGH) {
        lickes();
          Serial.println("Choosing Game or Settings");
        lcd.clear();
        delay(refresh);
        startup = false;
        repeatonce = true;
    // selection screen
    if (gamesorsettings == true) {
      alloff();
      back();
      lcd.clear();
      lcd.setCursor(1, 0);
      lcd.print("Mode Selection");
      lcd.setCursor(1, 1);
      lcd.print("Games");
      lcd.setCursor(9, 1);
      lcd.print("Settng");
      lcd.setCursor(cor2 - 4, 1);
      lcd.print(">");
      lcd.setCursor(cor2 + 3, 1);
      lcd.print("<");
      sensorcheck();
      // movement checks
      if (joy1Ys < 400 || joy2Ys < 400) {
        cor2 = cor2 + 9;
      if (joy1Ys > 700 || joy2Ys > 700) {
        cor2 = cor2 - 9;
      if (cor2 > 14) {
        cor2 = 12;
      if (cor2 < 2) {
        cor2 = 3;
      //selector
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor2 == 3) {
        allfalse();
        gameselection = true;
        lcd.clear();
          Serial.println("Games Chosen");
        lickes();
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor2 == 12) {
        allfalse();
        settings = true;
        lcd.clear();
          Serial.println("Settings Chosen");
        lickes();
      back();
      refreshb();
    // settings
    if (settings == true) {
      refreshb();
      back();
      sensorcheck();
      if ((joy1Ys < 400 || joy2Xs < 400) && (cor3 == 0)) {
        cor7 = cor7 - 1;
      } else if (joy1Ys > 700 || joy2Xs > 700) {
        cor3 = cor3 + 1;
      if ((joy1Ys > 700 || joy2Xs > 700) && cor3 > 0) {
        cor7 = cor7 + 1;
      } else if (joy1Ys < 400 || joy2Xs < 400) {
        cor3 = cor3 - 1;
      if (cor3 == 1 && (joy1Ys < 400 || joy2Xs < 400)) {
        cor7 = 1;
      if (cor3 > 4) {
        cor3 = 4;
      if (cor3 < 0) {
        cor3 = 0;
      if (cor7 > 1) {
        cor7 = 1;
      if (cor7 < 0) {
        cor7 = 0;
      if (cor3 == 0 || cor3 == 1) {
        lcd.setCursor(2, 0);
        lcd.print("High Scores");
        lcd.setCursor(2, 4);
        lcd.print("   Sound");
      } else if (cor3 == 2) {
        lcd.clear();
        lcd.setCursor(2, 1);
        lcd.print("  Refresh");
      } else if (cor3 == 3) {
        lcd.clear();
        lcd.print("  Lights");
      } else if (cor3 == 4) {
        lcd.clear();
        lcd.print("  Reset");
      lcd.setCursor(0, cor7);
      lcd.print("->");
      lcd.setCursor(14, cor7);
      lcd.print("<-");
      // selection phase
      sensorcheck();
      if ((joy1Bs == LOW || joy2Bs == LOW) && ((cor7 == 0 && cor3 == 3) || (cor7 == 1 && cor3 == 2))) {
        delay(250);
        allfalse();
        refreshchange = true;
        lcd.clear();
          Serial.println("Changing Refresh Settings");
        lickes();
      if ((joy1Bs == LOW || joy2Bs == LOW) && (cor3 == 0 || cor3 == 1) && cor7 == 0) {
        delay(250);
        allfalse();
        highscores = true;
        lcd.clear();
          Serial.println("Checking High Scores");
        lickes();
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor3 == 4 && cor7 == 1) {
        delay(250);
        allfalse();
        TIME = true;
        lcd.clear();
          Serial.println("Possible Reset");
        lickes();
      if ((joy1Bs == LOW || joy2Bs == LOW) && ((cor3 == 4 && cor7 == 0) || (cor3 == 3 && cor7 == 1))) {
        delay(250);
        allfalse();
        LIGHTS = true;
        lcd.clear();
          Serial.println("Changing Light Settings");
        lickes();
      if ((joy1Bs == LOW || joy2Bs == LOW) && (((cor3 == 0 || cor3 == 1) && cor7 == 1) || (cor3 == 3 && cor7 == 0))) {
        delay(250);
        allfalse();
        lcd.clear();
        SOUND = true;
          Serial.println("Changing Sound Settings");
        lickes();
    if (TIME == true) {
      back();
      refreshb();
      sensorcheck();
      lcd.setCursor(4, 0);
      lcd.print("Reset?");
      lcd.print("Yes");
      lcd.setCursor(12, 1);
      lcd.print("No");
      sensorcheck();
      lcd.setCursor(cor1, 1);
      lcd.print(">");
      lcd.setCursor(cor1 + cor11, 1);
      lcd.print("<");
      if (cor1 == 1 && (joy1Bs == LOW || joy2Bs == LOW)) {
        lickes();
        lcd.clear();
        Serial.print("SAVING");
        lcd.print("SAVING");
        for (int i = 0; i < random(3, 15); i++) {
          delay(300);
          lcd.print(".");
          Serial.print(".");
        delay(random(1, 500));
        lcd.clear();
        lcd.print("RESETING");
        Serial.print("RESETING");
        delay(400);
        resetFunc();
      if (cor1 == 11 && (joy1Bs == LOW || joy2Bs == LOW)) {
        lickes();
        allfalse();
        TIME = false;
        settings = true;
        cor1 = 11;
        cor11 = 3;
        cor1 = 1;
        cor11 = 4;
      //cor1
    if (LIGHTS == true) {
      refreshb();
      lcd.setCursor(5, 0);
      lcd.print("Lights");
      lcd.print("ON");
      lcd.setCursor(11, 1);
      lcd.print("OFF");
      lcd.setCursor(cor9, 1);
      lcd.print(">");
      lcd.setCursor(cor9 + cor91, 1);
      lcd.print("<");
      sensorcheck();
      if (cor9 == 1 && (joy1Bs == LOW || joy2Bs == LOW)) {
        Light = true;
        allfalse();
        settings = true;
        EEPROM.update(112, 1);
      if (cor9 == 10 && (joy1Bs == LOW || joy2Bs == LOW)) {
        Light = false;
        allfalse();
        settings = true;
        EEPROM.update(112, 2);
        cor9 = 10;
        cor91 = 4;
        cor9 = 1;
        cor91 = 3;
    if (SOUND == true) {
      refreshb();
      lcd.print("SOUND");  /////////////////////////////////////////////////////////////////////////////////////////////////////////////
      lcd.print("ON");
      lcd.print("OFF");
      lcd.print(">");
      lcd.print("<");
      sensorcheck();
        nosound = true;
        allfalse();
        settings = true;
        EEPROM.update(111, 1);
        nosound = false;
        allfalse();
        settings = true;
        EEPROM.update(111, 2);
        cor9 = 10;
        cor91 = 4;
        cor9 = 1;
        cor91 = 3;
    if (refreshchange == true) {
      back();
      refreshb();
      lcd.print(rrate - 1);
      lcd.setCursor(13, 0);
      lcd.print(rrate + 1);
      lcd.print("Save");
      lcd.setCursor(10, 1);
      lcd.print("Back");
      lcd.setCursor(7, 0);
      lcd.print(rrate);
      sensorcheck();
      if (X1 == true) {
          rrate = rrate + 1;
          rrate = rrate - 1;
        lcd.setCursor(6, 0);
        lcd.print("[");
        lcd.setCursor(c, 0);
        lcd.print("]");
      if (X2 == true) {
          cor5 = 9;
          cor5 = 1;
        lcd.setCursor(cor5, 1);
        lcd.print(">");
        lcd.setCursor(cor5 + 5, 1);
        lcd.print("< ");
      if ((joy1Bs == LOW || joy2Bs == LOW) && X2 == true && cor5 == 9) {
        lickes();
        backRR = true;
      if ((joy1Bs == LOW || joy2Bs == LOW) && X2 == true && cor5 == 1) {
        lickes();
        SaveRR = true;
        allon();
      if (joy1Xs < 400 || joy2Xs < 400) {
        X1 = true;
        X2 = false;
      if (joy1Xs > 700 || joy2Xs > 700) {
        X1 = false;
        X2 = true;
      if (rrate < 1) {
        rrate = 1;
      if (rrate > 9) {
        c = 9;
        c2 = 1;
      } else c = 8;
      c2 = 2;
      back();
    if (backRR == true) {
      settings = true;
      backRR = false;
      alloff();
    if (SaveRR == true) {
      refreshb();
      if (rrate > 9) {
        c2 = 1;
      } else c2 = 2;
      lcd.setCursor(c2, 0);
      lcd.print(rrate);
      lcd.print(" Per Second ? ");
      lcd.print("Yes");
      lcd.print("No");
      lcd.setCursor(cor6, 1);
      lcd.print(" > ");
      lcd.setCursor(cor6 + g1, 1);
      lcd.print(" < ");
      sensorcheck();
        g1 = 3;
        cor6 = 11;
        g1 = 4;
        cor6 = 1;
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor6 == 11) {
        SaveRR = false;
        settings = true;
          Serial.println("Action Canceled");
        alloff();
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor6 == 1) {
        SaveRR = false;
        lcd.clear();
        lcd.print("Saving");
        delay(random(250, 750));
        lcd.clear();
        X1 = true;
        X2 = false;
          Serial.print("Refresh Rate Saved As ");
          Serial.print(rrate);
          Serial.println(" Per Second");
        alloff();
        EEPROM.update(EEPROMRR, rrate);
    if (highscores == true) {
      back();
      refreshb();
      lcd.print("1");
      lcd.setCursor(7, 1);
      lcd.print("2");
      lcd.print("3");
      lcd.print("[");
      lcd.setCursor(cor6 + 2, 1);
      lcd.print("]");
      sensorcheck();
        cor6 = cor6 + 5;
        cor6 = cor6 - 5;
      if (cor6 > 12) {
        cor6 = 11;
      if (cor6 < 3) {
        cor6 = 1;
      sensorcheck();
        highscores = false;
        allfalse();
        G1HS = true;
          Serial.println("G1HS");
        lickes();
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor6 == 6) {
        highscores = false;
        allfalse();
        G2HS = true;
          Serial.println("G2HS");
        lickes();
        highscores = false;
        allfalse();
        G3HS = true;
          Serial.println("G3HS");
        lickes();
      back();
    if (G3HS == true) {
      back();
      refreshb();
      lcd.print("Game 3 Hih Score");
      lcd.print(g3highscore);
    if (G2HS == true) {
      back();
      refreshb();
      lcd.print("Game 2 Hih Score");
      lcd.print(g2highscore);
    if (G1HS == true) {
      back();
      refreshb();
      lcd.print("Game 1 Hih Score");
      lcd.print(g1highscore);
    // game selection
    if (gameselection == true) {
      sensorcheck();
      refreshb();  ///////////////////////////////////////////////////////////////////////////////////////////////
      back();
        Serial.println("GAME SCREEN");
        repeatonce = false;
      lcd.print(" Game Selection");
      lcd.print("1");
      lcd.print("2");
      lcd.print("3");
      lcd.setCursor(cor - 1, 1);
      lcd.print(">");
      lcd.setCursor(cor + 1, 1);
      lcd.print("<");
        cor = cor + 5;
        cor = cor - 5;
      if (cor > 13) {
        cor = 12;
      if (cor < 3) {
        cor = 2;
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor == 2) {
        allfalse();
        lickes();
        activategame1 = true;
        lcd.clear();
        repeatonce = true;
        Serial.println("Game 1 Chosen");
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor == 7) {
        allfalse();
        lickes();
        activategame2 = true;
        lcd.clear();
        repeatonce = true;
        Serial.println("Game 2 Chosen");
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor == 12) {
        allfalse();
        lickes();
        activategame3 = true;
        lcd.clear();
        repeatonce = true;
        Serial.println("Game 3 Chosen");
    if (activategame1 == true) {
      allfalse();
      back();
      refreshb();
      lcd.print("Game 1? ");
      lcd.print("Yes");
      lcd.print("No");
      lcd.setCursor(cor4g1, 1);
      lcd.print("->");
      lcd.setCursor(cor4g1 + cor41, 1);
      lcd.print("<-");
      back();
      delay(300);
      sensorcheck();
      // movement checks
        cor41 = 4;
        cor4g1 = 9;
        cor41 = 5;
        cor4g1 = 0;
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor4g1 == 0) {
        lickes();
        proceedgame1 = true;
        countdown = true;
        lcd.clear();
        timereset();
        delay(300);
          Serial.println("Choice Confirmed as Yes");
          Serial.println("Starting Countdown to Game 1");
        repeatonce = true;
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor4g1 == 9) {
        lickes();
        lcd.clear();
        timereset();
        delay(300);
        repeatonce = true;
          Serial.println("Choice Confirmed as No");
          Serial.println("Decided Aginst Game 1 Returning to Main Menu");
    if (proceedgame1 == true) {
      back();
      if (countdown == true) {
        back();
        lcd.clear();
        lcd.print("     Game 1");
        back();
        lcd.print("3");
          tone(buzzer, 750, 450);
        delay(450);
        delay(550);
        lcd.clear();
        back();
        lcd.print("2");
        delay(450);
        delay(550);
        lcd.clear();
        back();
        lcd.print("1");
        delay(450);
        delay(550);
        lcd.clear();
        back();
        lcd.setCursor(6, 1);
        lcd.print("GO!");
          tone(buzzer, 900, 900);
        allon();
        delay(900);
        alloff();
        delay(100);
        clicked = true;
        gaming = true;
        countdown = false;
          Serial.println("Game 1 Countdown Finished");
        back();
      if (gaming == true) {
        back();
        lcd.clear();
        something = something + 1;
        lcd.print(minutes1);
        lcd.print(" : ");
        if (bool4 == true) {
          lcd.print("0");
        lcd.setCursor(int1, 0);
        lcd.print(seconds1);
        lcd.setCursor(8, 0);
        lcd.print("Score : ");
        lcd.print(game1score);
        lcd.print(game1words[rint]);
        counter3 = counter3 + 1;
        counter2 = counter2 + 1;
        if (counter2 > 4) {
          counter2 = 0;
          seconds1 = seconds1 - 1;
            tone(buzzer, 400, 100);
          delay(100);
        if (counter3 > 10) {
          counter3 = 0;
          rint = random(1, 23);
        sensorcheck();
        if (game1words[rint] == "    Twist It") {
          if (counter2 == 1) {
              Serial.println("Twister");
          if (encoderTwisted == true) {
            game1score = game1score + 1;
            counter = 2;
              Serial.println("Twister scored");
          } else
        sensorcheck();
        if (game1words[rint] == "    Touch It") {
              Serial.println("Touch");
          if (touch1s == HIGH || touch2s == LOW || touch3s == LOW) {
            counter = 2;
              Serial.println("Touch scored");
          } else
        sensorcheck();
        if (game1words[rint] == "    Click It") {
              Serial.println("Button");
          if (redBs == LOW || yellowBs == LOW || greenBs == LOW) {
            counter = 2;
              Serial.println("Button scored");
          } else
        sensorcheck();
        if (game1words[rint] == "    Flick It") {
              Serial.println("Flick");
              Serial.println("Flick error ask about");
          //game1score = game1score + 1;
        sensorcheck();
        if (game1words[rint] == "Pres the Joystick") {
              Serial.println("Joystick");
          if (joy1Bs == LOW || joy2Bs == LOW) {
            counter = 2;
              Serial.println("Joystick Scored");
        if (seconds1 < 10) {
          int1 = 3;
          bool4 = true;
        } else int1 = 2;
        bool4 = false;
        if (minutes1 == 0 && seconds1 == 0) {
          lcd.clear();
          gaming = false;
          if (g1highscore < game1score) {
            g1highscore = game1score;
            newscore = true;
            gameover = false;
          } else
            gameover = true;
          newscore = false;
        if (seconds1 == 0) {
          seconds1 = 59;
          minutes1 = minutes1 - 1;
        counter = counter + 1;
        if (gameover == true) {
          back();
          lcd.clear();
          lcd.print("   Game Over");
          delay(300);
          back();
            Serial.println("Game 1 Over");
          delay(700);
          back();
          lcd.clear();
          lcd.print(" Your Score : ");
          delay(2500);
          back();
          lcd.clear();
          lcd.print("Your Score : ");
          lcd.print("High Score : ");
          delay(2500);
          back();
        if (counter > 10) {
          if (rint > 23) {
          counter = 1;
        if (newscore == true) {
          back();
          lcd.clear();
          lcd.print("highscore");
          delay(300);
        delay(250);
    if (activategame2 == true) {  //////////////////////////////////////////////////////////////////////////////////////////////////////////
      allfalse();
      back();
      refreshb();
      lcd.print("Game 2? ");
      lcd.print("Yes");
      lcd.print("No");
      lcd.print("->");
      lcd.print("<-");
      back();
      delay(300);
      sensorcheck();
      // movement checks
        cor41 = 4;
        cor4g1 = 9;
        cor41 = 5;
        cor4g1 = 0;
        lickes();
        allfalse();
        game2s = true;
        lcd.clear();
        timereset();
        delay(300);
          Serial.println("Starting Countdown to Game 2");
        repeatonce = true;
        lickes();
        lcd.clear();
        timereset();
        delay(300);
        repeatonce = true;
          Serial.println("Decided Aginst Game 2 Returning to Main Menu");
      //spare bool game2s
    if (game2s == true) {
    if (activategame3 == true) {
      back();
      lcd.clear();
      lcd.print(" Click As Many");
      lcd.print("   Buttons As");
      delay(1500);
      back();
      lcd.clear();
      lcd.print("    Possible");
      delay(1500);
      back();
      game3 = true;
      repeatonce = true;
      lcd.print("Forwarding To Game 3");
    if (game3 == true) {
        back();
          Serial.println("Succesfully Forwarded to Game 3");
          Serial.println("Game 3 Chosen, Choosing Timer");
        repeatonce = false;
      if (Serial.available()) {
        command = Serial.readStringUntil('\n');
        command.trim();
        if (command.equals("timer") || command.equals("yes")) {
          timer = true;
          game3 = false;
          notimer = false;
        if (command.equals("no timer") || command.equals("no")) {
          timer = false;
          game3 = false;
          notimer = true;
      back();
      lcd.clear();
      lcd.print("Play With Timer ? ");
      lcd.print("Yes");
      lcd.print("No");
      lcd.setCursor(cor4, 1);
      lcd.print("->");
      lcd.setCursor(cor4 + int7, 1);
      lcd.print(" < -");
      delay(300);
      sensorcheck();
      // movement checks
        cor4 = 10;
        int7 = 4;
        cor4 = 0;
        int7 = 5;
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor4 == 9) {
        notimer = true;
        game3 = false;
        timer = false;
        Serial.println("Game 3 Without Timer");
        lcd.clear();
        delay(300);
        repeatonce = true;
        lickes();
        lcd.clear();
      if ((joy1Bs == LOW || joy2Bs == LOW) && cor4 == 0) {
        notimer = false;
        game3 = false;
        timer = true;
        first = true;
        lcd.clear();
        delay(300);
        Serial.println("Game 3 With Timer");
        repeatonce = true;
        lickes();
        lcd.clear();
    if (notimer == true) {
      int thing = (100 / 81) * game3totalfound;
      lcd.print("    Find It!");
      lcd.print("Found : ");
      lcd.print(game3totalfound);
      back();
      sensorcheck();
    if (timer == true) {
      refreshb();
      lcd.clear();
      back();
      if (first == true) {
        back();
        if (seconds3 < 10) {
          int1 = 13;
        } else int1 = 12;
        lcd.print("Time Left");
        lcd.setCursor(10, 0);
        lcd.print(minutes3);
        lcd.print(" : ");
        lcd.print(seconds3);
        lcd.print("Clicked : ");
        sensorcheck();
        if (touch1s == HIGH || touch2s == HIGH) {
          alloff();
            digitalWrite(rlights[random(1, 29)], HIGH);
          g3score = g3score + 1;
          game3totalfound = game3totalfound + 1;
        if (touch3s == HIGH || joy1Bs == LOW) {
          alloff();
        if (joy2Bs == LOW || greenBs == LOW) {
          alloff();
        if (yellowBs == LOW || redBs == LOW || rotaryBs == LOW) {
          alloff();
        if (something == rrate) {
          something = 0;
          seconds3 = seconds3 - 1;
        if (seconds3 == 0) {
          seconds3 = 59;
          minutes3 = minutes3 - 1;
      if (minutes3 == 0 && seconds3 == 1) {
          lcd.clear();
          back();
          Serial.println("Game Over");
          allfalse();
        if (game3totalfound > g3highscore) {
          alloff();
          refreshb();
          Serial.println("NEW HIGH SCORE!");
            EEPROM.update(G3HS, game3totalfound);
            lcd.print("NEW HIGH SCORE!");
          lcd.print(g3score);
          back();
          first = false;
        if (game3totalfound < g3highscore) {
          alloff();
          first = false;
          lcd.clear();
          lcd.setCursor(3, 0);
          lcd.print("GAME OVER");
          lcd.print(g3score);
          back();
          delay(2000);
          back();
          lcd.clear();
          lcd.print("  High Score: ");
          back();
          delay(2000);
          back();
          first = false;
          lcd.clear();
          lcd.print(" Push Joysticks");
          lcd.print("To Go Main Menu");
          back();
          delay(2000);
          back();
      back();
  if ((Serial.available() || Serial2.available())) {
    command.trim();
      if (command.equals("back") || command.equals("home")) {
        allfalse();
        timereset();
        startup = true;
        Serial.println("Returning to main screen");
        repeatonce = true;
        sentcommands();
      } else if (command.equals("game 3")) {
        allfalse();
        sentcommands();
      } else if (command.equals("game 1 straight") || command.equals("game 1 overide")) {
        allfalse();
        countdown = true;
        gaming = true;
        sentcommands();
      } else if (command.equals("game 1")) {
        allfalse();
        sentcommands();
      } else if (command.equals("game 2")) {
        allfalse();
        game2s = true;
        sentcommands();
      } else if (command.equals("begin") || command.equals("start") || command.equals("Begin") || command.equals("Start")) {
        allfalse();
        timereset();
        repeatonce = true;
        sentcommands();
      } else if (command.equals("Please")) {
        g1highscore = 7500;
        EEPROM.read(game1hs);
        Serial.println(game1hs);
        lcd.print(game1hs);
        sentcommands();
      } else if (command.equals("game 3 with timer") || command.equals("game 3 w timer")) {
        allfalse();
        minutes3 = 2;
        seconds3 = 59;
        timer = true;
        sentcommands();
        lcd.clear();
      } else if (command.equals("game 3 with out timer") || command.equals("game 3 w / o timer") || command.equals("game 3 no timer")) {
        allfalse();
        notimer = true;
        sentcommands();
      } else if (command.equals("HELP")) {
          sentcommands();
        Serial.println("Type Sound Or Lights On Or Off");
        delay(750);
        Serial.println("Type What Game You Would Like To Go To");
        delay(750);
        Serial.println("'Reset' Restarts Board With Data Saved");
        delay(750);
        Serial.println("'Home' Brings You Back To The Home Screen");
          delay(750);
          Serial.println("Type 'Notes' For Programming Notes");
          delay(750);
          Serial.println("Type 'Bool Check' For Active Booleans");
          delay(750);
          Serial.println("Type 'Sensor Check' For List Of Sensor States");
      } else if (command.equals("DeveloperReagan Off") || command.equals("Developer Reagan Off")) {
        Serial.println("Developer Mode Off");
        Serial.println("RESETING");
        delay(150);
        EEPROM.update(114, 2);
        resetFunc();
      } else if ((command.equals("Time ? ") || command.equals("time ? ")) && timer == true) {
        sentcommands();
        Serial.print(minutes3);
        Serial.print(" : ");
        Serial.println(seconds3);
      } else if (command.equals("63Mininto1") && timer == true) {
        minutes3 = 0;
        seconds3 = 15;
        Serial.println("Cheat Code Accepted");
        Serial.println("Time Changed");
      } else if (command.equals("Version ? ") || command.equals("Version") || command.equals("version")
                 || command.equals("version ? ")) {
        Serial.println("Need to fix game 2");
        Serial.println("HELP Function Built");
        Serial.println("Added lights on and off serial commands");
        Serial.println("Added Developer Mode");
        Serial.println("work to debug game 1");
        Serial.println("debugged settings and replaced time with reset");
        Serial.println("Added manual reset option");
        Serial.println("Version 1.2.1");
        Serial.print("Upload ");
      } else if (command.equals("No Sound")) {
        nosound = true;
        Serial.println("Accepted. Sound Turned Off.");
      } else if (command.equals("Sound On")) {
        nosound = false;
        Serial.println("Accepted. Sound Turned On.");
      } else if (command.equals("No Lights")) {
        Light = false;  //////////////////////////////////////////////////////////////////////////////////////////////////////
      } else if (command.equals("Lights On")) {
        Light = true;
      } else if (command.equals("Reset")) {
        Serial.println("Are You Sure You Want To Reset ? ");
        Serial.println("Type Confirm To Proceed Or Cancel To Cancel");
        lastCommand = command;
      } else if (command.equals("Cancel") && lastCommand.equals("Reset")) {
        Serial.println("Good Choice");
      } else if (command.equals("TEST")) {
        allfalse();
        allon();
        Serial.println("You Have 3 Seconds To Input Delay");
        delay(3000);
        alloff();
      } else if (command.equals("Notes")) {
        Serial.println("debugged settings and replaced time with sensitivity");
      } else if (command.indexOf("indent") != -1 && developermode == true) {
        char fifthCharacter = command.charAt(7);
        Serial.println(fifthCharacter);
        blankline(fifthCharacter);
      } else if (command.equals("Confirm") && lastCommand.equals("Reset")) {
        Serial.println("Reseting");
        delay(150);
        resetFunc();
      } else if (command.equals("Direct Reset")) {
        lcd.clear();
          delay(300);
          lcd.print(".");
          Serial.print(".");
        lcd.clear();
        delay(400);
        resetFunc();
      } else if (command.equals("Activate Serial Feedback")) {
        Serial.println("Serial Feedback Enabled");
        Serial.println("Thank You");
      } else if (command.equals("confirm") && activategame1 == true) {
        lcd.clear();
        allfalse();
        countdown = true;
      } else if (command.equals("Version Notes")) {
      } else if (command.equals("Bool Check") && developermode == true) {
        Serial.println("Active Booleans");
          Serial.println("developermode");
        if (backS == true) {
          Serial.println("backS");
        if (SaveS == true) {
          Serial.println("SaveS");
        if (G3T == true) {
          Serial.println("G3T");
        if (G2T == true) {
          Serial.println("G2T");
        if (G1T == true) {
          Serial.println("G1T");
        if (TIME == true) {
          Serial.println("TIME");
        if (confirmreset == true) {
          Serial.println("confirmreset");
          Serial.println("game2s");
        if (game2over == true) {
          Serial.println("game2over");
          Serial.println("LIGHTS");
          Serial.println("SOUND");
        if (G1HS == true) {
        if (G2HS == true) {
        if (G3HS == true) {
          Serial.println("backRR");
          Serial.println("SaveRR");
          Serial.println("bool4");
          Serial.println("newscore");
        if (refreshnow == true) {
          Serial.println("refreshnow");
          Serial.println("gameselection");
          Serial.println("repeatonce");
          Serial.println("gameover");
          Serial.println("gaming");
        if (clicked == true) {
          Serial.println("clicked");
          Serial.println("countdown");
          Serial.println("proceedgame1");
        if (putina0 == true) {
          Serial.println("putina0");
          Serial.println("first");
        if (game1 == true) {
          Serial.println("game1");
        if (game2 == true) {
          Serial.println("game2");
          Serial.println("game3");
          Serial.println("notimer");
          Serial.println("timer");
          Serial.println("settings");
          Serial.println("refreshchange");
          Serial.println("highscores");
          Serial.println("gamesorsettings");
          Serial.println("activategame1");
          Serial.println("activategame2");
          Serial.println("activategame3");
          Serial.println("startup");
      } else if (command.equals("Sensor Check") || command.equals("Sensor States")) {
        sensorcheck();
        if (joy2Bs == LOW) {
          Serial.println("Joystick 2 Button");
        if (touch1s == HIGH) {
          Serial.println("Touch 1");
        if (touch2s == HIGH) {
          Serial.println("Touch 2");
        if (touch3s == HIGH) {
          Serial.println("Touch 3");
        if (joy1Bs == LOW) {
          Serial.println("Joystick 1 Button");
        if (twisters == LOW) {
          Serial.println("Twister Pressed");
        if (redBs == LOW) {
          Serial.println("Red Button");
        if (greenBs == LOW) {
          Serial.println("Green Button");
        if (yellowBs == LOW) {
          Serial.println("Yellow Button");
        if (flickers == LOW) {
          Serial.println("Flicker");
        if (rotary1s == LOW) {
          Serial.println("Roatary 1");
        if (rotary2s == LOW) {
          Serial.println("Roatary 2");
        Serial.println("Joystick Values");
        Serial.print("Joystick 1 X Value:");
        Serial.println(joy1Xs);
        Serial.print("Joystick 2 X Value:");
        Serial.println(joy2Xs);
        Serial.print("Joystick 1 Y Value:");
        Serial.println(joy1Ys);
        Serial.print("Joystick 2 Y Value:");
        Serial.println(joy2Ys);
      } else if (command.equals("Developer Mode") || command.equals("Developer Mode")) {
        sentcommands();
        Serial.println("Type 'Developer' Username On or Off To Enter or Exit Developer Mode");
      } else if (command.equals("DeveloperReagan On") || command.equals("Developer Reagan On")) {
        Serial.println("Password?");
        lastCommand = command;  /////////////////////////////////////////////////////////////////////////////////////////////////////////////
      } else if (command.equals("31.5x2=Awesome!") && (lastCommand.equals("Developer Reagan On") || lastCommand.equals("DeveloperReagan On"))) {
        EEPROM.update(114, 1);
        Serial.println("Accepted");
      } else if (command != ("31.5x2=Awesome!") && lastCommand == ("Developer Reagan On")
                 && developermode == false) {
        Serial.print("Wrong Password, ");
        Serial.print(triesleft);
        Serial.println(" Remaining");
        triesleft = triesleft - 1;
        if (triesleft == 1) {
          Serial.println("Last Try Before Lockout");
      } else if (command.equals("Data Bank Mode On")) {
        EEPROM.update(4, 0);
        delay(400);
        resetFunc();
      } /*else if (){
      else if (command.equals("Joystick Values")) {
      } else Unkown();
    if (bank == true) {
      if (command.equals(User1)) {
        Serial.print("Accepted Username: ");
        Serial.print("Please Enter Password For ");
        lastcommand = command;
      } else if (lastcommand == (User1) && command.equals(User1pass)) {
        Serial.println("Correct");
      } else if (lastcommand == (User1) && command != ("31.5x2=Awesome!") && ask == true) {
        Serial.println("Incorect Password");
        Serial.print(tries);
        Serial.println(" Tries Left");
        tries = tries - 1;
        if (tries < 0) {
          Lockdown = true;
          fails = fails + 1;
          if (fails == 1) {
            t = 1;
            EEPROM.write(3, 1);
          if (fails == 2) {
            t = 3;
            EEPROM.write(3, 2);
          if (fails == 3) {
            t = 5;
            EEPROM.write(3, 3);
          if (fails == 4) {
            t = 10;
            EEPROM.write(3, 4);
          if (fails == 5) {
            t = 15;
            EEPROM.write(3, 5);
          if (fails == 6) {
            t = 30;
            EEPROM.write(3, 6);
          if (fails == 7) {
            t = 60;
            EEPROM.write(3, 7);
          left = 1;
          ask = false;
          EEPROM.write(1, 2);
          EEPROM.write(2, 1);
          Serial.print(t);
          Serial.println(" Minute(s)");
          lockoutend = currentTime + (t * 60000);
      } else if (command.equals("Data Bank Mode Off")) {
        EEPROM.update(4, 1);
        delay(400);
        resetFunc();
  refreshcounter = refreshcounter + 1;
  if (refreshcounter > 10 || command.equals("refresh")) {
    refreshnow = true;
    refreshcounter = 0;
void Unkown() {
  Serial.print("Uknown Command '");
  Serial.print(command);
  Serial.println("'.");
  Serial.println("Please Type Valid Command Or Change Letter Case");
  Serial.println("Type 'HELP' For List Of Commands");
The code i believe is causing the problem is located lines 2363 - 2424, 2342 - 2347, 255 - 265, and 378 - 426. Thank you!
Forgot to mention this, but i am using an arduino mega if it matters.
You are using EEPROM.write() and EEPROM.read() to write and read "int".
"Int" is 2 bytes long and EEPROM.write() and EEPROM.read() only read and write one byte.
Use EEPROM.put() and EEPROM.get(), and consider incrementing the address by 2 by 2.
I tried replacing EEPROM.read with EEPROM.get, and I got this error message
"Compilation error: no matching function for call to 'EEPROMClass::get(int)'"
could you clarify on your previous message? do you mean that i should replace all .write .read with . get and .put? or only with the commands trying to read integers? Thanks!
Read here about:
https://wiki-content.arduino.cc/en/Tutorial/LibraryExamples/EEPROMGet
and here about:
https://wiki-content.arduino.cc/en/Tutorial/LibraryExamples/EEPROMPut
The syntax of EEPROM.get() and EEPROM.put is different from the
syntax of EEPROM.read() and EEPROM.write.
EEPROM.read() ----> seconds1 = EEPROM.read(EEPROMG1S);
EEPROM.get() ----> EEPROM.get(EEPROMG1S,seconds1);
can anyone rewrite partof my code so i can just see, because your replies don't make much sense to me. it seems like you suggested replacing .write with .put but that did not help. Thank you.
I would be best if you can reduce your code to an MCVE. "Minimal,Complete,Verifiable,Example"
This is sometimes called and MRE
"Minimal,Reproducible,Example"
https://en.wikipedia.org/wiki/Minimal_reproducible_example
That is, some more simple code which demonstrates your problem.
That way responders can easily run and test your code and help you to fix it..
That's what reply #5 does.
.put() and .get() are not implemented in the esp32 library.
https://github.com/espressif/arduino-esp32/tree/master/libraries/EEPROM
Moreover, EEPROM is deprecated. The replacement is Preferences.h.
https://github.com/espressif/arduino-esp32/tree/master/libraries/Preferences
@cattledog OP use Mega, not ESP32.
Yes. Total brain fade.
I was responding to this and just assumed it was due to the use of an esp32. Certainly did make an ass out of (not)u and me.
Thank you. This is simplified code.
  delay(50);
  if (banks == 1) {
    bank = false;
  } else banks = true;
if (bank == true) {
if (bank == true) {
    if (value1 == 2) {
      Lockdown = true;
      Serial.print(left);
    if (left == 1) {
      Lockdown = true;
    if (fails == 1) {
      t = 1;
    if (fails == 2) {
      t = 3;
    if (fails == 3) {
      t = 5;
    if (fails == 4) {
      t = 10;
    if (fails == 5) {
      t = 15;
    if (fails == 6) {
      t = 30;
    if (fails == 7) {
      t = 60;
void loop(){
if (bank == true) {
        tries = tries - 1;
        if (tries < 0) {
          Lockdown = true;
          fails = fails + 1;
          if (fails == 1) {
            t = 1;
            EEPROM.write(3, 1);
          if (fails == 2) {
            t = 3;
            EEPROM.write(3, 2);
          if (fails == 3) {
            t = 5;
            EEPROM.write(3, 3);
          if (fails == 4) {
            t = 10;
            EEPROM.write(3, 4);
          if (fails == 5) {
            t = 15;
            EEPROM.write(3, 5);
          if (fails == 6) {
            t = 30;
            EEPROM.write(3, 6);
          if (fails == 7) {
            t = 60;
            EEPROM.write(3, 7);
          left = 1;
          ask = false;
          EEPROM.write(1, 2);
          EEPROM.write(2, 1);
          Serial.print(t);
        delay(400);
        resetFunc();
Please include the variable declarations/initializations and the function definitions. The example code needs to compile and run so as to demonstrate the issue.
What specifically does the example code fail to do that you want it to do, and what does the sample code do that you don't want it to do?
