Eeprom String Read - Two solutions with different answers
I am looking at a method that assigns '/0' at the write and reads back the data until this is found. In this way the string can be of any length
There are two ways to read, one is to append the read chars to a string, and the other to enter the char into an array.
The enclosed program shows both these methods, which on the face of it look identical, except that when I print out the recieved string there is an extra character on the end of the string
#include <Wire.h>
const int Disk1=0x57;              //Address of 24LC256 eeprom chip or ZS042
//Write to the Ext EEPROM
void WriteEEPROM(int deviceaddress, unsigned int eeaddress, byte data )
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8));   // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.write(data);
  Wire.endTransmission();
  delay(5);
 //Read From the Ext EEPROM
byte ReadEEPROM(int deviceaddress, unsigned int eeaddress )
  byte rdata = 0xFF;
  Wire.requestFrom(deviceaddress,1);
  if (Wire.available())
    rdata = Wire.read();
  delay(5);
  return rdata;
// Writes a string to EEprom
void EepromWriteString(int Disk,int Location,String Str)
  int len = Str.length();
  for(int i=0;i<len;i++)
    WriteEEPROM(Disk, Location+i,Str[i]) ;
  WriteEEPROM(Disk, Location+len,'\0');   // termination character
// Reads a string from EEprom
String EepromReadString(int Disk,int Location)
  String Str="";
  int len=0;
  char ks;
  while(ks !='\0' )   //Read until termination character
    ks=ReadEEPROM(Disk,Location+len);
    Str = Str+char(ks);
    len++;
  return String(Str);
// Reads a string from EEprom into a data array
String EepromReadStringData(int Disk,int Location)
  char data[100]; //Max 100 Bytes
  int len=0;
  char kd;
   while(kd !='\0' )   //Read until termination character
    kd=ReadEEPROM(Disk,Location+len);
    data[len]=kd;
    len++;
   // Serial.println(char(kd));
  data[len]='\0';
  return String(data);
  Serial.begin (115200);
  Wire.begin();
EepromWriteString(Disk1,1345, "Big Boys Toys");
delay(20);
//Serial.print("Array based   ");Serial.println(EepromReadStringData(Disk1,1345));
delay(20);
Serial.print("String based  ");Serial.println(EepromReadString(Disk1,1345));
Can anyone explain this please
Some bugs:
  • ks is undefined on the first iteration.
  • Then the next character is appended to the string. This character can be \0 which terminates a string in a char array but not a String.
Sorry, I don't understand how ks is undefined. It takes on the char of the EEprom read
Only after the first while() test.
