Elegoo 2.8" TFT Display not registering touch at certain points
Hello,
I have recently purchased an Elegoo 2.8" TFT display using an ILI9341 shield. I was able to get it working in the sense that I was able to get it to display what I want it to, but I discovered that the screen is only registering my touches on approximately 3/4 of the screen. I am assuming the screen is functional because I was able to run the example calibration sketch and touch the entire perimeter of the screen. Can someone help me with this issue?
Thank you!
Bryan
this is not an Installation & Troubleshooting issue!
I bet the issue is in the code you did not post!
Whoops! My apologies.
Here is a copy of my code. It is incomplete, so it is messy and some of it may not make sense, but the touchscreen calibrations are there. I originally ran this code on a smaller 2.4" display and it worked fine there -- not so much on the 2.8" display.
/**** INCLUDE THE REQUIRED LIBRARIES FOR THE CODE ****/
// Stepper motor library:
#include <AccelStepper.h>
// Touchscreen display libraries:
#include <TouchScreen.h>
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
/**** DEFINE THE ARDUINO PINS ****/
// Stepper motor pins:
#define dirPin 12 // Pin connecting to DIR+ port on motor driver:
#define stepPin 11  // Pin connecting to PUL+ port on motor driver:
#define motorInterfaceType 1  // Motor interface type defaulted to 1:
// Touchscreen display pins:
#define YP A1 // Pin connecting to 5V input on touchscreen:
#define XM A2 // Pin connecting to ground on touchscreen:
#define YM 7  // Pin connecting to ground on touchscreen:
#define XP 6  // Pin connecting to 5V input on touchscreen:
#define LCD_CS A3 // Pin connecting to CD_CS on touchscreen shield:
#define LCD_CD A2 // Pin connecting to CD_RS on touchscreen shield:
#define LCD_WR A1 // Pin connecting to CD_WR on touchscreen shield:
#define LCD_RD A0 // Pin connecting to CD_RD on touchscreen shield:
#define LCD_RESET A4 // Pin connecting to CD_RST on touchscreen shield:
/**** CREATE OBJECTS TO MANIPULATE IN CODE ****/
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
/**** CREATE AND DEFINE COLORS ****/
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define ORANGE  0xFD20
#define DARKORANGE  0xFB60
#define MAROON  0x7800
#define GRAY  0x8410
/**** DEFINE PRESSURE SETTINGS ****/
#define MINPRESSURE 100 // Defines minimum pressure applied to touchscreen display for input:
#define MAXPRESSURE 2000  // Defines maximum pressure applied to touchscreen display for input:
/**** CALIBRATE TOUCHSCREEN ACCORDING TO SCREEN SIZE ****/
#define TS_MINX 916  // Defines left bound of the screen:
#define TS_MINY 75  // Defines top bound of the screen:
#define TS_MAXX 109  // Defines right bound of the screen:
#define TS_MAXY 905  // Defines bottom bound of the screen:
/**** INITIATE TRUE/FALSE CONDITIONS FOR BUTTON PRESS ****/
bool change = 0;
bool touch = 0;  // Initial condition for start/stop button:
bool rst = 0;  // Initial condition for reset button:
/**** DEFINE VARIABLES ****/
int origin = 0;  // Initial condition for center of machine:
int speedset = 0;  // Initial condition for speed:
int command = 0;  // Initial condition for touch settings:
int back = 0;  // Initial condition for back button:
int back2 = 0;
int spdbtn = 0;  // Initial condition for speed setting button:
int locbtn = 0;  // Initial condition for location setting button:
int set = 0;  // Initial condition for settings button:
int units = 0;  // Initial condition for units buttons:
int calibrate = 0;  // Initial condition for calibrate button:
/**** CREATE HOME SCREEN FUNCTION ****/
void homescreen() {
  if (change == 0 && touch == 0 && rst == 0 && set == 0) {
    // Parameters for stepper motor:
    stepper.setMaxSpeed(speedset);
    // Code motor movement:
    stepper.moveTo(origin);
    stepper.runSpeedToPosition();
    delay(100);
    tft.fillRoundRect(25, 25, 150, 195, 10, GREEN);  // Creates button shape. Syntax: tft.fillRoundRect(x, y, width, height, radius, color):
    tft.setCursor(45, 110); //  Text location. Syntax: tft.setCursor(x, y):
    tft.setTextSize(4); // Font size:
    tft.println("START"); // Message:
    tft.fillRoundRect(200, 25, 100, 90, 10, GRAY);
    tft.setCursor(205, 65);
    tft.setTextSize(3);
    tft.println("RESET");
    tft.fillRoundRect(200, 130, 100, 90, 10, GRAY);
    tft.setCursor(205, 165);
    tft.setTextSize(2);
    tft.println("SETTINGS");
    change = 1;
    command = 0;
    back = 0;
    back2 = 0;
    spdbtn = 0;
    locbtn = 0;
    set = 0;
    delay(125);
  if (change == 0 && touch == 1 && rst == 0 && set == 0) {
    stepper.moveTo(origin + 1000);
    delay(100);
    stepper.moveTo(origin - 1000);
    delay(100);
    tft.fillRoundRect(25, 25, 150, 195, 10, RED);  // Creates button shape. Syntax: tft.fillRoundRect(x, y, width, height, radius, color):
    tft.setCursor(55, 110); //  Text location. Syntax: tft.setCursor(x, y):
    tft.println("STOP"); // Message:
    tft.setTextSize(3);
    tft.setTextSize(2);
    change = 1;
    command = 0;
    back = 0;
    back2 = 0;
    spdbtn = 0;
    locbtn = 0;
    set = 0;
    delay(25);
  if (change == 0 && touch == 0 && rst == 1 && set == 0) {
    origin = 0; // Reset platform to the center of the machine at motor position 0:
  if (change == 0 && touch == 0 && rst == 0 && set == 1) {
    settings();
    command = 1;
/**** CREATE SETTINGS FUNCTION ****/
void settings() {
  if (change == 0 && back == 0 && spdbtn == 0 && locbtn == 0) {
    tft.fillScreen(ORANGE);
    tft.fillRoundRect(12, 15, 75, 35, 5, GRAY); // Creates button shape. Syntax: tft.fillRoundRect(x, y, width, height, radius, color):
    tft.setCursor(25, 25); //  Text location. Syntax: tft.setCursor(x, y):
    tft.setTextSize(2); // Font size:
    tft.println("BACK"); // Message:
    tft.fillRoundRect(12, 75, 300, 70, 10, GRAY);
    tft.setCursor(50, 100);
    tft.setTextSize(3);
    tft.println("SPEED SETTING");
    tft.fillRoundRect(12, 160, 300, 70, 10, GRAY);
    tft.setCursor(20, 185);
    tft.setTextSize(3);
    tft.println("LOCATION SETTING");
    change = 1;
    command = 1;
    back = 0;
    back2 = 0;
    spdbtn = 0;
    locbtn = 0;
    set = 1;
    delay(225);
  if (change == 0 && back == 1 && spdbtn == 0 && locbtn == 0) {
    tft.fillScreen(WHITE);
    tft.setTextSize(3);
    tft.setTextSize(2);
    change = 1;
    command = 0;
    back = 0;
    spdbtn = 0;
    locbtn = 0;
    set = 0;
    delay(225);
  if (change == 0 && back == 0 && spdbtn == 1 && locbtn == 0) {
    speedsetting();
    command = 2;
  if (change == 0 && back == 0 && spdbtn == 0 && locbtn == 1) {
    locsetting();
    command = 3;
/**** CREATE SPEED SETTING FUNCTION ****/
void speedsetting() {
  if (change == 0 && back2 == 0 && units == 0) {
    tft.fillRoundRect(235, 15, 75, 35, 5, GRAY);
    tft.setCursor(245, 25);
    tft.setTextSize(2);
    tft.println("UNITS");
    tft.setCursor(12, 150);
    tft.setTextSize(2);
    tft.print("Motor Speed:");
    tft.drawRect(12, 170, 295, 40, BLACK);
    change = 1;
    command = 2;
    back2 = 0;
    spdbtn = 1;
    locbtn = 0;
    set = 1;
    delay(225);
  if (change == 0 && back2 == 1 && units == 0) {
    tft.setTextSize(3);
    tft.setTextSize(3);
    change = 1;
    command = 1;
    back2 = 0;
    spdbtn = 0;
    locbtn = 0;
    set = 1;
    delay(225);
/**** CREATE LOCATION SETTING FUNCTION ****/
void locsetting() {
  if (change == 0 && back2 == 0 && calibrate == 0 && units == 0) {
    tft.fillRoundRect(103, 15, 115, 35, 5, GRAY);
    tft.setCursor(108, 25);
    tft.setTextSize(2);
    tft.println("CALIBRATE");
    tft.setTextSize(2);
    tft.setTextSize(2);
    tft.print("Location:");
    change = 1;
    command = 3;
    back = 0;
    back2 = 0;
    spdbtn = 0;
    locbtn = 1;
    set = 1;
    delay(225);
  if (change == 0 && back2 == 1 && calibrate == 0 && units == 0) {
    tft.setTextSize(3);
    tft.setTextSize(3);
    change = 1;
    command = 1;
    back = 0;
    back2 = 0;
    spdbtn = 0;
    locbtn = 0;
    set = 1;
    delay(225);
/**** SET UP PARAMETERS FOR MACHINE ****/
  // Parameters for touchscreen display:
  tft.reset();
  tft.begin(0x9341);  // Defines driver type for touchscreen display:
  tft.setRotation(1); // Locks screen in an orientation (0 = vertical & 1 = horizontal):
  tft.setTextColor(BLACK);  // Defines text color:
  tft.fillScreen(WHITE);  // Defines background color:
/**** CREATE MAIN CODE TO RUN MACHINE ****/
  homescreen();
  TSPoint p = ts.getPoint();
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
    p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
    Serial.print("("); Serial.print(p.x);
    Serial.print(", "); Serial.print(p.y);
    Serial.println(")");
    if (command == 0) {
      if (p.x > 65 && p.x < 300) {
        if (p.y > 105 && p.y < 210) {
          change = 0;
          touch = !touch;
      if (p.x > 200 && p.x < 300) {
        if (p.y > 20 && p.y < 90) {
          change = 0;
          rst = !rst;
      if (p.x > 65 && p.x < 175) {
          change = 0;
          set = !set;
    if (command == 1) {
      if (p.x > 255 && p.x < 300) {
        if (p.y > 170 && p.y < 223) {
          change = 0;
          back = !back;
      if (p.x > 140 && p.x < 230) {
        if (p.y > 12 && p.y < 223) {
          change = 0;
          spdbtn = !spdbtn;
      if (p.x > 55 && p.x < 135) {
        if (p.y > 15 && p.y < 223) {
          change = 0;
          locbtn = !locbtn;
    if (command == 2) {
          change = 0;
          back2 = !back2;
          change = 0;
          units = !units;
    if (command == 3) {
          change = 0;
          back2 = !back2;
          change = 0;
          units = !units;
          change = 0;
          calibrate = !calibrate;
You appear to be using MCUFRIEND_kbv.
Run the Calibration sketch from the examples.
Make a note of the results for the 2.4 inch and the 2.8 inch screen.
Run the Touch_Shield_new.ino from the examples (with your calibration results)
This should give you a "Paint" screen. The paint spot should follow the stylus exactly. (if calibration is correct)
If you find that one corner is "out of reach" this is a common feature of resistive Touch Panels.
In practice you will have no problem with most Touch "buttons"
If you have a serious blind corner measure it with a ruler. Report the size and shape of the blind area.
David.
Thank you for your reply David. I did what you suggested and here are the results:
For 2.4":
Portrait Calibration: Left = 216, Right = 936, Top = 165, Bottom = 916
No dead spots or issues when using Touch_Shield_new.ino
For 2.8":
Portrait Calibration: Left = 921, Right = 109, Top = 73, Bottom = 902
Mostly dead when using Touch_Shield_new.ino
The measurement for the usable, triangular top, left section is 1.25 x 1.10".
The blind area looks like a rectangle with the top, left corner cut out of it.
The long base of the rectangle at the bottom is the entire width of the screen at about 1.7"
The short base at the top of the rectangle is about 0.43"
The short vertical side on the left is about 1.2"
The long vertical side on the right is the entire length of the screen at about 2.25"
I don't believe you. The two calibrations look perfectly normal i.e. ~800 difference between LEFT, RT and TOP, BOT.
If the calibration worked smoothly you can't have had any "blind" spots.
Sometimes you can't quite reach one of the corner cross-hairs.
I would expect scribbling to show most of the rectangle. Just with a missing 0.25" triangle on one corner. Everywhere else the coloured spot follows the stylus perfectly.
Your "Paint" description would mean that you can't select all the colours. e.g. the BLUE or MAGENTA. And if you scribble over the screen you only get a triangle.
David.
