I have spent a while searching around for this issue. It seems like many people are having the same issue but I am no closer to understanding what is happening. This is my first real attempt at programming an Arduino in any capacity.
I have an Elegoo kit and I have been using the browser program from Arduino to code.
I was having issues with a code I found, so I imported the libraries I needed from the disc included with the Elegoo, and even tried to run the examples they included. Which naively I would assume they would work but to no avail. But as I write this I found an interesting issue...
I have one file in my sketchbook that I am trying to compile and the code is copied right from the example, but is on a separate tab from the code I am trying to write independently.
The other is in its own sketchbook and will compile perfectly.
This leads me to think there is something I don't understand about how the tabs work in this program? I'm not sure. I included the images of the two tabs in case what I am saying is odd...
I do have other questions but lets clear that up first.
Thank you
