scswift
#1
I am trying to get the SD card library to work with a Sanguino variant, and the pin mappins are contained within define directives like the one above.
The problem is, I don't know where in hundreds of source files AVR_ATmega644P would be defined, if anywhere.
Where is the specific chipset used defined?
system
#2
It is not defined in the source files. It is defined by the IDE, as an argument to the preprocessor/compiler, when you select a particular board.
scswift
#3
