'else' without a previous 'if' error on arduino Ide
I was trying to write code for a lightning effect for Halloween. I got an"'else' without a previous 'if'" error message even though "if" is above. My code is below:
int TriggerValue = 0;
pinMode(A0, INPUT);//Botton trigger
pinMode(1, OUTPUT);// light
pinMode(2, OUTPUT); //sfx
TriggerValue = digitalRead(A0);
if (TriggerValue != 0)
Serial.println("Triggered");
  digitalWrite(1, HIGH);
  delay(200);
  digitalWrite(1, LOW);
  digitalWrite(2, HIGH);
  delay(200);
  Serial.println("Gottom! You should have seen the look on your face!");
  digitalWrite(2, LOW);
(TriggerValue != 1);
Thank you for helping!
You're missing { and } for the statements that depend on the if condition.
If you use tools->autoformat in the IDE, your code looks like
indicating that only the Serial.println is depending on the condition and the digitalWrite is not.
Note the indentations after the autoformat was applied.
Always use braces
The syntax you are looking for is probably
if( )
In your case the if statement ends with the first semicolon.
All next lines are outside of this "if" so the "else" statement causes an error. Same problem is behind the "else".
