Enable/Disable an interrupt
I have a bike speedometer based on a GPS module using a Nano Every. It shows me speed, latitude, longitude, a compass, and can datalog my position as I ride and later download that onto Google maps, all of that works fine.
I was calculating the distances travel based on the GPS speed and time. It was always off by about 15%. I've taken a hall effect sensor used on ebikes and have that going into interrupt 0, pin 2. This counts the revolutions of the wheel, some simple math will give me the milage, right now I'm just looking at revolutions.
I have a button to start/stop the datalogging. I only want the revolutions count to increment while datalogging. When I stop datalogging I want the count to remain and not increment. That why I can see how far I've gone. I have it so when I restart datalogging it zero's the count. Again most of that works with one exception.
I put the attachInterrupt function in an if statement, shown below. When I first start the system the interrupt does not increment, When I start datalogging it does start to count. When I stop datalogging it still increments. If I start datalogging again it does zero the count.
 if (RunLogger == 1) {
    // Wheel sensor interrupt
    attachInterrupt(digitalPinToInterrupt(2), distCount, RISING);
    Serial.println("Logger = 1");
  else {
    Serial.println("Logger = 0");
This is my first project using interrupts and I'm sure it has something to do with my lack of experience or what I can find online with using interrupts.
Why does it keep incrementing after I stop datalogging? Or a better questions is what is the correct way to do this?
Thanks for all help and suggestions, the complete code is below.
John
  Changed to Nano Every
  with Adafruit 3.5 TFT display
  Rev 2 Added touch, made 2 pages for displaing info
        No logging function
  Rev 6 added compass by G6EJD - David
  Rev 7 Changed to Elapsed time method and bike wheel pickup
// Include required libraries
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
#include <Adafruit_GFX.h>         // Core graphics library
#include <Adafruit_HX8357.h>      // Hardware-specific library
#include "TouchScreen.h"
// GPS Connections
static const int RXPin = 6, TXPin = 7;
// GPS Baud rate (change if required)
static const uint32_t GPSBaud = 9600;
// SD Card Select pin
const int chipSelect = 5;
// Write LED
const int recLED = 8;
// String to hold GPS data
String gpstext;
// GPS write delay counter variables
// Change gpsttlcount as required
int gpscount = 0;
int gpsttlcount = 140;
int fileMade = 0; // check to see if a new file was made on SD card
// TinyGPS++ object
TinyGPSPlus gps;
// SoftwareSerial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// display
#define TFT_CS   10
#define TFT_DC   9
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC);
// These are the four touchscreen analog pins
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 3   // can be a digital pin
#define XP 4   // can be a digital pin
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 110
#define TS_MINY 80
#define TS_MAXX 900
#define TS_MAXY 940
#define MINPRESSURE 10
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// Color definitions
#define BLACK    0x0000
#define BLUE     0x001F
#define RED      0xF800
#define GREEN    0x07E0
#define CYAN     0x07FF
#define MAGENTA  0xF81F
#define YELLOW   0xFFE0
#define WHITE    0xFFFF
bool newData = false;
float log_Dist = 0.0;
unsigned long int scan_time = millis();
int currentPage = 1;
int SD_Status = 0;
int GPS_Status = 0;
float Heading = 0.0;
String RideTime = "";
int RideHr = 0;
int RideMin = 0;
unsigned long RideSec = 0;
unsigned long StartTime = 0;
int StartHr = 0;
int StartMin = 0;
int StartSec = 0;
int readStartTime = 0;
char RideTm[80];
int TestTm = 0;
// Compass
float Bearing;
const int centreX  = 160; // Location of the compass display on screen
const int centreY  = 280;
const int diameter = 70; // Size of the compass
int  dx = centreX, dy = centreY;
int  last_dx = centreX, last_dy = centreY - diameter * 0.85;
// the logging file
File logfile;
char logFileName[20] = " "; // current log file name
int errorNumb = 0; // system error number to display message
int RunLogger = 0; // run logging file
int LogPBOld = 0;
int LogPBNew = 0;
File dataFile;
long int lastLogTime = 0; // last time log sample was read
int logDelay = 10000; // time delay between log samples
// for wheel sensor
volatile long int Wheel_Count = 0;
volatile float revolutions = 0;
long  DiststartTime = 0;
//long  DistelapsedTime;
float Wheel_Dia = 85.0;
float Mileage = 0;
  // Set all chip selects high to avoid bus contention during initialisation of each peripheral
  // digitalWrite(21, HIGH); // Touch controller chip select (if used)
  digitalWrite(10, HIGH); // TFT screen chip select
  digitalWrite( 5, HIGH); // SD card chips select, must use GPIO 5 (ESP32 SS)
  // Set LED pin as output
  pinMode(recLED, OUTPUT);
  // Wheel sensor pin
  pinMode(2, INPUT_PULLUP);
  // Start Serial Monitor for debugging
  // Start SoftwareSerial
  ss.begin(GPSBaud);
  // start display driver
  tft.begin();          // Initialize screen
  //tft.fillScreen(BLACK); //clears screen, sets to Black
  tft.setRotation(0);  // rotates screen 90' for landscape mode
  // load Speedometer page
  SpeedometerPage();
  // Initialize SD card
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    //don't do anything more:
    tft.fillCircle(30, 30, 10, RED);
    while (1);
  Serial.println("card initialized.");
  // Blink LED so we know we are ready
  //digitalWrite(recLED, HIGH);
  tft.fillCircle(30, 30, 10, BLACK);
  //digitalWrite(recLED, LOW);
  tft.fillCircle(30, 30, 10, GREEN);
  scan_time = millis(); // reset scan time
} // end setup
  // Turn off LED
  // Retrieve a point on touch screen
  TSPoint p = ts.getPoint();
  // See if GPS data available
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      // If we press the Speedometer Button
      if ((p.x >= 130) && (p.x <= 290) && (p.y >= 810) && (p.y <= 890)) {
        currentPage = 1; // Indicates that we are the first example
        Serial.println("Speed pressed");
        SpeedometerPage(); // It is called only once, because in the next iteration of the loop, this above if statement will be false so this funtion won't be called. This function will draw the graphics of the first example.
      } // end if for Speedometer button pressed
  // If we press the GPS Info Button
  if ((p.x >= 420) && (p.x <= 600) && (p.y >= 810) && (p.y <= 890)) {
    currentPage = 2;
    Serial.println("GPS Pressed");
    GPS_Info_Page();
  } // end if for GPS Info page
  // Start/Stop logging file with Log PB
  if ((p.x >= 725) && (p.x <= 890) && (p.y >= 810) && (p.y <= 890)) {
    RunLogger = !RunLogger;  // toggle RunLogger
  } // end RunLogger = !RunLogger
  // Data logger control PB
  if (RunLogger == 0 && LogPBOld == 1) {
    tft.fillRoundRect(240, 410, 70, 50, 10, RED);
    tft.setCursor(257, 427);
    tft.setTextColor(WHITE, RED);
    tft.setTextSize(2);
    tft.print("LOG");
    LogPBOld = 0;
    fileMade = 0;
  } // end RunLogger == 0
  else if (RunLogger == 1 && LogPBOld == 0) {
    tft.fillRoundRect(240, 410, 70, 50, 10, GREEN);
    tft.setTextColor(BLACK, GREEN);
    tft.setTextSize(2);
    tft.print("LOG");
    LogPBOld = 1;
    StartTime = millis();
    log_Dist = 0; //clear log distance
    RideHr = 0; // clear log hours
    RideMin = 0; // clear log minutes
    RideSec = 0; // clear log seconds
    revolutions = 0; // clear wheel sensor count
  } // end else if
  // call logger function
    // logger();
  } // end if RunLogger == 1
  else {
    logfile.close();
    fileMade = 0;
  } // end else
  // Update variables
  // display GPS status
  //if(GPS_Status == 1){
  if (gps.location.isValid()) {
    tft.fillCircle(290, 30, 10, GREEN);
  //if(GPS_Status == 0) {
  if (!gps.location.isValid()) {
    tft.fillCircle(290, 30, 10, RED);
  else {
  // calculate mileage
  Mileage = revolutions * Wheel_Dia;
  Serial.println(Mileage);
  newData = true;
  if (((millis() - scan_time) > 1000)) { // Update every second
    //if (gps.location.isValid())
    if (newData == true)
      newData = false;
      // ride start time
      if (readStartTime == 0) {
        StartHr = gps.time.hour();
        StartMin = gps.time.minute();
        StartSec = gps.time.second();
        readStartTime = 1;
      } // end if(readStartTime == 0)
    } // if(newdata == true)
      Serial.println(F("INVALID"));
    } // end else
    // Update screen variables
    if (currentPage == 1) {
      tft.setCursor(50, 120);
      tft.setTextColor(WHITE, BLACK);
      tft.setTextSize(6);
      tft.print(gps.speed.mph(), 1);
      Bearing = gps.course.deg();
      Display_Compass(Bearing); // show compass
    } // end if current page =1
    if (currentPage == 2) {
      tft.setCursor(50, 110);
      tft.setTextSize(4);
      tft.print(gps.location.lng(), 4);
      // Display Latitude
      tft.setCursor(50, 190);
      tft.setTextSize(4);
      tft.print(gps.location.lat(), 4);
      // Display log_Dist
      tft.setCursor(50, 270);
      tft.setTextSize(4);
      tft.print(log_Dist, 1);
      // Display Ride Time
      tft.setCursor(50, 350);
      tft.setTextSize(4);
      sprintf(RideTm, "%02d:%02d:%02d", RideHr, RideMin, RideSec);
      tft.print(RideTm);
    } // end if current page = 2
    if (millis() > 5000 && gps.charsProcessed() > 10) {
      GPS_Status = 1;
    if (millis() > 5000 && gps.charsProcessed() < 10)
      Serial.println(F("No GPS detected: check wiring."));
      GPS_Status = 0;
      //while(true);
    // calculate ride time
      RideSec = (millis() - StartTime) / 1000;
      if (RideSec >= 60) {
        RideMin = RideMin + 1;
        RideSec = 0;
      if (RideHr  >= 24) {
        RideHr = 0;
      if (RideMin >= 60) {
        RideMin = 0;
        RideHr = (RideHr + 1);
      // calculate log_Dist
      if (gps.speed.mph() > 0.5) {
        log_Dist = log_Dist + (gps.speed.mph() / 3600);
      } // end if(GPS.speed.mph() > 0.5)
    } // end if(RunLogger == 1)
    /*  if(RunLogger == 0){
      } // end if(RunLogger == 0)
  } // end (((millis() - scan_time) > 1000)
  // Run GPS Logger
    // Turn off LED
    // *************  Dronebot GPS logging code   **************
    // See if data available
        // See if we have a complete GPS data string
        if (displayInfo() != "0")
          // Check GPS Count
          // Serial.println(gpscount);
          if (gpscount == gpsttlcount) {
            // LED On to indicate data to write to SD card
            // create a new data logging file
            if (RunLogger == 1 && fileMade == 0) {
              Serial.println("Create file");
              char filename[] = "File00.CSV";
              for (uint8_t i = 0; i < 100; i++) {
                filename[4] = i / 10 + '0';
                filename[5] = i % 10 + '0';
                if (! SD.exists(filename)) {
                  // strcpy(logFileName, filename);
                  // only open a new file if it doesn't exist
                  dataFile = SD.open(filename, FILE_WRITE);
                  Serial.println(filename);
                  fileMade = 1;
                  break;  // leave the loop!
                } // end if (! SD.exist)
              } // end for (uint8_t i = 0; i < 100; i++)
            } // end if RunLogger == 1 && fileMade == 0
            //Open the file on card for writing
            dataFile = SD.open(logFileName, FILE_WRITE);
            Serial.println(logFileName);
            //File dataFile = SD.open("gpslog.csv", FILE_WRITE);
            // Get GPS string
            gpstext = displayInfo();
            if (dataFile) {
              // If the file is available, write to it and close the file
              dataFile.println(gpstext);
              dataFile.close();
              // Serial print GPS string for debugging
              Serial.println(gpstext);
            // If the file isn't open print an error message for debugging
            else {
              Serial.println("error opening datalog.txt");
          // Increment GPS Count
          gpscount = gpscount + 1;
          if (gpscount > gpsttlcount) {
            gpscount = 0;
        } // end if (displayInfo() != "0")
  } // end run logger
} // end loop()
void SpeedometerPage() {
  // Prints the title on the screen
  tft.setCursor(65, 20);
  tft.setTextColor(WHITE);
  tft.setTextSize(3);
  tft.print("Speedometer");
  tft.drawFastHLine(10, 60, 320, RED);
  // Display SS Initialized status
  // Display Speed
  tft.setCursor(50, 90);
  tft.setTextSize(2);
  tft.print("Speed");
  // Draw buttons
  // fillRoundRect(X, Y, width, height, radius, color);
  // Speedometer page select PB
  tft.fillRoundRect(10, 410, 70, 50, 10, BLUE);
  tft.setCursor(16, 427);
  tft.setTextColor(WHITE, BLUE);
  tft.setTextSize(2);
  tft.print("Speed");
  // GPS Info Page select PB
  tft.fillRoundRect(126, 410, 70, 50, 10, MAGENTA);
  tft.setCursor(143, 427);
  tft.setTextColor(BLACK, MAGENTA);
  tft.setTextSize(2);
  tft.print("GPS");
  if (RunLogger == 0) {
    tft.setTextSize(2);
    tft.print("LOG");
  else if (RunLogger == 1) {
    tft.setTextSize(2);
    tft.print("LOG");
  } // end else if
} // end Speedometer page
void GPS_Info_Page() {
  tft.setCursor(90, 20);
  tft.setTextSize(3);
  tft.print("GPS Info");
  // Display Longitude
  tft.setCursor(50, 80);
  tft.setTextSize(2);
  tft.print("Longitude");
  // Display Latitude
  tft.setCursor(50, 160);
  tft.setTextSize(2);
  tft.print("Latitude");
  // Display Distance
  tft.setCursor(50, 240);
  tft.setTextSize(2);
  tft.print("Distance");
  // Display Time
  tft.setCursor(50, 320);
  tft.setTextSize(2);
  tft.print("Time");
  // Draw buttons
  tft.setTextSize(2);
  tft.print("Speed");
  tft.setTextSize(2);
  tft.print("GPS");
    tft.setTextSize(2);
    tft.print("LOG");
    tft.setTextSize(2);
    tft.print("LOG");
  } // end else if
} // End GPS_Info_Page
// Function to return GPS string
String displayInfo()
  // Define empty string to hold output
  String gpsdata = "";
  // Get latitude and longitude
    gpsdata = String(gps.location.lat(), 6);
    gpsdata += (",");
    gpsdata += String(gps.location.lng(), 6);
    gpsdata += (",");
    return "0";
  // Get Date
  if (gps.date.isValid())
    gpsdata += String(gps.date.year());
    gpsdata += ("-");
    if (gps.date.month() < 10) gpsdata += ("0");
    gpsdata += String(gps.date.month());
    gpsdata += ("-");
    if (gps.date.day() < 10) gpsdata += ("0");
    gpsdata += String(gps.date.day());
    // gpsdata += (",");
    return "0";
  // Space between date and time
  gpsdata += (",");
  // Get time
  if (gps.time.isValid())
    if (gps.time.hour() < 10) gpsdata += ("0");
    gpsdata += String(gps.time.hour() - 4);
    gpsdata += (":");
    if (gps.time.minute() < 10) gpsdata += ("0");
    gpsdata += String(gps.time.minute());
    gpsdata += (":");
    if (gps.time.second() < 10) gpsdata += ("0");
    gpsdata += String(gps.time.second());
    return "0";
  // Return completed string
  return gpsdata;
} // end String displayInfo()
void Display_Compass(float dBearing) {
  int dxo, dyo, dxi, dyi;
  tft.setCursor(0, 0);
  tft.drawCircle(centreX, centreY, diameter, WHITE); // Draw compass circle
  for (float i = 0; i < 360; i = i + 22.5) {
    dxo = diameter * cos((i - 90) * 3.14 / 180);
    dyo = diameter * sin((i - 90) * 3.14 / 180);
    dxi = dxo * 0.9;
    dyi = dyo * 0.9;
    tft.drawLine(dxo + centreX, dyo + centreY, dxi + centreX, dyi + centreY, WHITE);
  PrintText((centreX - 5), (centreY - diameter - 18), "N", WHITE, 2);
  PrintText((centreX - 5), (centreY + diameter + 5) , "S", WHITE, 2);
  PrintText((centreX + diameter + 5),  (centreY - 5), "E", WHITE, 2);
  PrintText((centreX - diameter - 15), (centreY - 5), "W", WHITE, 2);
  dx = (0.85 * diameter * cos((dBearing - 90) * 3.14 / 180)) + centreX; // calculate X position
  dy = (0.85 * diameter * sin((dBearing - 90) * 3.14 / 180)) + centreY; // calculate Y position
  draw_arrow(last_dx, last_dy, centreX, centreY, 5, 5, BLACK);   // Erase last arrow
  draw_arrow(dx, dy, centreX, centreY, 5, 5, WHITE);           // Draw arrow in new position
  last_dx = dx;
  last_dy = dy;
  // display compass azimuthal points
  tft.setTextSize(3);
  tft.fillRect(230, 355, 60, 22, BLACK);
  tft.setCursor(230, 355);
  tft.print(Bearing_to_Ordinal(Bearing));
}// end Display_Compass;
void PrintText(int x, int y, String text, int colour, byte text_size) {
  tft.setCursor(x, y);
  tft.setTextColor(colour);
  tft.setTextSize(text_size);
  tft.print(text);
  tft.setTextColor(YELLOW); // Default colour
  tft.setTextSize(2);       // Default Text Size
} // end Printtext
void draw_arrow(int x2, int y2, int x1, int y1, int alength, int awidth, int colour) {
  float distance;
  int dx, dy, x2o, y2o, x3, y3, x4, y4, k;
  distance = sqrt(pow((x1 - x2), 2) + pow((y1 - y2), 2));
  dx = x2 + (x1 - x2) * alength / distance;
  dy = y2 + (y1 - y2) * alength / distance;
  k = awidth / alength;
  x2o = x2 - dx;
  y2o = dy - y2;
  x3 = y2o * k + dx;
  y3 = x2o * k + dy;
  x4 = dx - y2o * k;
  y4 = dy - x2o * k;
  tft.drawLine(x1, y1, x2, y2, colour);
  tft.drawLine(x1, y1, dx, dy, colour);
  tft.drawLine(x3, y3, x4, y4, colour);
  tft.drawLine(x3, y3, x2, y2, colour);
  tft.drawLine(x2, y2, x4, y4, colour);
} // end draw_arrow
String Bearing_to_Ordinal(float bearing) {
  if (bearing >= 348.75 || bearing < 11.25)  return "N  ";
  if (bearing >=  11.25 && bearing < 33.75)  return "NNE";
  if (bearing >=  33.75 && bearing < 56.25)  return "NE ";
  if (bearing >=  56.25 && bearing < 78.75)  return "ENE";
  if (bearing >=  78.75 && bearing < 101.25) return "E  ";
  if (bearing >= 101.25 && bearing < 123.75) return "ESE";
  if (bearing >= 123.75 && bearing < 146.25) return "SE ";
  if (bearing >= 146.25 && bearing < 168.75) return "SSE";
  if (bearing >= 168.75 && bearing < 191.25) return "S  ";
  if (bearing >= 191.25 && bearing < 213.75) return "SSW";
  if (bearing >= 213.75 && bearing < 236.25) return "SW ";
  if (bearing >= 236.25 && bearing < 258.75) return "WSW";
  if (bearing >= 258.75 && bearing < 281.25) return "W  ";
  if (bearing >= 281.25 && bearing < 303.75) return "WNW";
  if (bearing >= 303.75 && bearing < 326.25) return "NW ";
  if (bearing >= 326.25 && bearing < 348.75) return "NNW";
  return "?";
} // end Bearing_to_Ordinal
void distCount() //interrupt service routine
  revolutions++;
You need to detachInterrupt() when you want to stop handling them.
I don't see that you ever detachInterrupt.
Once attached, the interrupt will fire on conditions.
You could detach the interrupt when you don't want it, or write the ISR to respect an On/Off idea and though called, the ISR would ignore (do nothing with) the interrupt,.
a7
Why not just ignore the interrupt when you don't want to take any actions based on it ?
There you go: one, two three.
a7
That did it. Works fine now
Thanks for the quick replies and the education. Now I'm going for a ride
Thanks again
