Hi everyone,
Recently I brought a Blue Pill clones and I installed STM core for Arduino
I want to test the board to see whether it can be a good replacement for Due, and I find that STM32 compatible library is very limited.
My project needed to use rotary encoder, I tried the one discussed in this thread
https://forum.arduino.cc/index.php?topic=553990.0
When I tried to test the included example, the following error appears :
Compiling sketch...
"C:\Users\Home User\AppData\Local\Arduino15\packages\STM32\tools\arm-none-eabi-gcc\6-2017-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m3 -mthumb "@C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738/sketch/build_opt.h" -c -Os -std=gnu++14 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-IJ:\Arduino_Project\STM32\STM32RotaryEncoderInterruptsSerial" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\cores\arduino/avr" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\cores\arduino/stm32" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\cores\arduino/stm32/LL" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/Drivers/STM32F1xx_HAL_Driver/Inc/" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/Drivers/STM32F1xx_HAL_Driver/Src/" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/STM32F1xx/" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\variants\BLUEPILL_F103C8/usb" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/Middlewares/ST/STM32_USB_Device_Library/Core/Src" -DSTM32F1xx -DARDUINO=10802 -DARDUINO_BLUEPILL_F103C8 -DARDUINO_ARCH_STM32 -DBOARD_NAME="BLUEPILL_F103C8" -DSTM32F103xB -DHAL_UART_MODULE_ENABLED "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\tools\CMSIS\5.3.0/CMSIS/Core/Include/" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/Drivers/CMSIS/Device/ST/STM32F1xx/Include/" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\system/Drivers/CMSIS/Device/ST/STM32F1xx/Source/Templates/gcc/" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\cores\arduino" "-IC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\variants\BLUEPILL_F103C8" "-IJ:\Arduino_Project\libraries\RotaryEncoder-master\src" "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\sketch\STM32RotaryEncoderInterruptsSerial.ino.cpp" -o "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\sketch\STM32RotaryEncoderInterruptsSerial.ino.cpp.o"
In file included from J:\Arduino_Project\STM32\STM32RotaryEncoderInterruptsSerial\STM32RotaryEncoderInterruptsSerial.ino:39:0:
J:\Arduino_Project\libraries\RotaryEncoder-master\src/RotaryEncoder.h:95:21: warning: inline function 'int16_t RotaryEncoder::getPosition()' used but never defined
inline int16_t getPosition(void);
Compiling libraries...
Compiling library "RotaryEncoder-master"
Using previously compiled file: C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\libraries\RotaryEncoder-master\RotaryEncoder.cpp.o
Using previously compiled file: C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\libraries\RotaryEncoder-master\RotaryEncoderAdvanced.cpp.o
Compiling core...
Using previously compiled file: C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\core\PeripheralPins.c.o
Using previously compiled file: C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\core\variant.cpp.o
Using precompiled core
Linking everything together...
"C:\Users\Home User\AppData\Local\Arduino15\packages\STM32\tools\arm-none-eabi-gcc\6-2017-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m3 -mthumb -Os --specs=nano.specs -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align "-TC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.4.0\variants\BLUEPILL_F103C8/ldscript_cb.ld" "-Wl,-Map,C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738/STM32RotaryEncoderInterruptsSerial.ino.map" "-LC:\Users\Home User\AppData\Local\Arduino15\packages\STM32\tools\CMSIS\5.3.0/CMSIS/Lib/GCC/" -larm_cortexM3l_math -o "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738/STM32RotaryEncoderInterruptsSerial.ino.elf" "-LC:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738" -Wl,--start-group "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\sketch\STM32RotaryEncoderInterruptsSerial.ino.cpp.o" "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\libraries\RotaryEncoder-master\RotaryEncoder.cpp.o" "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\libraries\RotaryEncoder-master\RotaryEncoderAdvanced.cpp.o" "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\core\PeripheralPins.c.o" "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\core\variant.cpp.o" -Wl,--whole-archive "C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_cache_517726\core\core_STM32_stm32_GenF103_pnum_BLUEPILL_F103C8,flash_CB,upload_method_serialMethod,xserial_generic,opt_osstd,rtlib_nano_f4ae01b8b35b7a4b9d4ec525cfd5836d.a" -Wl,--no-whole-archive -lc -Wl,--end-group -lm -lgcc -lstdc++
C:\Users\HOMEUS~1\AppData\Local\Temp\arduino_build_789738\sketch\STM32RotaryEncoderInterruptsSerial.ino.cpp.o: In function `loop':
STM32RotaryEncoderInterruptsSerial.ino.cpp:(.text.loop+0x4): undefined reference to `RotaryEncoder::getPosition()'
STM32RotaryEncoderInterruptsSerial.ino.cpp:(.text.loop+0x14): undefined reference to `RotaryEncoder::getPosition()'
collect2.exe: error: ld returned 1 exit status
Using library RotaryEncoder-master at version 1.4.0 in folder: J:\Arduino_Project\libraries\RotaryEncoder-master
exit status 1
Error compiling for board Generic STM32F103 series.
I don't know why this error occurs because in the corresponding library file rotaryEncoder.cpp , there is an entry exist :
setPosition()
Manualy sets encoder position
void RotaryEncoder::setPosition(int16_t position)
_counter = position;
does anyone use this encoder library successfully ?
