I am trying to hook up the encoder e38s6g5-600b-g24n which works fine with a normal Arduino uno and yes it can take from 5v to 24v, so it shoudl be working fine.
The issue I suspect is the output voltage of the cable A and B that are not high enough to trigger the interrupt on the OPTA.
is there a way to change the sensitivity or I need to get an opamp to boost the voltage?
I tried with INPUT_PULLUP but didnt work. If I apply 12v to that interrupt pin I can see the function getting called, so I suspect the voltage coming out is not high enough
I dusted off an old project and my solution didn't work: it makes 5V internally with a 78L05. So "5-24V" is a lie, it needs 7V. I've updated the original thread. Sorry for confusion.
