I want to encode my audio file using base64.
Here is the code:
#include <SPI.h>
#include <SD.h>
#include <base64.h>
#include "Arduino.h"
#include <FS.h>
#include "Wav.h"
#include "I2S.h"
#include <WiFi.h>
#include <HTTPClient.h>
const char* ssid = "name";
const char* password = "pass";
const char* serverName = "http://***.**.**.**:8000";
const char filename[] = "/soundMont.mp3";
File file;
String get_wifi_status(int status){
switch(status){
case WL_IDLE_STATUS:
return "WL_IDLE_STATUS";
case WL_SCAN_COMPLETED:
return "WL_SCAN_COMPLETED";
case WL_NO_SSID_AVAIL:
return "WL_NO_SSID_AVAIL";
case WL_CONNECT_FAILED:
return "WL_CONNECT_FAILED";
case WL_CONNECTION_LOST:
return "WL_CONNECTION_LOST";
case WL_CONNECTED:
return "WL_CONNECTED";
case WL_DISCONNECTED:
return "WL_DISCONNECTED";
int status = WL_IDLE_STATUS;
WiFi.begin(ssid, password);
Serial.println("Connecting");
Serial.println(get_wifi_status(status));
while(WiFi.status() != WL_CONNECTED) {
// Serial.print(".");
status = WiFi.status();
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println("Initializing SD card...");
while (!SD.begin(SS)) {
Serial.write('.');
Serial.println(F("\nWiring is correct and a card is present."));
file = SD.open(filename);
if (file) {
//encoding base64
unsigned int fileSize = file.size(); // Get the file size.
uint8_t * pBuffer = (uint8_t *) malloc(fileSize); // allocate memory for the file.
if (pBuffer != nullptr) { // if allocation worked
file.read(pBuffer, fileSize); // then read the whole file into SRAM.
// >>>> this is where you do something with the buffer <<<<
String toEncode =(char*)pBuffer;
String encoded = base64::encode(toEncode);
Serial.println(encoded.length());
Serial.println(encoded);
free(pBuffer); // Free the memory that was used by the buffer.
file.close();
if(WiFi.status()== WL_CONNECTED){
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, serverName);
// If you need an HTTP request with a content type: text/plain
http.addHeader("Content-Type", "text/plain");
int httpResponseCode = http.POST("encoded");
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
// Free resources
http.end();
else {
Serial.println("WiFi Disconnected");
Serial.println("\Error: not enough memory to load audio");
Serial.println("\Error: could not find audio");
void loop() {}
when i read text file it encoded correctly and as expected. But when I encode an audio file with the same code that works perfectly with text file, it returned short encoded string ended with 2 equals sign as shown below:
Connected to WiFi network with IP Address: ***.**.**.*
12
UklGRuRXAQ==
HTTP Response code: -1
Why that's happened?
How to solve this issue?
I want to simply transfer the file (audio file) to server even without encoding. this is my goal
you need to find out what length will be the encoded version, for that you call base64_enc_len(fileSize) ➜ you need to build an char output buffer that has this size plus one byte if you want to add the trailing null char
I stuck in this issue and I feel it's easy to solve but cuz I'm a bit stressed, can you help.
if (file) {
//encoding base64
unsigned int fileSize = file.size();// Get the file size.
//char* BinaryBuffer = (char*) malloc(fileSize); // allocate memory for the file.
uint8_t * BinaryBuffer = (uint8_t *) malloc(fileSize); // allocate memory for the file.
if (BinaryBuffer != nullptr) { // if allocation worked
file.read(BinaryBuffer, fileSize); // then read the whole file into SRAM.
unsigned int base64len = encode_base64_length(fileSize);
unsigned char base64Buffer[base64len+1];
unsigned int base64_length = encode_base64((unsigned char)BinaryBuffer, sizeof(BinaryBuffer), base64Buffer);
printf("%d\n", base64_length); // Prints "8"
printf((char *) base64Buffer); // Prints "hfR1zrLD"
the error:
cast from 'uint8_t*' {aka 'unsigned char*'} to 'unsigned char' loses precision [-fpermissive]
I'm forced to use uint8_t* to use
to read the whole file into SRAM.
so I faced the error in
as they expected unsigned char
Kindly, I need your support, highly appreciated.
The type of your BinaryBuffer is pointer to unsigned char, not the unsigned char.
The function encode_base64 need a pointer too, so you have not cast it to unsigned char:
unsigned int base64_length = encode_base64(BinaryBuffer, sizeof(BinaryBuffer), base64Buffer);
@b707@J-M-L
Thank you all, based on your replies and the library I used, I came up with this code:
```cpp
#include <SPI.h>
#include <SD.h>
//#include <base64.h>
#include "base64.hpp"
#include <FS.h>
#include "Wav.h"
#include "I2S.h"
#include <WiFi.h>
const char* serverName = "http://xxx.xx.xx.xx:8000";
File file;
Serial.write('.');
if (file) {
//encoding base64
//Note1: you build your binary buffer
//Note2:you calculate the length of base64 string needed for a given number of binary bytes (including a trailing null) and allocate a buffer of that size
//Note3: you encode and add the trailing null (if the library does not do it) * I think the lib do it, kindly correct me if I'm wrong
free(BinaryBuffer); // Free the memory that was used by the buffer.
free(base64Buffer);
file.close();
void loop() {}
Did I apply the instruction correctly? is it what you meant?
I recommend you use malloc() for this buffer as well. That way you won't overflow the stack if there isn't enough stack space.
//Note2: you calculate the length of base64 string needed for a given number of binary bytes (including a trailing null) and allocate a buffer of that size
unsigned char* base64Buffer = malloc(base64len+1);
if (base64Buffer != NULL)
print((char *)base64Buffer);
free(base64Buffer);
Serial.println("\Error: not enough memory to convert");
The malloc way has significant advantage: in case of memory lacking malloc just return nothing and don't crash the entire program. Of course, base64 array won't be encoded, but the rest of routine still works.
