Endat Interface?
Hi
Are you able to implement the Endat Interface? Because I am also trying to Implement this to read value from Encoder. I am using an Arduino Mega and two RS485 MKR shield but I need some help If you help in this regard.
Thanks for this in advance.
Topic split from another
Please do not hijack old topics
Ok ok. I will rename it.
You have missed the point
Your post above has been moved to its own topic rather than being attached to the 6 month old one where you originally posted it
The original topic has been closed
Yes I understand. Thanks
EnDat 2.2?
Yes I went to this documentation. But need some help if someone really implemented this thing with Arduino Master.
Im also interested, I have some lenght measuring Systems from heidenhein around i I would like to use in a cnc project.
did you find a way to use arduino as endata master card?
I think this clock generator Adafruit Si5351A Clock Generator Breakout Board - 8KHz to 160MHz : ID 2045 : $7.95 : Adafruit Industries, Unique & fun DIY electronics and kits could be used for the clock signal
I found this transceptor for the RS485 interphase https://es.farnell.com/texas-instruments/sn65hvd78d/transceiver-rs485-50mbps-soic/dp/3121386
