Sorry for the slow response I live in sweden
Did you run a test on the standalone OLED?
No I didn't
Verify the OLED has the correct library. Inside the library are example sketches.
thank you
Here is the library repository online... you can also find it in your IDE >> FILES >> EXAMPLES >> SSD1306 >> (examples)
If you will not be displaying graphics on the OLED, maybe you can do without the GFX library?
If your OLED uses the Adafruit 1306 OLED library, this should show a page of ASCII characters.
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1 // -1 if sharing Arduino reset pin
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3D)) {
Serial.println(F("SSD1306 allocation failed"));
while (1);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.display();
display.setCursor(0, 0);
for (int i = 33; i < 201; i++) {
display.write(i);
display.display();
// empty
Here the screen I used for my project maybe it was the model the problem
You need to find the library that supports the OLED. Look for identifying information on the OLED.
ok thank
I did some test and the screen won't open but on the arduino ide it say that it didn't
initialized so maybe it the adress that isn't right
#include <Wire.h>
Wire.begin();
Serial.println("Scanning I2C devices...");
for (byte address = 1; address < 127; address++) {
Wire.beginTransmission(address);
if (Wire.endTransmission() == 0) {
Serial.print("I2C device found at address 0x");
if (address < 16) Serial.print("0");
Serial.println(address, HEX);
delay(10);
Serial.println("Scanning done.");
void loop() {}
That is a code I will use to verify the adress, is it ok ?
You are missing the library for the OLED, and creating the OLED instance.
But it only for scanning the address so do I really need the library ?
Search "arduino libraries" and tell me why you are wrong.
Sorry, but I can't tell you how I am wrong but I know I am wrong
Correct , the i2c scanner in Arduino examples is the same.
No Libraries except for <Wire.h>
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
int nDevices = 0;
Serial.println("Scanning...");
for (byte address = 1; address < 127; ++address) {
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
byte error = Wire.endTransmission();
if (error == 0) {
if (address < 16) {
Serial.print("0");
Serial.print(address, HEX);
Serial.println(" !");
++nDevices;
} else if (error == 4) {
Serial.print("Unknown error at address 0x");
if (address < 16) {
Serial.print("0");
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // Wait 5 seconds for next scan
thank
The recent reference (beginning post #19) was "OLED not working" and keeps getting sent to to "do the I2C scanner" when the program clearly NEEDS the correct library for the OLED.
I refer to the scanner only , no Oled libraries needed.
I was and am referring to Post #19 and after... where the question was OLED not working... until the "scanner" instructions derailed it.
I was referring to Post#32 , no derailing , different questions different answers.
