Multiple Sensors Working Together
Hello friends. I am making a project which includes sensors; MPU6050, MAX30102, BMP180, OLED. The point is to measure various parameters and transmit information to app and screen. Now not being much of an expert, I studied connection pinout for each sensor individually and combined all that knowledge and connected on the breadboard. I am using an Arduino nano. Now the problem comes when I try to run a sketch for the setup and it does not work on it. So either the code is at fault or the hardware connections are. These are my current connections:
BMP180:
vcc=ard 3.3V
GND=ard gnd
SCL=ARD A5
SDA=ARD A4
mpu6050:
VCC=5V
GND=gnd
SCL=A5
SDA=A4
MAX30102:
Vin=5V
GND=gnd
SCL=A5
SDA=A4
OLED display:
GND=gnd
VCC=5V
SCL=A5
SDA=A4
All these connections have been made simultaneously on one board. Please let me know if these connections are feasible. If they are then I will need to look towards debugging software.
EDIT: I am including code that worked fine separately for each sensor. I am not including the merged code as I'm sure my beginner merging skills have not done it justice. I would be eternally grateful if someone could help merge these four code sets successfully.
Code for MPU6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
void setup(void) {
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MPU6050 test!");
  // Try to initialize!
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  //setupt motion detection
  mpu.setHighPassFilter(MPU6050_HIGHPASS_0_63_HZ);
  mpu.setMotionDetectionThreshold(1);
  mpu.setMotionDetectionDuration(20);
  mpu.setInterruptPinLatch(true);	// Keep it latched.  Will turn off when reinitialized.
  mpu.setInterruptPinPolarity(true);
  mpu.setMotionInterrupt(true);
  Serial.println("");
  delay(100);
  if(mpu.getMotionInterruptStatus()) {
    /* Get new sensor events with the readings */
    sensors_event_t a, g, temp;
    mpu.getEvent(&a, &g, &temp);
    /* Print out the values */
    Serial.print("AccelX:");
    Serial.print(a.acceleration.x);
    Serial.print(",");
    Serial.print("AccelY:");
    Serial.print(a.acceleration.y);
    Serial.print(",");
    Serial.print("AccelZ:");
    Serial.print(a.acceleration.z);
    Serial.print(", ");
    Serial.print("GyroX:");
    Serial.print(g.gyro.x);
    Serial.print(",");
    Serial.print("GyroY:");
    Serial.print(g.gyro.y);
    Serial.print(",");
    Serial.print("GyroZ:");
    Serial.print(g.gyro.z);
    Serial.println("");
  delay(10);
MAX30102
  Optical Heart Rate Detection (PBA Algorithm) using the MAX30105 Breakout
  By: Nathan Seidle @ SparkFun Electronics
  Date: October 2nd, 2016
  https://github.com/sparkfun/MAX30105_Breakout
  This is a demo to show the reading of heart rate or beats per minute (BPM) using
  a Penpheral Beat Amplitude (PBA) algorithm.
  It is best to attach the sensor to your finger using a rubber band or other tightening
  device. Humans are generally bad at applying constant pressure to a thing. When you
  press your finger against the sensor it varies enough to cause the blood in your
  finger to flow differently which causes the sensor readings to go wonky.
  Hardware Connections (Breakoutboard to Arduino):
  -5V = 5V (3.3V is allowed)
  -GND = GND
  -SDA = A4 (or SDA)
  -SCL = A5 (or SCL)
  -INT = Not connected
  The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V
  but it will also run at 3.3V.
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
  Serial.println("Initializing...");
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println("MAX30105 was not found. Please check wiring/power. ");
    while (1);
  Serial.println("Place your index finger on the sensor with steady pressure.");
  particleSensor.setup(); //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
  long irValue = particleSensor.getIR();
  if (checkForBeat(irValue) == true)
    //We sensed a beat!
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    if (beatsPerMinute < 255 && beatsPerMinute > 20)
      rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
      rateSpot %= RATE_SIZE; //Wrap variable
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  Serial.print("IR=");
  Serial.print(irValue);
  Serial.print(", BPM=");
  Serial.print(beatsPerMinute);
  Serial.print(", Avg BPM=");
  Serial.print(beatAvg);
  if (irValue < 50000)
    Serial.print(" No finger?");
OLED
This is an example for our Monochrome OLEDs based on SSD1306 drivers
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/category/63_98
This example is for a 128x64 size display using I2C to communicate
3 pins are required to interface (2 I2C and one reset)
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
I change the adafruit SSD1306 to SH1106
SH1106 driver don't provide several functions such as scroll commands.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH1106.h>
#define OLED_RESET 4
Adafruit_SH1106 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
#if (SH1106_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SH1106.h!");
#endif
void setup()   {
  // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  display.begin(SH1106_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  // init done
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  display.display();
  delay(2000);
  // Clear the buffer.
  display.clearDisplay();
  // draw a single pixel
  display.drawPixel(10, 10, WHITE);
  // Show the display buffer on the hardware.
  // NOTE: You _must_ call display after making any drawing commands
  // to make them visible on the display hardware!
  display.display();
  delay(2000);
  // draw many lines
  testdrawline();
  display.display();
  delay(2000);
  // draw rectangles
  testdrawrect();
  display.display();
  delay(2000);
  // draw multiple rectangles
  testfillrect();
  display.display();
  delay(2000);
  // draw mulitple circles
  testdrawcircle();
  display.display();
  delay(2000);
  // draw a white circle, 10 pixel radius
  display.fillCircle(display.width()/2, display.height()/2, 10, WHITE);
  display.display();
  delay(2000);
  testdrawroundrect();
  delay(2000);
  testfillroundrect();
  delay(2000);
  testdrawtriangle();
  delay(2000);
  testfilltriangle();
  delay(2000);
  // draw the first ~12 characters in the font
  testdrawchar();
  display.display();
  delay(2000);
  // draw scrolling text
 /* testscrolltext();
  delay(2000);
  display.clearDisplay();*/
  // text display tests
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.println("Hello, world!");
  display.setTextColor(BLACK, WHITE); // 'inverted' text
  display.println(3.141592);
  display.setTextSize(2);
  display.print("0x"); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
  // miniature bitmap display
  display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  display.display();
  // invert the display
  display.invertDisplay(true);
  display.invertDisplay(false);
  // draw a bitmap icon and 'animate' movement
  testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  // initialize
  for (uint8_t f=0; f< NUMFLAKES; f++) {
    icons[f][XPOS] = random(display.width());
    icons[f][YPOS] = 0;
    icons[f][DELTAY] = random(5) + 1;
    Serial.print("x: ");
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(" y: ");
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(" dy: ");
    Serial.println(icons[f][DELTAY], DEC);
  while (1) {
    // draw each icon
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], logo16_glcd_bmp, w, h, WHITE);
    display.display();
    delay(200);
    // then erase it + move it
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS],  logo16_glcd_bmp, w, h, BLACK);
      // move it
      icons[f][YPOS] += icons[f][DELTAY];
      // if its gone, reinit
      if (icons[f][YPOS] > display.height()) {
	icons[f][YPOS] = 0;
void testdrawchar(void) {
  for (uint8_t i=0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    if ((i > 0) && (i % 21 == 0))
      display.println();
  display.display();
void testdrawcircle(void) {
  for (int16_t i=0; i<display.height(); i+=2) {
    display.drawCircle(display.width()/2, display.height()/2, i, WHITE);
    display.display();
void testfillrect(void) {
  uint8_t color = 1;
  for (int16_t i=0; i<display.height()/2; i+=3) {
    // alternate colors
    display.fillRect(i, i, display.width()-i*2, display.height()-i*2, color%2);
    display.display();
    color++;
void testdrawtriangle(void) {
  for (int16_t i=0; i<min(display.width(),display.height())/2; i+=5) {
    display.drawTriangle(display.width()/2, display.height()/2-i,
                     display.width()/2-i, display.height()/2+i,
                     display.width()/2+i, display.height()/2+i, WHITE);
    display.display();
void testfilltriangle(void) {
  uint8_t color = WHITE;
  for (int16_t i=min(display.width(),display.height())/2; i>0; i-=5) {
    display.fillTriangle(display.width()/2, display.height()/2-i,
    if (color == WHITE) color = BLACK;
    else color = WHITE;
    display.display();
void testdrawroundrect(void) {
  for (int16_t i=0; i<display.height()/2-2; i+=2) {
    display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, WHITE);
    display.display();
void testfillroundrect(void) {
    display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, color);
    else color = WHITE;
    display.display();
void testdrawrect(void) {
  for (int16_t i=0; i<display.height()/2; i+=2) {
    display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
    display.display();
void testdrawline() {
  for (int16_t i=0; i<display.width(); i+=4) {
    display.drawLine(0, 0, i, display.height()-1, WHITE);
    display.display();
  for (int16_t i=0; i<display.height(); i+=4) {
    display.drawLine(0, 0, display.width()-1, i, WHITE);
    display.display();
  delay(250);
    display.drawLine(0, display.height()-1, i, 0, WHITE);
    display.display();
  for (int16_t i=display.height()-1; i>=0; i-=4) {
    display.drawLine(0, display.height()-1, display.width()-1, i, WHITE);
    display.display();
  delay(250);
  for (int16_t i=display.width()-1; i>=0; i-=4) {
    display.drawLine(display.width()-1, display.height()-1, i, 0, WHITE);
    display.display();
    display.drawLine(display.width()-1, display.height()-1, 0, i, WHITE);
    display.display();
  delay(250);
    display.drawLine(display.width()-1, 0, 0, i, WHITE);
    display.display();
    display.drawLine(display.width()-1, 0, i, display.height()-1, WHITE);
    display.display();
  delay(250);
/*void testscrolltext(void) {
  display.setCursor(10,0);
  display.println("scroll");
  display.display();
  display.startscrollright(0x00, 0x0F);
  delay(2000);
  display.stopscroll();
  display.startscrollleft(0x00, 0x0F);
  delay(2000);
  display.startscrolldiagright(0x00, 0x07);
  delay(2000);
  display.startscrolldiagleft(0x00, 0x07);
  delay(2000);
BMP180
/* SFE_BMP180 altitude example sketch
This sketch shows how to use the Bosch BMP180 pressure sensor
as an altimiter.
https://www.sparkfun.com/products/11824
Like most pressure sensors, the BMP180 measures absolute pressure.
Since absolute pressure varies with altitude, you can use the pressure
to determine your altitude.
Because pressure also varies with weather, you must first take a pressure
reading at a known baseline altitude. Then you can measure variations
from that pressure
Hardware connections:
- (GND) to GND
+ (VDD) to 3.3V
(WARNING: do not connect + to 5V or the sensor will be damaged!)
You will also need to connect the I2C pins (SCL and SDA) to your
Arduino. The pins are different on different Arduinos:
Any Arduino pins labeled:  SDA  SCL
Uno, Redboard, Pro:        A4   A5
Mega2560, Due:             20   21
Leonardo:                   2    3
Leave the IO (VDDIO) pin unconnected. This pin is for connecting
the BMP180 to systems with lower logic levels such as 1.8V
Have fun! -Your friends at SparkFun.
The SFE_BMP180 library uses floating-point equations developed by the
Weather Station Data Logger project: http://wmrx00.sourceforge.net/
Our example code uses the "beerware" license. You can do anything
you like with this code. No really, anything. If you find it useful,
buy me a beer someday.
V10 Mike Grusin, SparkFun Electronics 10/24/2013
// Your sketch must #include this library, and the Wire library.
// (Wire is a standard library included with Arduino.):
#include <SFE_BMP180.h>
#include <Wire.h>
// You will need to create an SFE_BMP180 object, here called "pressure":
SFE_BMP180 pressure;
double baseline; // baseline pressure
  Serial.println("REBOOT");
  // Initialize the sensor (it is important to get calibration values stored on the device).
  if (pressure.begin())
    Serial.println("BMP180 init success");
    // Oops, something went wrong, this is usually a connection problem,
    // see the comments at the top of this sketch for the proper connections.
    Serial.println("BMP180 init fail (disconnected?)\n\n");
    while(1); // Pause forever.
  // Get the baseline pressure:
  baseline = getPressure();
  Serial.print("baseline pressure: ");
  Serial.print(baseline);
  Serial.println(" mb");
  double a,P;
  // Get a new pressure reading:
  P = getPressure();
  // Show the relative altitude difference between
  // the new reading and the baseline reading:
  a = pressure.altitude(P,baseline);
  Serial.print("relative altitude: ");
  if (a >= 0.0) Serial.print(" "); // add a space for positive numbers
  Serial.print(a,1);
  Serial.print(" meters, ");
  Serial.print(a*3.28084,0);
  Serial.println(" feet");
double getPressure()
  char status;
  double T,P,p0,a;
  // You must first get a temperature measurement to perform a pressure reading.
  // Start a temperature measurement:
  // If request is successful, the number of ms to wait is returned.
  // If request is unsuccessful, 0 is returned.
  status = pressure.startTemperature();
  if (status != 0)
    // Wait for the measurement to complete:
    delay(status);
    // Retrieve the completed temperature measurement:
    // Note that the measurement is stored in the variable T.
    // Use '&T' to provide the address of T to the function.
    // Function returns 1 if successful, 0 if failure.
    status = pressure.getTemperature(T);
    if (status != 0)
      // Start a pressure measurement:
      // The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
      status = pressure.startPressure(3);
      if (status != 0)
        delay(status);
        // Retrieve the completed pressure measurement:
        // Note that the measurement is stored in the variable P.
        // Use '&P' to provide the address of P.
        // Note also that the function requires the previous temperature measurement (T).
        // (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
        status = pressure.getPressure(P,T);
        if (status != 0)
          return(P);
        else Serial.println("error retrieving pressure measurement\n");
      else Serial.println("error starting pressure measurement\n");
    else Serial.println("error retrieving temperature measurement\n");
  else Serial.println("error starting temperature measurement\n");
The merged code
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math
#include <PulseSensorPlayground.h>
#include <Wire.h>
//bpm_oloed_buzzer
#include <Adafruit_GFX.h>        //OLED libraries
#include "MAX30105.h"           //MAX3010x library
#include "heartRate.h"          //Heart rate calculating algorithm
//for lm35
const int lm35_pin = A1;  /* LM35 O/P pin */
#define ALTITUDE 10 // Altitude of SparkFun's HQ in Boulder, CO. in meters
byte rateSpot = 0;
int beatAvg;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET    -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define sh1106_swap(a, b) { SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET  }
Adafruit_SH1106 display  (SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //Declaring the display name (display)
static const unsigned char PROGMEM logo2_bmp[] =
{ 0x03, 0xC0, 0xF0, 0x06, 0x71, 0x8C, 0x0C, 0x1B, 0x06, 0x18, 0x0E, 0x02, 0x10, 0x0C, 0x03, 0x10,              //Logo2 and Logo3 are two bmp pictures that display on the OLED if called
  0x04, 0x01, 0x10, 0x04, 0x01, 0x10, 0x40, 0x01, 0x10, 0x40, 0x01, 0x10, 0xC0, 0x03, 0x08, 0x88,
  0x02, 0x08, 0xB8, 0x04, 0xFF, 0x37, 0x08, 0x01, 0x30, 0x18, 0x01, 0x90, 0x30, 0x00, 0xC0, 0x60,
  0x00, 0x60, 0xC0, 0x00, 0x31, 0x80, 0x00, 0x1B, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x04, 0x00,
static const unsigned char PROGMEM logo3_bmp[] =
{ 0x01, 0xF0, 0x0F, 0x80, 0x06, 0x1C, 0x38, 0x60, 0x18, 0x06, 0x60, 0x18, 0x10, 0x01, 0x80, 0x08,
  0x20, 0x01, 0x80, 0x04, 0x40, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x02, 0xC0, 0x00, 0x08, 0x03,
  0x80, 0x00, 0x08, 0x01, 0x80, 0x00, 0x18, 0x01, 0x80, 0x00, 0x1C, 0x01, 0x80, 0x00, 0x14, 0x00,
  0x80, 0x00, 0x14, 0x00, 0x80, 0x00, 0x14, 0x00, 0x40, 0x10, 0x12, 0x00, 0x40, 0x10, 0x12, 0x00,
  0x7E, 0x1F, 0x23, 0xFE, 0x03, 0x31, 0xA0, 0x04, 0x01, 0xA0, 0xA0, 0x0C, 0x00, 0xA0, 0xA0, 0x08,
  0x00, 0x60, 0xE0, 0x10, 0x00, 0x20, 0x60, 0x20, 0x06, 0x00, 0x40, 0x60, 0x03, 0x00, 0x40, 0xC0,
  0x01, 0x80, 0x01, 0x80, 0x00, 0xC0, 0x03, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0x30, 0x0C, 0x00,
  0x00, 0x08, 0x10, 0x00, 0x00, 0x06, 0x60, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x01, 0x80, 0x00
const int PulseWire = 0; // 'S' Signal pin connected to A0
// const int LED13 = 13;          // The on-board Arduino LED
int Threshold = 550; // Determine which Signal to "count as a beat" and which to ignore
PulseSensorPlayground pulseSensor;
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
float ax = 0, ay = 0, az = 0, gx = 0, gy = 0, gz = 0;
const int buttonPin = 6;
const int ledPin = 3;
// int data[STORE_SIZE][5]; //array for saving past data
// byte currentIndex=0; //stores current data array index (0-255)
boolean fall = false;     // stores if a fall has occurred
boolean trigger1 = false; // stores if first trigger (lower threshold) has occurred
boolean trigger2 = false; // stores if second trigger (upper threshold) has occurred
boolean trigger3 = false; // stores if third trigger (orientation change) has occurred
byte trigger1count = 0; // stores the counts past since trigger 1 was set true
byte trigger2count = 0; // stores the counts past since trigger 2 was set true
byte trigger3count = 0; // stores the counts past since trigger 3 was set true
int angleChange = 0;
// variable for storing the pushbutton status
int buttonState = 0;
int ledState = 0;
int fall_message_ouput = 7;
  //bpm
  display.begin(SH1106_SWITCHCAPVCC, 0x3D);
  display.display();
  delay(3000);
  particleSensor.begin(Wire, I2C_SPEED_FAST); //Use default I2C port, 400kHz speed
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B); // PWR_MGMT_1 register
  Wire.write(0);    // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  // set input pin of button and output pin of led
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  // Configure the PulseSensor object, by assigning our variables to it
  pulseSensor.analogInput(PulseWire);
  // pulseSensor.blinkOnPulse(LED13);       // Blink on-board LED with heartbeat
  pulseSensor.setThreshold(Threshold);
  if (pulseSensor.begin())
    Serial.println("PulseSensor object created!");
  //bmp
    Serial.println("BMP180 init fail\n\n");
    while (1); // Pause forever.
    //lm35
  // read the state of the pushbutton value
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH
  if (buttonState == HIGH)
    ledState = !ledState;
  if (ledState == HIGH)
    // turn LED on
    digitalWrite(ledPin, HIGH);
    // turn LED off
    digitalWrite(ledPin, LOW);
  // heartbeat sensor
  int myBPM = pulseSensor.getBeatsPerMinute(); // Calculates BPM
  if (pulseSensor.sawStartOfBeat())
  { // Constantly test to see if a beat happened
    Serial.println("Heartbeat  BPM: " + myBPM); // If true, print a message                       // Print the BPM value
  if (myBPM > 170)
  { // high heart rate detection
    Serial.println("High Heartrate Alert: Your heart rate is above 200!");
    digitalWrite(fall_message_ouput, HIGH);
    digitalWrite(fall_message_ouput, LOW);
  if (myBPM < 27)
    Serial.println("Low Heartrate Alert: Your heart rate is below 27!");
  // accelerator
  mpu_read();
  // 2050, 77, 1947 are values for calibration of accelerometer
  //  values may be different for you
  ax = (AcX - 2050) / 16384.00;
  ay = (AcY - 77) / 16384.00;
  az = (AcZ - 1947) / 16384.00;
  // 270, 351, 136 for gyroscope
  gx = (GyX + 270) / 131.07;
  gy = (GyY - 351) / 131.07;
  gz = (GyZ + 136) / 131.07;
  // calculating Amplitute vactor for 3 axis
  float Raw_AM = pow(pow(ax, 2) + pow(ay, 2) + pow(az, 2), 0.5);
  int AM = Raw_AM * 10; // as values are within 0 to 1, I multiplied
  // it by for using if else conditions
  // Serial.println(analogRead(A1));
  // if(digitalRead(A3) == HIGH)
  //   Serial.println("A3: SOS"+digitalRead(A3));
  Serial.println(AM);
  // Serial.println(PM);
  // delay(5);
  if (trigger3 == true)
    trigger3count++;
    // Serial.println(trigger3count);
    if (trigger3count >= 10)
      angleChange = pow(pow(gx, 2) + pow(gy, 2) + pow(gz, 2), 0.5);
      // delay(10);
      Serial.println(angleChange);
      if ((angleChange >= 0) && (angleChange <= 10))
      { // if orientation changes remains between 0-10 degrees
        fall = true;
        trigger3 = false;
        trigger3count = 0;
      { // user regained normal orientation
        trigger3 = false;
        trigger3count = 0;
        Serial.println("TRIGGER 3 DEACTIVATED");
  if (fall == true)
  { // in event of a fall detection
    Serial.println("FALL DETECTED");
    fall = false;
    // exit(1);
  if (trigger2count >= 6)
  { // allow 0.5s for orientation change
    trigger2 = false;
    trigger2count = 0;
    Serial.println("TRIGGER 2 DECACTIVATED");
  if (trigger1count >= 6)
  { // allow 0.5s for AM to break upper threshold
    trigger1 = false;
    trigger1count = 0;
    Serial.println("TRIGGER 1 DECACTIVATED");
  if (trigger2 == true)
    trigger2count++;
    // angleChange=acos(((double)x*(double)bx+(double)y*(double)by+(double)z*(double)bz)/(double)AM/(double)BM);
    if (angleChange >= 30 && angleChange <= 400)
    { // if orientation changes by between 80-100 degrees
      trigger3 = true;
      trigger2 = false;
      trigger2count = 0;
      Serial.println("TRIGGER 3 ACTIVATED");
  if (trigger1 == true)
    trigger1count++;
    if (AM >= 12)
    { // if AM breaks upper threshold (3g)
      trigger2 = true;
      Serial.println("TRIGGER 2 ACTIVATED");
      trigger1 = false;
      trigger1count = 0;
  if (AM <= 2 && trigger2 == false)
  { // if AM breaks lower threshold (0.4g)
    trigger1 = true;
    Serial.println("TRIGGER 1 ACTIVATED");
  // It appears that delay is needed in order not to clog the port
  delay(100);
void mpu_read()
  Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
  AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  //bmp
void bmp_read()
  char status;
  double T, P, p0, a;
  // Loop here getting pressure readings every 10 seconds.
  // If you want sea-level-compensated pressure, as used in weather reports,
  // you will need to know the altitude at which your measurements are taken.
  // We're using a constant called ALTITUDE in this sketch:
  Serial.print("provided altitude: ");
  Serial.print(ALTITUDE, 0);
  Serial.print(ALTITUDE * 3.28084, 0);
  // If you want to measure altitude, and not pressure, you will instead need
  // to provide a known baseline pressure. This is shown at the end of the sketch.
  if (status != 0)
    delay(status);
    if (status != 0)
      // Print out the measurement:
      Serial.print("temperature: ");
      Serial.print(T, 2);
      Serial.print(" deg C, ");
      Serial.print((9.0 / 5.0)*T + 32.0, 2);
      Serial.println(" deg F");
      if (status != 0)
        delay(status);
        status = pressure.getPressure(P, T);
        if (status != 0)
          Serial.print("absolute pressure: ");
          Serial.print(P, 2);
          Serial.print(" mb, ");
          Serial.print(P * 0.0295333727, 2);
          Serial.println(" inHg");
          // The pressure sensor returns abolute pressure, which varies with altitude.
          // To remove the effects of altitude, use the sealevel function and your current altitude.
          // This number is commonly used in weather reports.
          // Parameters: P = absolute pressure in mb, ALTITUDE = current altitude in m.
          // Result: p0 = sea-level compensated pressure in mb
          p0 = pressure.sealevel(P, ALTITUDE); // we're at 1655 meters (Boulder, CO)
          Serial.print("relative (sea-level) pressure: ");
          Serial.print(p0, 2);
          Serial.print(p0 * 0.0295333727, 2);
          // On the other hand, if you want to determine your altitude from the pressure reading,
          // use the altitude function along with a baseline pressure (sea-level or other).
          // Parameters: P = absolute pressure in mb, p0 = baseline pressure in mb.
          // Result: a = altitude in m.
          a = pressure.altitude(P, p0);
          Serial.print("computed altitude: ");
          Serial.print(a, 0);
          Serial.print(a * 3.28084, 0);
  delay(5000);  // Pause for 5 seconds.
void lm35_read()
  int temp_adc_val;
  float temp_val;
  temp_adc_val = analogRead(lm35_pin); /* Read Temperature */
  temp_val = (temp_adc_val * 4.88); /* Convert adc value to equivalent voltage */
  temp_val = (temp_val / 10); /* LM35 gives output of 10mv/°C */
  Serial.print("Temperature = ");
  Serial.print(temp_val);
  Serial.print(" Degree Celsius\n");
I want the code to read the parameters via respective sensors and display results on serial monitor. Whereas the code is not giving results, even though compiling just fine. Is the merging at fault, or is there something else? How do I determine, and where am I going wrong.
meanwhile, sending schematic...
All sensors must work in sync and display real-time orientation, temperature, altitude, pressure, heart rate and spo2.
After you made all the connections, and you ran I2C scanner what were your results?
Oh, yes to being possible.
Connections seem ok, I also recommend you run i2c scanner sketch.
Also please post links to the sensor modules and oled you are using.
What is the problem that you're facing? Is the code not being compiled at all? Or desired output is not being shown after uploading the code?
Hmm. I did run this, but can't recall results. I'll try again.
Instead of hooking them all up at once, do them one at a time. Connect one sensor to the Nano. Make sure that the I2C scanner sees it (if it is I2C). Load up example code form a library or find example code for just that one sensor. Get the sensor working by sending its output to serial monitor. Do the same with each sensor and the LCD. Once you have code for each sensor and understand how they work it will be much easier to build your app.
Yup hook one up, run the scanner, hook another up run the scanner, hook another up and run the scanner kind of thing.
MPU6050
MAX30102
OLED 128x64, 1.3", SH1106 driver compatible
BMP180
Code is compiling and uploading just fine. But no result on serial monitor and plotter. Also as I've merged code of various sensors, I was wondering that perhaps I should include a menu option in the merged code, how else will the monitor know which sensor parameter to display at any given time
What code? Where are the results of the I2C scan you performed?
Don't you think you should make it work before worrying about things like that? Anyway, it's a design decision that depends on the requirements of the application, which we don't know.
I did exactly this! :'l I connected each sensor separately to arduino, ran the example code; each sensor gave results on the serial plotter. But when I connected all sensors together as per above mentioned connections, and merged all the already tested separate codes, that's when no result came on serial monitor, still compiled and uploaded fine though. I'm beginning to think I must have not merged correctly, but again, it gives no error; then how is the merging at fault
What code posted in code tags are you having a problem with?
If you do not want to post your code then my guess is that the code on line 533 is wrong.
I would suggest that you post the code. Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please post a schematic. Written descriptions are always more ambiguous than a drawing. Hand drawn, photographed and posted is fine. Include all pin names/numbers, components, their part numbers and/or values and power supplies.
What does the code actually do and how is that different from what you expect.
Code for MPU6050
#include <Wire.h>
void setup(void) {
  while (!Serial)
  if (!mpu.begin()) {
    while (1) {
      delay(10);
  Serial.println("");
  delay(100);
    Serial.print(",");
    Serial.print(",");
    Serial.print(", ");
    Serial.print(",");
    Serial.print(",");
    Serial.println("");
  delay(10);
MAX30102
  -GND = GND
  -SDA = A4 (or SDA)
  -SCL = A5 (or SCL)
#include <Wire.h>
byte rateSpot = 0;
int beatAvg;
    while (1);
    //We sensed a beat!
      beatAvg = 0;
OLED
#include <SPI.h>
#include <Wire.h>
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#endif
void setup()   {
  // init done
  display.display();
  delay(2000);
  display.display();
  delay(2000);
  // draw many lines
  testdrawline();
  display.display();
  delay(2000);
  // draw rectangles
  testdrawrect();
  display.display();
  delay(2000);
  testfillrect();
  display.display();
  delay(2000);
  testdrawcircle();
  display.display();
  delay(2000);
  display.display();
  delay(2000);
  delay(2000);
  delay(2000);
  testdrawtriangle();
  delay(2000);
  testfilltriangle();
  delay(2000);
  testdrawchar();
  display.display();
  delay(2000);
  delay(2000);
  display.display();
  delay(2000);
  display.display();
  // initialize
    icons[f][YPOS] = 0;
  while (1) {
    // draw each icon
    display.display();
    delay(200);
      // move it
	icons[f][YPOS] = 0;
    display.write(i);
      display.println();
  display.display();
    display.display();
  uint8_t color = 1;
    // alternate colors
    display.display();
    color++;
    display.display();
    else color = WHITE;
    display.display();
    display.display();
    else color = WHITE;
    display.display();
    display.display();
    display.display();
    display.display();
  delay(250);
    display.display();
    display.display();
  delay(250);
    display.display();
    display.display();
  delay(250);
    display.display();
    display.display();
  delay(250);
  display.display();
  delay(2000);
  delay(2000);
  delay(2000);
  delay(2000);
BMP180
as an altimiter.
from that pressure
- (GND) to GND
+ (VDD) to 3.3V
Leonardo:                   2    3
#include <Wire.h>
  double a,P;
  P = getPressure();
  Serial.print(a,1);
  char status;
  double T,P,p0,a;
  if (status != 0)
    delay(status);
    if (status != 0)
      if (status != 0)
        delay(status);
        if (status != 0)
          return(P);
Where is the merged code? You did not have issue with the non-merged codes.
Alright. I need to see results when all sensors are running together. But no result on serial monitor. Whereas the code runs fine separately
Can't do much to help without seeing the code and schematic. Crystal ball out for oil change.
All the included codes work fine separately
