Erreur compilation sur horloge ds3231 et ws2812b 32x8
Bonjour à tous. A 70 printemps passé, je me remet au micro contrôleur. J’ ai copier un sketch sur le net mais a la compilation il y a une ou plusieurs erreur. Pouvez vous m’aider SVP?
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <Wire.h>
#include <DS3231.h>
struct ts temps;
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, 2,
                                               NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT + NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
                                               NEO_GRB + NEO_KHZ800);
  matrix.begin();
  matrix.setTextWrap(false);
  matrix.setBrightness(10);
  Wire.begin();
  DS3231_init(DS3231_INTCN);
  DS3231_get(&temps);
  int heure = temps.hour;
  int minute = temps.min;
  matrix.fillScreen(0);
  matrix.setTextColor(matrix.Color(0, 0, 200));
  matrix.setCursor(25, 1);
  matrix.print(minute % 10);
  matrix.setCursor(19, 1);
  matrix.print(minute / 10);
  matrix.setTextColor(matrix.Color(100, 100, 100));
  matrix.setCursor(13, 1);
  matrix.print(":");
  matrix.setCursor(14, 1);
  matrix.print(":");
  matrix.setCursor(8, 1);
  matrix.print(heure % 10);
  matrix.setCursor(2, 1);
  matrix.print(heure / 10);
  matrix.show();
  matrix.show();
Voici l'erreur:
loading library from c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\dht22-tm1637: invalid library: no header files foundloading library from c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812: invalid library: no header files found
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour Adafruit_GFX.h: [Adafruit GFX Library@1.12.4]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit GFX Library@1.12.4]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour Adafruit_I2CDevice.h: [Adafruit BusIO@1.17.4]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit BusIO@1.17.4]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour Adafruit_NeoMatrix.h: [Adafruit NeoMatrix@1.3.3]
ResolveLibrary(Adafruit_NeoMatrix.h)
  -> candidates: [Adafruit NeoMatrix@1.3.3]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour Adafruit_NeoPixel.h: [Adafruit NeoPixel@1.15.2]
ResolveLibrary(Adafruit_NeoPixel.h)
  -> candidates: [Adafruit NeoPixel@1.15.2]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
Alternative pour DS3231.h: [DS3231@1.1.2]
ResolveLibrary(DS3231.h)
  -> candidates: [DS3231@1.1.2]
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_GenericDevice.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\Wire.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\utility\twi.c -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src\SPI.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix\Adafruit_NeoMatrix.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_Neopixel_RP2.cpp -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\esp.c -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\esp8266.c -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\kendyte_k210.c -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel\psoc6.c -o nul
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 c:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231\DS3231.cpp -o nul
Generating function prototypes...
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o C:\Users\hacqu\AppData\Local\Temp\484523495\sketch_merged.cpp
C:\Users\hacqu\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\hacqu\AppData\Local\Temp\484523495\sketch_merged.cpp
Compilation du croquis...
"C:\\Users\\hacqu\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\hacqu\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\hacqu\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-Ic:\\Users\\hacqu\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\hacqu\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\hacqu\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\hacqu\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-Ic:\\Users\\hacqu\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoMatrix" "-Ic:\\Users\\hacqu\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-Ic:\\Users\\hacqu\\OneDrive\\Documents\\Arduino\\libraries\\DS3231" "C:\\Users\\hacqu\\AppData\\Local\\arduino\\sketches\\D85AD7D66C5C8ECC60DA5DAB176EF123\\sketch\\heureWS2812.ino.cpp" -o "C:\\Users\\hacqu\\AppData\\Local\\arduino\\sketches\\D85AD7D66C5C8ECC60DA5DAB176EF123\\sketch\\heureWS2812.ino.cpp.o"
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:7:11: error: aggregate 'ts temps' has incomplete type and cannot be defined
 struct ts temps;
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino: In function 'void setup()':
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:18:15: error: 'DS3231_INTCN' was not declared in this scope
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:18:15: note: suggested alternative: 'DS3231_h'
               DS3231_h
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:18:3: error: 'DS3231_init' was not declared in this scope
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:18:3: note: suggested alternative: 'DS3231_h'
   DS3231_h
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino: In function 'void loop()':
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:22:3: error: 'DS3231_get' was not declared in this scope
   DS3231_get(&temps);
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:22:3: note: suggested alternative: 'DS3231_h'
   DS3231_get(&temps);
   DS3231_h
Utilisation de la bibliothèque Adafruit GFX Library version 1.12.4 dans le dossier: C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library
Utilisation de la bibliothèque Adafruit BusIO version 1.17.4 dans le dossier: C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI
Utilisation de la bibliothèque Adafruit NeoMatrix version 1.3.3 dans le dossier: C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix
Utilisation de la bibliothèque Adafruit NeoPixel version 1.15.2 dans le dossier: C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel
Utilisation de la bibliothèque DS3231 version 1.1.2 dans le dossier: C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231
exit status 1
Compilation error: aggregate 'ts temps' has incomplete type and cannot be defined
Par Avance Merci d'aider un Papy.
Cordialement JC.
Bonjour,
Peux-tu nous donner l'origine du sketch en question?
https://lasdi.com/arduino7.html#
quelle bibliothèque ?
La bibliothèque est donnée en lien dans le projet n°61
La librairie en question ne correspond pas du tout à ce qui est dans le code. Donc manifestement il y a un problème dans ce projet. Il y a d'ailleurs une personne qui reporte le même problème dans les commentaires de la vidéo et l'auteur n'a jamais répondu.
il semblerait que ce soit une ancienne version de cette bibliothèque
qui contient bien la struct ts
ils disent
Author: Petre Rodan 2b4eda@subdimension.ro
Available from: https://github.com/rodan/ds3231
License: GNU GPLv3
mais le lien GitHub ne fonctionne plus...
et si on utilise celle là on a une erreur
sketch_dec03a:18:15: error: 'DS3231_INTCN' was not declared in this scope
Mais si on remplace cette ligne par
	DS3231_init(DS3231_CONTROL_INTCN);
alors là ça compile... à voir si ça fonctionne cela dit...
Merci à tous les deux. J’ai télécharger le lien de J_M_L et modifier la ligne dans le setup mais toujours la même erreur. A mon age, je voulais juste avoir un aperçu sur un petit montage. Mais bon ça deviens trop hard pour ma petite tête.
Enlevez la bibliothèque que vous avez téléchargée de votre répertoire qui contient toutes les bibliothèques
Récupérez uniquement les 2 fichier DS3231.h et DS3231.cpp et mettez les dans le même dossier que votre .ino
Dans le code de votre .ino et dans le .cpp, au lieu de
#include <DS3231.h>
Replaced les <> par des guillemets droits
#include <"DS3231.h"
Pour dire au compilateur de chercher ces fichier dans le répertoire de travail avant d’aller voir du côté des bibliothèques
Ça devrait alors compiler
Je suis complètement a l’ouest voir sur une autre planète;
#include <Wire.h>
#include "DS3231.h"
#include "DS3231.cpp"
struct ts temps;
  matrix.begin();
  Wire.begin();
  DS3231_get(&temps);
  matrix.print(":");
  matrix.print(":");
  matrix.show();
  matrix.show();
voici l'erreur:
C:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\hacqu\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoMatrix -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel -Ic:\Users\hacqu\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\hacqu\AppData\Local\arduino\sketches\D85AD7D66C5C8ECC60DA5DAB176EF123\sketch\heureWS2812.ino.cpp -o C:\Users\hacqu\AppData\Local\Temp\534605062\sketch_merged.cpp
C:\Users\hacqu\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\hacqu\AppData\Local\Temp\534605062\sketch_merged.cpp
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:9:11: error: aggregate 'ts temps' has incomplete type and cannot be defined
 struct ts temps;
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:20:15: error: 'DS3231_CONTROL_INTCN' was not declared in this scope
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:20:3: error: 'DS3231_init' was not declared in this scope
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:20:3: note: suggested alternative: 'DS3231_h'
   DS3231_h
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:24:3: error: 'DS3231_get' was not declared in this scope
   DS3231_get(&temps);
C:\Users\hacqu\OneDrive\Documents\Arduino\libraries\heurews2812\heureWS2812\heureWS2812.ino:24:3: note: suggested alternative: 'DS3231_h'
   DS3231_get(&temps);
   DS3231_h
exit status 1
J'ai supprimer la bibliothèque.mais j'en ai d'autre dans le répertoire arduino.Bref, je suis perdu, je vais laisser tomber ce programme voir si il n'y en a pas d'autre plus récent sur le forum.
Non pas celui la
On inclut juste le .h
J’avais dit faire de même dans le .cpp mais je vois en fait qu’il y a déjà des guillemets
Donc rien à faire d’autre qu’avoir ces 2 fichiers (et rien d’autre) dans le même répertoire que votre .ino
