I was trying to make this Arduino project where I would control a robotic arm using an app made with MIT App inventor via Bluetooth. I referred to the website- https://howtomechatronics.com/tutorials/arduino/diy-arduino-robot-arm-with-smartphone-control/ (blocks, and source code is there in the website)
The circuit, code all looks fine to me. The app consists of a slider controller, I move the robot arm based on the movement of slider controller.
The PROBLEM is that when I move the slider controller, the app crashes that is, it freezes and gives the following error- "Error 516:Unable to write:Broken pipe". I have observed that the bluetooth module(HC-05) I'm using starts disconnecting everytime I connect it, hence "broken pipe".
So, I would like to know is there any solution to fix it, if yes then please let me know it.
Thank You!
