ERROR AL CARGAR EJEMPLOS ESTÁNDAR DEL ID ARDUINO
Hola,
Soy nuevo en el mundo Arduino y nada mas empezar tengo un problemilla que me trae dolores de cabeza.
Ya he instalado el ID Arduino correctamente y ahora, no se por que razón, cuando intento cargar un ejemplo estandar del programa me salta el siguente error:
Invalid Drawer: trying to add a drawer that already exists: DFRobot
Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space
at java.awt.image.DataBufferInt.(DataBufferInt.java:41)
at java.awt.image.Raster.createPackedRaster(Raster.java:458)
at java.awt.image.DirectColorModel.createCompatibleWritableRaster(DirectColorModel.java:1015)
at java.awt.GraphicsConfiguration.createCompatibleImage(GraphicsConfiguration.java:163)
at edu.mit.blocks.codeblocks.rendering.BlockShapeUtil.getBevelImage(BlockShapeUtil.java:178)
at edu.mit.blocks.renderable.RenderableBlock.updateBuffImg(RenderableBlock.java:1387)
at edu.mit.blocks.renderable.RenderableBlock.(RenderableBlock.java:271)
at edu.mit.blocks.renderable.RenderableBlock.(RenderableBlock.java:186)
at edu.mit.blocks.renderable.FactoryRenderableBlock.(FactoryRenderableBlock.java:40)
at edu.mit.blocks.workspace.PageDrawerLoadingUtils.loadBlockDrawerSets(PageDrawerLoadingUtils.java:236)
at edu.mit.blocks.workspace.Workspace.loadWorkspaceFrom(Workspace.java:855)
at edu.mit.blocks.controller.WorkspaceController.loadFreshWorkspace(WorkspaceController.java:415)
at com.ardublock.core.Context.resetWorksapce(Context.java:126)
at com.ardublock.core.Context.(Context.java:92)
at com.ardublock.core.Context.getContext(Context.java:79)
at com.ardublock.ui.OpenblocksFrame.(OpenblocksFrame.java:71)
at com.ardublock.ui.ArduBlockToolFrame.(ArduBlockToolFrame.java:3)
at com.ardublock.ArduBlockTool.init(ArduBlockTool.java:28)
at processing.app.Editor.addTools(Editor.java:796)
at processing.app.Editor.buildToolsMenu(Editor.java:674)
at processing.app.Editor.buildMenuBar(Editor.java:478)
at processing.app.Editor.(Editor.java:205)
at processing.app.Base.handleOpen(Base.java:709)
at processing.app.Base.handleOpen(Base.java:674)
at processing.app.Base$7.actionPerformed(Base.java:1108)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
Alguien me puede ayudar a resolver el problema?
SO: Windows 8o 1.0.6
Software: Arduin
Saludos!!
Que versión de IDE estas usando.
Si leo mal dice 1.0.6?
Desinstala e instala la versión 1.6.4 o la ultima que veas.
Hola, encontraste la solucion?, yo tengo el mismo problema pero es aleatorio, y pasa desde que instale Ardublock, es tu caso?
La solucion es usar la version 1.6.0 a menos que tengas un Arduino Ultimo modelo que requiera las versiones superiores.
Vas a www.arduino.cc luego Download y luego Previus IDE Realeases
Olvidé algo muy importante: Ve a Windows Update y verifica que este actualizado al día de hoy.
Verifica que Java esta actualizado también.
