hi,
this is a programme i worte for my liney follower and it s giving a error which i cant understand
/*------------------LINEY_V2------------------*/
#include <PID_Beta6.h>
int val_right,val_left,error;
unsigned int change;
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint,2,5,1);
/*!!!!MOTOR SETIUP!!!!*/
#define m1p1 2;
#define m1p2 3;
#define m2p1 4;
#define m2p2 5;
/*######pwm_set#####*/
#define pwm_right 9;
#define pwm_left 10;
/*setting of the pins*/
Input = change;
Setpoint = 100;
myPID.SetMode(AUTO);
pinMode(0,INPUT);
pinMode(1,INPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
pinMode(4,INPUT);
pinMode(5,INPUT);
pinMode(m1p1,OUTPUT);
pinMode(m1p2,OUTPUT);
pinMode(m2p1,OUTPUT);
pinMode(m2p2,OUTPUT);
/*--------LOOP---------*/
/*set motor to move forward , keep setting to gain accuracy */
setmotor();
/*calculating values to check the alignment of the bot WRT line*/
val_right = ((analogRead(0))+(analogRead(1))+(analogRead(2)));
val_left = ((analogRead(3))+(analogRead(4))+(analogRead(5)));
/*calculating the difference and setting it as an unsigned int to do pwm*/
change = (val_left-val_right);
/*compute pid values*/
Input = change;
myPID.Compute();
/*------PWM WRITE VALUES-----*/
if(val_right>val_left) //decision as to which pwm pin to write on.
analogWrite(10,OUTPUT);
analogWrite(9,OUTPUT);
void setmotor();
digitalWrite(m1p1,HIGH);
digitalWrite(m1p2,LOW);
digitalWrite(m2p1,HIGH);
digitalWrite(m2p2,LOW);
Arduino 18 ; ubuntu 10.10 (maverick ) arduino duemilanove
ERROR
In function ‘void setup()’:
error: expected `)' before ‘;’ token In function ‘void loop()’:
At global scope:
