Hi all,
Very new to Arduino and while i have understood it a little im stuck on these errors as when i change what i think it might be i get more errors.
Any help would be greatly appreciated. I have been trying to merge three different codes, I have a 4 wasy relay module where two relays will be controlled by push buttons, one will be controlled by a light sensor module and the 4th to be controlled by RFID.
My code is here
[Edit - code tags added by Moderator. Please use them next time, the </> button on the menu.]
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 12 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
const int pushButton[] = {2, 3}; // define push button inputs
const int relayPin[] = {11, 10}; // output pins where 4 relays will be connected
const int LIGHT_SENSOR_PIN = A0; // Arduino pin connected to light sensor's pin
const int RELAY_PIN = 1; // Arduino pin connected to Relay's pin
const int ANALOG_THRESHOLD = 500;
String relayNames[] = {"CH1", "CH2", "CH3", "CH4"}; // Just put name for 4 relays
String read_rfid; // Add how many you need and don't forget to include the UID.
String ok_rfid_1 = "e199312d"; // This is for my main RFID Card. aka. The one I will be using to turn on my PC. Can also be used to shut it down if you want to.
String ok_rfid_2 = "fbecb673"; // This is for the RFID Keyfob. aka. Shutdown Keyfob. Not advisable tho. Just shutdown your PC normally.
int pushed[] = {0, 0, 0, 0}; // status of each buttons
int relayStatus[] = {HIGH, HIGH, HIGH, HIGH}; // initial status of relay
int lock = 8; // For the Card.
int lock2 = 8; // For the Keyfob.
int analogValue;
pinMode(RELAY_PIN, OUTPUT); // set arduino pin to output mode
Serial.begin(9600);// initialize serial monitor
for (int i = 0; i < 4; i++)
pinMode(pushButton[i], INPUT_PULLUP);
pinMode(relayPin[i], OUTPUT);
digitalWrite(relayPin[i], HIGH);// initial relay status to be OFF
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
//Choose which lock below:
pinMode(lock, OUTPUT);
pinMode(lock2, OUTPUT);
void dump_byte_array(byte * buffer, byte bufferSize) {
read_rfid = "";
for (byte i = 0; i < bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX)
void open_lock() {
digitalWrite(lock, HIGH);
digitalWrite(lock, LOW);
void close_lock2() {
digitalWrite(lock2, HIGH);
delay(5000);
digitalWrite(lock2, LOW);
analogValue = analogRead(LIGHT_SENSOR_PIN); // read the input on analog pin
if (analogValue < ANALOG_THRESHOLD)
digitalWrite(RELAY_PIN, HIGH); // turn on Relay
digitalWrite(RELAY_PIN, LOW); // turn off Relay
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.println(read_rfid);
if (read_rfid == ok_rfid_1) {
//ok, open the door.
open_lock();
if (read_rfid == ok_rfid_2) {
close_lock2();
int val = digitalRead(pushButton[i]);
if (val == HIGH && relayStatus[i] == LOW) {
pushed[i] = 1 - pushed[i];
delay(100);
}// if
relayStatus[i] = val;
if (pushed[i] == HIGH) {
Serial.print(relayNames[i]);
Serial.println(" ON");
digitalWrite(relayPin[i], LOW);
Serial.println(" OFF");
}// else
}// for
Serial.println("==");
delay(100);
The errors im getting are
C:\Users\MrA\Desktop\chopper_wiring\chopper_wiring.ino: In function 'void setup()':
chopper_wiring:43:56: error: a function-definition is not allowed here before '{' token
exit status 1
Thanks
