Error Codes
Hello Everyone,
I am new to programming and trying to learn the ropes. What I am trying to accomplish is, control a humidifier with a relay. I based my code off of a video. What I want the code to do is read the value coming from the DHT11 sensor and and turn the relay on if it is high than a set value. So I wrote/borrowed the following code. I get the following error code - Arduino: 1.6.1 (Mac OS X), Board: "Arduino Uno"
(code tags added by Moderator - please use them in your future posts)
DHT11.ino: In function 'void loop()':
DHT11.ino:62:1: error: expected '}' at end of input
Error compiling. "
//    FILE: dht11_test.ino
//  AUTHOR: Adam Zabielski
// VERSION: 1.0
// PURPOSE: Humidifier Control Module
#include <dht.h>
dht DHT;
#define DHT11_PIN 2
int Humidifier = 4;
//Onborad led
int led = 13;
int i = 0;
  Serial.println("DHT TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT_LIB_VERSION);
  Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
  pinMode(Humidifier,OUTPUT);
  pinMode(led,OUTPUT);
  // READ DATA
  Serial.print("DHT11, \t");
  int chk = DHT.read11(DHT11_PIN);
  // DISPLAY DATA
  Serial.print(DHT.humidity, 1);
  Serial.print(",\t");
  Serial.println(DHT.temperature, 1);
  //Relay Control
  if (DHT.humidity<55) {
    digitalWrite(Humidifier,LOW);
  } else { digitalWrite(Humidifier,HIGH);
 // Deley and LED flashing
i=0;
while (i<10) {
  digitalWrite(led,HIGH);
  digitalWrite(led,LOW);
  i++;
// End of code
Thanks for taking a look.
All the { } must pair up.
All code must be in a function - setup() and loop() are considered functions as well.
This 2nd } here
closes out the loop() function.
All the code that follows is then Not in a function. Move the 2nd } to the end of the sketch.
This 2nd } here
That is why you should NEVER put the { next to code. Put EVERY { and every } on their own lines. Keep your code properly indented (or use Tools + Auto Format) and your see where functions and blocks start and end, and you won't have multiple things ending at the same place/prematurely.
