#include <Servo.h>
#include <AFMotor.h>
#define LINE_BUFFER_LENGTH 512
char STEP = MICROSTEP ;
const int penZUp = 115;
const int penZDown = 83;
const int penServoPin = 10 ;
const int stepsPerRevolution = 48;
Servo penServo;
// Initialize steppers for X- and Y-axis using this Arduino pins for the L293D H-bridge
AF_Stepper myStepperY(stepsPerRevolution, 1);
AF_Stepper myStepperX(stepsPerRevolution, 2);
/* Structures, global variables */
struct point {
float x;
float y;
float z;
struct point actuatorPos;
float StepInc = 1;
int StepDelay = 0;
int LineDelay = 0;
int penDelay = 50;
float StepsPerMillimeterX = 100.0;
float StepsPerMillimeterY = 100.0;
float Xmin = 0;
float Xmax = 40;
float Ymin = 0;
float Ymax = 40;
float Zmin = 0;
float Zmax = 1;
float Xpos = Xmin;
float Ypos = Ymin;
float Zpos = Zmax;
boolean verbose = false;
void setup() - Initialisations
// Setup
Serial.begin( 9600 );
penServo.attach(penServoPin);
penServo.write(penZUp);
delay(100);
// Decrease if necessary
myStepperX.setSpeed(600);
myStepperY.setSpeed(600);
Serial.println("Mini CNC Plotter alive and kicking!");
Serial.print("X range is from ");
Serial.print(Xmin);
Serial.print(" to ");
Serial.print(Xmax);
Serial.println(" mm.");
Serial.print("Y range is from ");
Serial.print(Ymin);
Serial.print(Ymax);
void loop() - Main loop
delay(100);
char line[ LINE_BUFFER_LENGTH ];
char c;
int lineIndex;
bool lineIsComment, lineSemiColon;
lineIndex = 0;
lineSemiColon = false;
lineIsComment = false;
while (1) {
while ( Serial.available() > 0 ) {
c = Serial.read();
if (( c == '\n') || (c == '\r') ) {
if ( lineIndex > 0 ) {
line[ lineIndex ] = '\0';
if (verbose) {
Serial.print( "Received : ");
Serial.println( line );
processIncomingLine( line, lineIndex );
lineIndex = 0;
else {
// Empty or comment line. Skip block.
Serial.println("ok");
else {
if ( (lineIsComment) || (lineSemiColon) ) {
if ( c == ')' ) lineIsComment = false;
else {
if ( c <= ' ' ) {
else if ( c == '/' ) {
else if ( c == '(' ) {
lineIsComment = true;
else if ( c == ';' ) {
lineSemiColon = true;
else if ( lineIndex >= LINE_BUFFER_LENGTH - 1 ) {
Serial.println( "ERROR - lineBuffer overflow" );
else if ( c >= 'a' && c <= 'z' ) { // Upcase lowercase
line[ lineIndex++ ] = c - 'a' + 'A';
else {
line[ lineIndex++ ] = c;
void processIncomingLine( char* line, int charNB ) {
int currentIndex = 0;
char buffer[ 64 ];
struct point newPos;
newPos.x = 0.0;
newPos.y = 0.0;
while ( currentIndex < charNB ) {
switch ( line[ currentIndex++ ] ) {
case 'U':
penUp();
case 'D':
penDown();
case 'G':
buffer[0] = line[ currentIndex++ ];
buffer[1] = '\0';
switch ( atoi( buffer ) ) {
case 0:
case 1:
char* indexX = strchr( line + currentIndex, 'X' );
char* indexY = strchr( line + currentIndex, 'Y' );
if ( indexY <= 0 ) {
newPos.x = atof( indexX + 1);
newPos.y = actuatorPos.y;
else if ( indexX <= 0 ) {
newPos.y = atof( indexY + 1);
newPos.x = actuatorPos.x;
else {
indexY = '\0';
drawLine(newPos.x, newPos.y );
actuatorPos.x = newPos.x;
actuatorPos.y = newPos.y;
case 'M':
buffer[0] = line[ currentIndex++ ]; // /!\ Dirty - Only works with 3 digit commands
buffer[1] = line[ currentIndex++ ];
buffer[2] = line[ currentIndex++ ];
buffer[3] = '\0';
case 300:
char* indexS = strchr( line + currentIndex, 'S' );
float Spos = atof( indexS + 1);
if (Spos == 30) {
penDown();
if (Spos == 50) {
penUp();
case 114: // M114 - Repport position
Serial.print( "Absolute position : X = " );
Serial.print( actuatorPos.x );
Serial.print( " - Y = " );
Serial.println( actuatorPos.y );
default:
Serial.print( "Command not recognized : M");
Serial.println( buffer );
void drawLine(float x1, float y1) {
if (verbose)
Serial.print("fx1, fy1: ");
Serial.print(x1);
Serial.print(",");
Serial.print(y1);
Serial.println("");
if (x1 >= Xmax) {
x1 = Xmax;
if (x1 <= Xmin) {
x1 = Xmin;
if (y1 >= Ymax) {
y1 = Ymax;
if (y1 <= Ymin) {
y1 = Ymin;
if (verbose)
Serial.print("Xpos, Ypos: ");
Serial.print(Xpos);
Serial.print(",");
Serial.print(Ypos);
Serial.println("");
if (verbose)
Serial.print("x1, y1: ");
Serial.print(x1);
Serial.print(",");
Serial.print(y1);
Serial.println("");
x1 = (int)(x1 * StepsPerMillimeterX);
y1 = (int)(y1 * StepsPerMillimeterY);
float x0 = Xpos;
float y0 = Ypos;
long dx = abs(x1 - x0);
long dy = abs(y1 - y0);
int sx = x0 < x1 ? StepInc : -StepInc;
int sy = y0 < y1 ? StepInc : -StepInc;
long i;
long over = 0;
if (dx > dy) {
for (i = 0; i < dx; ++i) {
myStepperX.onestep(sx, STEP);
over += dy;
if (over >= dx) {
over -= dx;
myStepperY.onestep(sy, STEP);
delay(StepDelay);
else {
for (i = 0; i < dy; ++i) {
over += dx;
if (over >= dy) {
over -= dy;
delay(StepDelay);
if (verbose)
Serial.print("dx, dy:");
Serial.print(dx);
Serial.print(",");
Serial.print(dy);
Serial.println("");
if (verbose)
Serial.print("Going to (");
Serial.print(x0);
Serial.print(",");
Serial.print(y0);
Serial.println(")");
delay(LineDelay);
Xpos = x1;
Ypos = y1;
void penUp() {
delay(penDelay);
Zpos = Zmax;
digitalWrite(15, LOW);
digitalWrite(16, HIGH);
if (verbose) {
Serial.println("Pen up!");
void penDown() {
penServo.write(penZDown);
delay(penDelay);
Zpos = Zmin;
digitalWrite(15, HIGH);
digitalWrite(16, LOW);
if (verbose) {
Serial.println("Pen down.");
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
Is that a half-assed comment?
