Error compiling for board Arduino Uno
Hello,
First time usign Arduino. I have soem code that worked fine on Arduino cloud but is now not verifyign when i use the Arduino software. I am unable to transdefer the code form the cloud to my Uno as it is not compatible.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\wjunior\Downloads\copy_of_password_based_door_lock1\copy_of_password_based_door_lock1.ino:1:20: fatal error: Keypad.h: No such file or directory
#include <Keypad.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#define Password_Length 5
Servo myservo;
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
int pos = 0;
char Data[Password_Length];
char Master[Password_Length] = "1234";
byte data_count = 0, master_count = 0;
bool Pass_is_good;
bool door = false;
char customKey;
/*---preparing keypad---*/
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {0, 1, 2, 3};
byte colPins[COLS] = {4, 5, 6, 7};
Keypad customKeypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
/*--- Main Action ---*/
  myservo.attach(9, 2000, 2400);
  ServoClose();
  lcd.begin(16, 2);
  lcd.print("Protected Door");
  loading("Loading");
  lcd.clear();
  if (door == true)
    customKey = customKeypad.getKey();
    if (customKey == '#')
      lcd.clear();
      ServoClose();
      lcd.print("Door is closed");
      delay(3000);
      door = false;
    Open();
void loading (char msg[]) {
  lcd.setCursor(0, 1);
  lcd.print(msg);
  for (int i = 0; i < 9; i++) {
    lcd.print(".");
void clearData()
  while (data_count != 0)
    Data[data_count--] = 0;
  return;
void ServoClose()
  for (pos = 90; pos >= 0; pos -= 10) {
    myservo.write(pos);
void ServoOpen()
  for (pos = 0; pos <= 90; pos += 10) {
    myservo.write(pos);
void Open()
  lcd.setCursor(0, 0);
  lcd.print("Enter Password");
  if (customKey)
    Data[data_count] = customKey;
    lcd.setCursor(data_count, 1);
    lcd.print(Data[data_count]);
    data_count++;
  if (data_count == Password_Length - 1)
    if (!strcmp(Data, Master))
      lcd.clear();
      ServoOpen();
      lcd.print(" Door is Open ");
      door = true;
      delay(5000);
      loading("Waiting");
      lcd.clear();
      lcd.print(" Time is up! ");
      ServoClose();
      door = false;
      lcd.clear();
      lcd.print(" Wrong Password ");
      door = false;
    lcd.clear();
    clearData();
Hi @cholland00. All the >6600 libraries of the Arduino Library Manager are pre-installed in Arduino Cloud. When using Arduino IDE, only a few of the fundamental libraries are pre-installed. You must install any other libraries used by your sketch. When you don't have the library installed, it causes the compilation to fail with a "No such file or directory" error.
I'll provide instructions you can follow to install the missing "Keypad" library:
  1. Select Sketch > Include Library > Manage Libraries... from the Arduino IDE menus.
    The "Library Manager" dialog will open.
  2. Wait for the update to finish, as indicated by the progress bar at the bottom of the "Library Manager" dialog.
  3. Type Keypad in the "Filter your search..." field.
  4. Press the Enter key.
  5. Scroll down through the list of libraries until you see the "*Keypad by Mark Stanley, Alexander Brevig" entry. Click on it.
    A menu and button will appear at the bottom of the entry.
  6. Click the "Install" button in the "" entry.
  7. You may now get a dialog asking:
    Would you like to install also all the missing dependencies?
    If so, click the "Install all" button.
  8. Wait for the installation to finish.
  9. Click the "Close" button in the "Library Manager" dialog.
    The "Library Manager" dialog will close.
Now try compiling your sketch again. Hopefully this time it will compile without any errors.
Thank you so much for your reply.
The problem is now fixed and everything is working.
You are welcome. I'm glad it is working now.
Regards,
Per
So mark post #2 as the solution so everyone knows the problem has been solved.
