Error ESP32 comunication
Im doing my final project and i thinks that theres a problem with the comunication of my computer and the esp32
Since morning this mensage keeps showing up, but before wasnt
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
it wound be nice if yall could point me the error and how can i fix it
Disconnect all wires from esp32 and try to upload again
i tryed, but i dont know why is not working
i tryed uploading the same code with a arduino uno and it worked
the problem is with the esp32
  • Check you are passing the correct serial port on the command line.
  • Try with different USB cable
  • Check you have permissions to access the serial port, and other software (such as modem-manager on Linux) is not trying to interact with it.
  • Try using a slower baud rate (-b 9600 is a very slow value that you can use to verify it’s not a baud rate problem).
Also post a pic of your board
  • Have you tried uploading simple blink code ?
  • Have you ever Programmed this esp32 before?
