Error: expected ';' before 'digitalWrite'
I mega beginner I don't know what the error code: error: expected ';' before 'digitalWrite' means with the following code:
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(11,OUTPUT);
pinMode(10,OUTPUT);
pinMode(9,OUTPUT);
pinMode(8,OUTPUT);
pinMode(7,OUTPUT);
pinMode(6,OUTPUT);
digitalWrite(13,HIGH);
digitalWrite(12,LOW);
digitalWrite(11,LOW);
digitalWrite(10,LOW);
digitalWrite(9,LOW);
digitalWrite(8,LOW);
digitalWrite(7,LOW);
digitalWrite(6,LOW);
delay(100);
digitalWrite(13,LOW);
digitalWrite(12,HIGH);
delay(100);
digitalWrite(11,HIGH);
delay(100);
digitalWrite(10,HIGH);
delay(100);
digitalWrite(9,HIGH);
delay(100);
digitalWrite(8,HIGH);
delay(100)
digitalWrite(7,HIGH);
delay(100);
digitalWrite(6,HIGH);
delay(100);
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
    delay(100)
      digitalWrite(13, LOW);
Missing semicolon on the delay() function
The error message
69:1: error: expected ';' before 'digitalWrite'
tells you to look at line 69 of the sketch and the missing semicolon is on the previous line
delay(100)
You are missing a ; after delay(100)
Thank you Thank you with the <code wanted to do it but I was afraid that it would be formatted
The best thing to do when posting code is to use Edit/Auto Format in the IDE to tidy up the layout then use Edit/Copy for Forum to copy it and automatically add code tags ready to paste in a forum reply
Unrelated to your problem but if you learn about 'functions', 'arrays' and 'for loops' you could drastically simplify your code. I remember being blown away when I first combined these things together.
Boy your good. I'll bet you could pass the test where you have to count the "of" in a paragraph :grinning:
