Hi guys,
I have 12 error: expected primary-expression before '.' token. in my code. Please can you help me fix these.
This is the error code appearing:
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino: In function 'void setup()':
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:69:8: error: expected primary-expression before '.' token
GPS.begin(9600);
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:70:4: error: expected primary-expression before '.' token
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:80:10: error: expected primary-expression before '.' token
GPSSerial.println(PMTK_Q_RELEASE);
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:81:20: error: expected primary-expression before '.' token
int realhours = GPS.hour - 8;
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:148:25: error: expected primary-expression before '.' token
dataFile.println(GPS.minute);
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino: In function 'void loop()':
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:162:15: error: expected primary-expression before '.' token
char c = GPS.read();
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:165:10: error: expected primary-expression before '.' token
if (GPS.newNMEAreceived()) {
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:166:23: error: expected primary-expression before '.' token
Serial.println(GPS.lastNMEA());
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:167:13: error: expected primary-expression before '.' token
if (!GPS.parse(GPS.lastNMEA())); //Serial GPS info for debugging
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:167:23: error: expected primary-expression before '.' token
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:173:44: error: expected primary-expression before '.' token
if (timer1.finished()) {knot = knot+GPS.speed; knotcounter++;
/tmp/045508017/sketch_sep1b/sketch_sep1b.ino:178:13: error: expected primary-expression before '.' token
if (GPS.fix) {
exit status 1
Thanks Tom
Speed_coach_code__with_errors.ino (9.56 KB)
