hey so i have been using tinkercad to make my code but i keep getting this error: expected unqualified-id before 'else'
on my line 4:1,5:1 and 6:1 but nothing is their. I have moved my code down and the error is still on 4,5 and 6. i have also deleted that space and tried but nothing changed.
(Next post, please use code tags, </> on the menu. Thanks - Moderator)
//UltraSonic Sensor & light Sensor w/ Motor
//Updated 5/04/2020
//Variable Declaration
int lightPin = 0;
int lightPin1 = A1;
int lightPin2 = A2;
int lightPin3 = A3;
int LEDPin = 7 ;
int LEDPin1 = 8 ;
int LEDPin2 = 12;
int LEDPin3 = 13;
int echo1 = 10; //Echo1
int trig1 = 11; //Trigger1
int echo2 = 6; //Echo2
int trig2 = 9; //Trigger2
long duration1;
float distance1; //Left
int safetyDistance;
long duration2;
float distance2; //Right
float range = 30; //Determines when the object should turn. Changable for testing
//int motor1On = 13; //motor1
int outPut1a = 2;
int outPut1b = 4;
//int motor2On = 12; //motor2
int outPut2a = 5;
int outPut2b = 3;
//LED
pinMode(LEDPin, OUTPUT);
pinMode(LEDPin1, OUTPUT);
pinMode(LEDPin2, OUTPUT);
pinMode(LEDPin3, OUTPUT);
// pinMode(motor1On, OUTPUT);
pinMode(outPut1a, INPUT);
pinMode(outPut1b, INPUT);
// pinMode(motor2On, OUTPUT);
pinMode(outPut2a, INPUT);
pinMode(outPut2b, INPUT);
// UltraSonic Sensor
pinMode(echo1, INPUT);
pinMode(trig1, OUTPUT);
pinMode(echo2, INPUT);
pinMode(echo2, OUTPUT);
int lightLevel = analogRead(lightPin);
lightLevel = map(lightLevel, 200, 900, 0, 255); // adjusting the value 200 to 900 and 0 to 255
lightLevel = constrain(lightLevel, 0, 255); // do not go over 255
Serial.println(lightLevel);
int lightLevel1 = analogRead(lightPin1);
lightLevel1 = map(lightLevel1, 200, 900, 0, 255); // adjusting the value 0 to 900 and 0 to 255
lightLevel1 = constrain(lightLevel1, 0, 255); // do not go over 255
Serial.println(lightLevel1);
int lightLevel2 = analogRead(lightPin2);
lightLevel2 = map(lightLevel2, 200, 900, 0, 255); // adjusting the value 0 to 900 and 0 to 255
lightLevel2 = constrain(lightLevel2, 0, 255); // do not go over 255
Serial.println(lightLevel2);
int lightLevel3 = analogRead(lightPin3);
lightLevel3 = map(lightLevel2, 200, 900, 0, 255); // adjusting the value 0 to 900 and 0 to 255
lightLevel3 = constrain(lightLevel3, 0, 255); // do not go over 255
Serial.println(lightLevel3);
bool A = distance1 <= range && distance2 > range;
bool B = distance1 <= range && distance2 <= range;
bool C = distance1 <= range && distance2 > range;
bool D = distance2 <= range && distance1 > range;
bool E = lightLevel >= lightLevel1 && lightLevel >= lightLevel2 && lightLevel > lightLevel3;
bool F = lightLevel1 > lightLevel && lightLevel1 >= lightLevel2 && lightLevel1 >= lightLevel3;
bool G = lightLevel2 > lightLevel && lightLevel2 > lightLevel && lightLevel2 >= lightLevel3;
bool H = lightLevel3 >= lightLevel && lightLevel3 > lightLevel && lightLevel3 > lightLevel2;
bool S = lightLevel >= lightLevel1 && lightLevel >= lightLevel2 && lightLevel >= lightLevel3;
digitalWrite(trig1, LOW);
delayMicroseconds(2);
digitalWrite(trig1, HIGH);
delayMicroseconds(10);
duration1 = pulseIn(echo1, HIGH);
digitalWrite(trig2, LOW);
digitalWrite(trig2, HIGH);
duration2 = pulseIn(echo2, HIGH);
distance1 = (duration1 * 0.0133 /2 );
distance2 = (duration2 * 0.0133 /2 );
//go forward
if ( E && A ){
go_forward();
//avoid going left
else if ( E && D ) {
avoid_going_left();
//avoid going right
else if ( E && C ) {
avoid_going_right();
//turn around
else if ( E && B ) {
turn_around();
//go left
else if ( F ) {
go_left();
//go right
else if ( G ) {
go_right();
//turn around 2
else if ( H ) {
turn_around_2();
//stop
else if ( S ) {
stop();
else {
// Subroutines*************************************************
//go forward Subroutine
void go_forward(){
digitalWrite(outPut1a, HIGH);
digitalWrite(outPut1b, LOW);
digitalWrite(outPut2a, HIGH);
digitalWrite(outPut2b, LOW);
//avoid going left
void avoid_going_left(){
digitalWrite(outPut1a, LOW);
digitalWrite(outPut1b, HIGH);
//avoid going right Subroutine
void avoid_going_right(){
digitalWrite(outPut2a, LOW);
digitalWrite(outPut2b, HIGH);
//go turn around
void turn_around(){
//go left Subroutine
void go_left(){
//go right Subroutine
void go_right(){
//turn around 2 Subroutine
void turn_around_2(){
//stop Subroutine
void stop(){
