ERROR IN HUMANOID ROBOT CODE
Can anyone rectify this error and help me with this code . Please !!!!!!!!!!!!!!!!!!!!!!
The error is "blue is not defined in this scope".
Below is code along with it's library.
Please correct it and reply.
VarSpeedServo-master.zip (23.9 KB)
arduino_voice.ino (6.4 KB)
rk5849c:
What error?
You need to post the error message.
And don't post your email address in a public Forum unless you enjoy being flooded with SPAM.
Nobody here is going to send you a response using email. You have to come back and read the Forum.
...R
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
blue is what you are calling your BT channel, however you need to use Software Serial library if you are going to use it with a UNO and not use pin0 and pin1 of the serial monitor.
This may help;
If a Mega, use one of the other hardware UARTs.
Thanks.. Tom.. :slight_smile:
[OT]
I would have expected an error like "SHIFT KEY/CAPS LOCK FAILURE DETECED."
[/OT]
Seems fairly clear. It's telling you that you are trying to use something called blue, as in blue.begin(9600). But you have never defined anything called blue. We can only guess what blue is supposed be and where and how it might be connected. The compiler won't guess, you have to tell it.
Steve
///////////// Android Controlled Biped - Test Code 1
////////////  Sequence like walk, dance etc.
// import the serial library1
#include <VarSpeedServo.h>                    // varialble speed control servo libarary                           // Assigning Integer
VarSpeedServo RU;                          // Ininitalizling servo objects
VarSpeedServo RM;
VarSpeedServo RL;
VarSpeedServo LU;
VarSpeedServo LM;
VarSpeedServo LL;
// Added these two lines to work around undefined names.
// Compiles with only warnings for Arduino Leonardo. (Arduino Mega should also work)
#define blue Serial1
String voice;
  blue.begin(9600);                      // Enabling Serial Communication for Bluetooth (HC-05)
  Serial.begin(9600);                   // Enabling Serial communcication for serial monitoring of data
  LU.attach(3);                        // Attaching Servo motors
  LM.attach(5);
  LL.attach(6);
  RU.attach(9);
  RM.attach(10);
  RL.attach(11);
  LU.write(90);           // Initializing all motors to position
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
  delay (5000);
  int b = 60;
  while (blue.available())                // Checking for serial communcation of bluetooth data
    char c = blue.read();      // Geting values in a varialbe
    delay(10);
    if (c == '#')
    voice += c;
  if (voice.length() > 0)
    // prepare for next data ...
    Serial.println(voice);
    if (voice == "*forward")
      Serial.println("moving forward");
      walk ();
    else if (voice == "*stop")
      Serial.println("Stopping");
      halt ();
    else if (voice == "*kick")
      Serial.println("Kicking the ball");
      kick ();
    else  if (voice == "*welcome")
      Serial.println("Greeting you all");
      welcome ();
    else if (voice == "*left")
      Serial.println("Turning Left");
      left ();
    else if (voice == "*right")
      Serial.println("Turning Right");
      right ();
      Serial.println("No command found");
      delay(200);
      LM.write(90);
      delay(200);
      LL.write(90);
      delay(200);
      RU.write(90);
      delay(200);
      RM.write(90);
      delay(200);
      RL.write(90);
      delay(200);
    voice = "";       // resetting string to get fresh voice command
void walk ()
  for (int i = 0; i < 3; i++)
    LL.write(60, 50, true);
    RL.write(60, 50, true);
    //RM.write(120,50,true);
    //delay (1000);
    // LL.write(60,50,true);
    RU.write(110, 40, true);
    LM.write(110, 50, true);
    // RU.write(90,50,true);
    // LU.write(90,50,true);
    // RM.write(90,20,true);
    RL.write(90, 50, true);
    LL.write(90, 50, true);
    RL.write(125, 30, true);
    LL.write(120, 100, true);
    int a = RU.read ();
    RU.write(a - 10, 50, true);
    LM.write(90, 50, true);
    LU.write(70, 50, true);
    RU.write(60, 50, true);
    //LU.write(60,50,true);
    RM.write(60, 50, true);
    // b= RM.read();
    RM.write(90, 50, true); // updation
    LU.write(90, 50, true); // updation
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
  //  delay (1000);
void halt ()
  LU.write(90);
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
void kick ()
  LU.write(90);
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
  LL.write(60, 100, true);
  RL.write(60, 100, true);
  RM.write(130, 100, true);
  RL.write(90, 10, true);
  RM.write(90, 10, true);
  RU.write(60, 10, true);
  RU.write(120, 50, true);
void welcome ()
  LU.write(90);
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
  RM.write(60);//,50,true);
  LM.write(120);//,100,true);
  delay(100);
  RM.write(45);
  LM.write(135);
  delay(100);
  RM.write(30);//,50,true);
  LM.write(150);//,100,true);
  RM.write(60);
  LM.write(120);
  delay(100);
  RM.write(90);
  LM.write(90);
  delay(2000);
void left()
  LU.write(90);
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
    RL.write(120, 50, true);
    LL.write(120, 50, true);
    //RU.write(60,50,true);
    RM.write(70, 50, true);
    LU.write(110, 50, true);
void right ()
  LU.write(90);
  delay(200);
  LM.write(90);
  delay(200);
  LL.write(90);
  delay(200);
  RU.write(90);
  delay(200);
  RM.write(90);
  delay(200);
  RL.write(90);
  delay(200);
  for (int i = 0; i < 3; i++);
    //delay (1000);
    delay(400);
    RU.write(70, 50, true);
  RU.write(90, 50, true);
