In section "Creating (Declaring) an Array" it states:
int mySensVals[6] = {2, 4, -8, 3, 2};
I count 5 items and as this is an int array and not a char "array" declaration, there is no last implicit last '\0' item which will add +1 to the item count.
The number of explicit initializers (the values in the curly braces) does not have to match the size of the array, as long as there are not more of them.
When the size is not specified, the compiler will determine the size of the array.
I'm not sure that there is ever a situation where the number of initializers (other than 0) will reasonably not match the size of the array.
The page could do a better job of explaining this, but there is nothing technically wrong on that page.
LexInTheCity:
A declaration of a char array with a comma-separated list of chars in braces does not implicitly add an extra element for the zero byte. Lots of char arrays are used for things other than C-style "strings." On the other hand, if you initialize a char array with a string literal, and you don't declare the size of the array the array will be sized by the compiler to include the terminating zero byte.
For any kind of array with a declared size, if the number of elements in the initializer list is smaller than the declared size of the array, the remaining elements are initialized to zero.
