Error In Interfacing Dust Sensor to Arduino
hello, i am a beginner of Arduino and I still dont know how to code properly, I was trying to write a small code for my Particle Sensor But I Got This Error
Code:
 Interfacing Sharp Optical Dust Sensor GP2Y1014AU0F with Arduino
#define measurePin = 0; //Connect dust sensor to Arduino A0 pin
#define ledPower = 7;   //Connect 3 led driver pins of dust sensor to Arduino D2
int samplingTime = 280; // time required to sample signal coming out   of the sensor
int deltaTime = 40; //
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
void setup(){
  pinMode(ledPower,OUTPUT);
void loop(){
  digitalWrite(ledPower,LOW); // power on the LED
  delayMicroseconds(samplingTime);
  voMeasured = analogRead(measurePin); // read the dust value
  delayMicroseconds(deltaTime);
  digitalWrite(ledPower,HIGH); // turn the LED off
  delayMicroseconds(sleepTime);
  // 0 - 5V mapped to 0 - 1023 integer values
  // recover voltage
  calcVoltage = voMeasured * (5.0 / 1024.0);
  // linear eqaution taken from http://www.howmuchsnow.com/arduino/airquality/
  // Chris Nafis (c) 2012
  dustDensity = 170 * calcVoltage - 0.1;
  Serial.println(dustDensity); // unit: ug/m3
Error:
exit status 1
Compilation error: expected primary-expression before '=' token
#define measurePin A0 //Connect dust sensor to Arduino A0 pin
#define ledPower 7 //Connect 3 led driver pins of dust sensor to Arduino D2
Though D2 on an Uno is 2, not 7. What board are you using?
im using Arduino uno
i changed that but i still get
\.arduinoIDE-unsaved20231129-16752-r3xv92.bhm9e\sketch_dec29a\sketch_dec29a.ino:61:16: note: in expansion of macro 'ledPower'
\.arduinoIDE-unsaved20231129-16752-r3xv92.bhm9e\sketch_dec29a\sketch_dec29a.ino:61:24: error: expected primary-expression before ',' token
exit status 1
Show your updated sketch.
#define ledPower = 2;   //Connect 3 led driver pins of dust sensor to Arduino D2
void setup(){
void loop(){
  // recover voltage
Go back and read post 2 again.
i changed the #define ledPower 7 to #define ledPower 2, do have to change anything else?
@iliasoli
Change
to
Change
to
#define ledPower 7
No equal sign and no semicolon
Then your original code will work with analog input A0 and digital pin 7
Glad it worked
Have a nice day
thanks
