Error in uploading
this shows up in arduino editor. |
is there any idea? /
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xad
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xad
Are you seeing the com port , and selecting it ?
This is covered a lot on this forum and ...
  1. Using good data usb lead ( not a charger lead)
  2. Using a cheap Arduino ? Some of these need a CH340 driver .
  3. Select the correct cons port ( not com1) and board.
  4. Previous board use had overwritten the bootloader ( re load it )
I have no problem with what you say and I still have the same problem.
Your problem is that you do NOT read and follow instructions.
The posting rules do apply to you.
Mark
