This sketch test the GSM shield's ability to connect to a
GPERS network. It asks for APN information through the
serial monitor and tries to connect to arduino.cc.
Circuit:
* GSM shield attached
* SIM card with data plan
Created 18 Jun 2012
by David del Peral
This example code is part of the public domain
http://arduino.cc/en/Tutorial/GSMToolsTestGPRS
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // GSM access: include a 'true' parameter for debug enabled
GPRS gprsAccess; // GPRS access
GSMClient client; // Client service for TCP connection
// messages for serial monitor response
String oktext = "OK";
String errortext = "ERROR";
// URL and path (for example: arduino.cc)
char url[] = "arduino.cc";
char urlproxy[] = "http://arduino.cc";
char path[] = "/";
// variable for save response obtained
String response = "";
// use a proxy
boolean use_proxy = false;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
use_proxy = false;
// start GSM shield
// if your SIM has PIN, pass it as a parameter of begin() in quotes
Serial.print("Connecting GSM network...");
if (gsmAccess.begin(PINNUMBER) != GSM_READY)
Serial.println(errortext);
while (true);
Serial.println(oktext);
// read APN introduced by user
char apn[50];
Serial.print("Enter your APN: ");
readSerial(apn);
Serial.println(apn);
// Read APN login introduced by user
char login[50];
Serial.print("Now, enter your login: ");
readSerial(login);
Serial.println(login);
// read APN password introduced by user
char password[20];
Serial.print("Finally, enter your password: ");
readSerial(password);
// attach GPRS
Serial.println("Attaching to GPRS with your APN...");
if (gprsAccess.attachGPRS(apn, login, password) != GPRS_READY)
else {
// read proxy introduced by user
char proxy[100];
Serial.print("If your carrier uses a proxy, enter it, if not press enter: ");
readSerial(proxy);
Serial.println(proxy);
// if user introduced a proxy, asks him for proxy port
int pport;
if (proxy[0] != '\0') {
// read proxy port introduced by user
char proxyport[10];
Serial.print("Enter the proxy port: ");
readSerial(proxyport);
// cast proxy port introduced to integer
pport = (int) proxyport;
use_proxy = true;
Serial.println(proxyport);
// connection with arduino.cc and realize HTTP request
Serial.print("Connecting and sending GET request to arduino.cc...");
int res_connect;
// if use a proxy, connect with it
if (use_proxy)
res_connect = client.connect(proxy, pport);
res_connect = client.connect(url, 80);
if (res_connect)
// make a HTTP 1.0 GET request (client sends the request)
client.print("GET ");
// if use a proxy, the path is arduino.cc URL
if (use_proxy)
client.print(urlproxy);
client.print(path);
client.println(" HTTP/1.0");
client.println();
// if you didn't get a connection to the server
Serial.print("Receiving response...");
boolean test = true;
while (test)
// if there are incoming bytes available
// from the server, read and check them
if (client.available())
char c = client.read();
response += c;
// cast response obtained from string to char array
char responsechar[response.length() + 1];
response.toCharArray(responsechar, response.length() + 1);
// if response includes a "200 OK" substring
if (strstr(responsechar, "200 OK") != NULL) {
Serial.println("TEST COMPLETE!");
test = false;
// if the server's disconnected, stop the client:
if (!client.connected())
Serial.println("disconnecting.");
client.stop();
test = false;
Read input serial
int readSerial(char result[])
int i = 0;
while (1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result[i] = '\0';
return 0;
if (inChar != '\r')
result[i] = inChar;
i++;
