Hello,
For a LARP, I have to create a necklace like Battle Royale, With a IR remote, we can control A RGB LED like as Blue, Green, Red or blinking
in my code, no problem with the IR aquisition an dispatch remote, but on the blinking part I have a problem with my while.
#include <IRremote.h>
int RECV_PIN = 8;
int R_PIN = 9;
int G_PIN = 5;
int B_PIN = 11;
boolean running = false;
#define ON 0xFFE01F
#define OFF 0xFF609F
#define BRIGHTNESS_UP 0xFFA05F
#define BRIGHTNESS_DOWN 0xFF20DF
#define FLASH 0xFFF00F
#define STROBE 0xFFE817
#define FADE 0xFFD827
#define SMOOTH 0xFFC837
#define RED 0xFF906F
#define GREEN 0xFF10EF
#define BLUE 0xFF50AF
#define WHITE 0xFFD02F
#define ORANGE 0xFFB04F
#define YELLOW_DARK 0xFFA857
#define YELLOW_MEDIUM 0xFF9867
#define YELLOW_LIGHT 0xFF8877
#define GREEN_LIGHT 0XFF30CF
#define GREEN_BLUE1 0XFF28D7
#define GREEN_BLUE2 0XFF18E7
#define GREEN_BLUE3 0XFF08F7
#define BLUE_RED 0XFF708F
#define PURPLE_DARK 0XFF6897
#define PURPLE_LIGHT 0XFF58A7
#define PINK 0XFF48B7
unsigned long rgb = 0;
byte r,g,b;
IRrecv irrecv(RECV_PIN);
decode_results results;
int currentMillis = 0;
irrecv.enableIRIn(); // IR initialisation
pinMode(R_PIN, OUTPUT);
pinMode(G_PIN, OUTPUT);
pinMode(B_PIN, OUTPUT);
void variar (byte* color, char valor) {
if (valor > 0) {
if ( *color + valor <= 255) {
*color += valor;
*color = 255;
if (*color + valor >= 0) {
*color += valor;
*color = 0;
void attendre(int interval) {
currentMillis = millis();
Serial.println(interval);
Serial.println("entrée attendre");
Serial.println(currentMillis);
while (millis() - currentMillis < interval) {
Serial.println(millis() - currentMillis < interval);
Serial.println("entrée while");
if (irrecv.decode(&results)) {
if (results.value != 0xFFFFFFFF) {
return;
irrecv.resume(); // Receive the next value
}//end while
void STEP1(){
//initialise boolean
running = true;
// enter in a while routine
while(running){
//set the first step leds
RGB(0x00FF00FF);
//lights the LEDs
analogWrite(R_PIN,r);
analogWrite(G_PIN,g);
analogWrite(B_PIN,b);
//wait 100ms
delay (100);
//set the second step leds
RGB(0x00FFFFFF);
//switch of the leds
//wait 100ms
delay(100);
// receive the next value
Serial.println("test");
irrecv.resume();
Serial.println(results.value);
// if we receive value
if (irrecv.decode(&results)){
Serial.println("there is something");
//if value is defferent of the FLASH Code
if ( results.value != 0xFFF00F) {
running = false;
else {
Serial.println("test2");
return;
void RGB(unsigned long valor) {
r = valor >> 16;
g = (valor >> 8) & 0xFF;
b = valor & 0xFF;
if ( results.value != 0xFFFFFFFF) {
switch (results.value) {
case OFF :
RGB(0x00FFFFFF); break;
case ON :
RGB(0x00000000); break;
case RED :
Serial.println("ROUGE");
RGB(0x0000FFFF); break;
case GREEN : RGB(0x00FF00FF); break;
case BLUE : RGB(0x00FFFF00); break;
case WHITE : RGB(0x00000000); break;
case ORANGE : RGB(0x0000AAFF); break;
case YELLOW_DARK : RGB(0x00FFAA00); break;
case YELLOW_MEDIUM : RGB(0x00FFD400); break;
case YELLOW_LIGHT : RGB(0x00FFFF00); break;
case GREEN_LIGHT : RGB(0x0000FFAA); break;
case GREEN_BLUE1 : RGB(0x0000FFFF); break;
case GREEN_BLUE2 : RGB(0x0000AAFF); break;
case GREEN_BLUE3 : RGB(0x00FF7F00); break;
case BLUE_RED : RGB(0x00000080); break;
case PURPLE_DARK : RGB(0x003F0080); break;
case PURPLE_LIGHT : RGB(0x007A00BF); break;
case PINK : RGB(0x00FF00FF); break;
case FLASH :
STEP1();
Serial.println(results.value, HEX);
Serial.println(r,DEC);
Serial.println(g, DEC);
Serial.println(b, DEC);
If you see on Step1, we have this part
running = false;
else {
but when I run the code on my arduino (Uno V3) it's always prit : test2
I try many things but now I'm Lost
Could you help me please ![]()
