Error manssage saying that 'class MPU6050' has no function as pitchPID.Compute() and yawPID.Compute()
I am programming a balanced robot, that uses an MPU6050 chip. I am using my code from a working example from: BalancedRobot/Balanced_Robot.ino at main · un0038998/BalancedRobot · GitHub
But I am always getting the message that 'class MPU6050' has no function as pitchPID.Compute() and yawPID.Compute().
Here is the code:
//#define PRINT_DEBUG_BUILD  //This is to print the mpu data on serial monitor to debug
//PID library
#include <PID_v1.h>
//These are needed for MPU
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
MPU6050 mpu;
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
VectorInt16 gy;         // [x, y, z]            gyro sensor measurements
// ===               INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
#define PID_MIN_LIMIT -255  //Min limit for PID
#define PID_MAX_LIMIT 255  //Max limit for PID
#define PID_SAMPLE_TIME_IN_MILLI 10  //This is PID sample time in milliseconds
//The pitch angle given by MPU6050 when robot is vertical and MPU6050 is horizontal is 0 in ideal case.
//However in real case its slightly off and we need add some correction to keep robot vertical.
//This is the angle correction to keep our robot stand vertically. Sometimes robot moves in one direction so we need to adjust this.
#define SETPOINT_PITCH_ANGLE_OFFSET -2.2
#define MIN_ABSOLUTE_SPEED 0  //Min motor speed
double setpointPitchAngle = SETPOINT_PITCH_ANGLE_OFFSET;
double pitchGyroAngle = 0;
double pitchPIDOutput = 0;
double setpointYawRate = 0;
double yawGyroRate = 0;
double yawPIDOutput = 0;
#define PID_PITCH_KP 10
#define PID_PITCH_KI 80
#define PID_PITCH_KD .8
#define PID_YAW_KP 0.5
#define PID_YAW_KI 0.5
#define PID_YAW_KD 0
PID pitchPID(&pitchGyroAngle, &pitchPIDOutput, &setpointPitchAngle, PID_PITCH_KP, PID_PITCH_KI, PID_PITCH_KD, DIRECT);
PID yawPID(&yawGyroRate, &yawPIDOutput, &setpointYawRate, PID_YAW_KP, PID_YAW_KI, PID_YAW_KD, DIRECT);
int enableMotor1=9;
int motor1Pin1=5;
int motor1Pin2=6;
int motor2Pin1=7;
int motor2Pin2=8;
int enableMotor2=10;
void setupPID()
  pitchPID.SetOutputLimits(PID_MIN_LIMIT, PID_MAX_LIMIT);
  pitchPID.SetMode(AUTOMATIC);
  pitchPID.SetSampleTime(PID_SAMPLE_TIME_IN_MILLI);
  yawPID.SetOutputLimits(PID_MIN_LIMIT, PID_MAX_LIMIT);
  yawPID.SetMode(AUTOMATIC);
  yawPID.SetSampleTime(PID_SAMPLE_TIME_IN_MILLI);
void setupMotors()
  pinMode(enableMotor1,OUTPUT);
  pinMode(motor1Pin1,OUTPUT);
  pinMode(motor1Pin2,OUTPUT);
  pinMode(enableMotor2,OUTPUT);
  pinMode(motor2Pin1,OUTPUT);
  pinMode(motor2Pin2,OUTPUT);
  rotateMotor(0,0);
void setupMPU()
  // join I2C bus (I2Cdev library doesn't do this automatically)
      Wire.begin();
      Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
  #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
      Fastwire::setup(400, true);
  #endif
  mpu.initialize();
  pinMode(INTERRUPT_PIN, INPUT);
  devStatus = mpu.dmpInitialize();
  // supply your own gyro offsets here, scaled for min sensitivity
//           X Accel  Y Accel  Z Accel   X Gyro   Y Gyro   Z Gyro
//OFFSETS    -1798,     263,    1124,    -261,      26,      32
  mpu.setXAccelOffset(-1798);
  mpu.setYAccelOffset(263);
  mpu.setZAccelOffset(1124);
  mpu.setXGyroOffset(-261);
  mpu.setYGyroOffset(26);
  mpu.setZGyroOffset(32);
  // make sure it worked (returns 0 if so)
  if (devStatus == 0)
      // Calibration Time: generate offsets and calibrate our MPU6050
      //mpu.CalibrateAccel(6);
      //mpu.CalibrateGyro(6);
      // turn on the DMP, now that it's ready
      mpu.setDMPEnabled(true);
      mpuIntStatus = mpu.getIntStatus();
      dmpReady = true;
      // get expected DMP packet size for later comparison
      packetSize = mpu.dmpGetFIFOPacketSize();
      // ERROR!
  //This is to set up motors
  setupMotors();
  //This is to set up MPU6050 sensor
  setupMPU();
  //This is to set up PID
  setupPID();
  // if programming failed, don't try to do anything
  if (!dmpReady) return;
  // read a packet from FIFO. Get the Latest packet
  if (mpu.dmpProcessFIFOPacket(fifoBuffer))
    mpu.dmpGetQuaternion(&q, fifoBuffer);
    mpu.dmpGetGravity(&gravity, &q);
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
    mpu.dmpGetGyro(&gy, fifoBuffer);
    yawGyroRate = gy.z;                   //rotation rate in degrees per second
    pitchGyroAngle = ypr[1] * 180/M_PI;   //angle in degree
    pitchPID.Compute(true);
    yawPID.Compute(true);
    rotateMotor(pitchPIDOutput+yawPIDOutput, pitchPIDOutput-yawPIDOutput);
    #ifdef PRINT_DEBUG_BUILD
      Serial.println("The gyro  before ");
      Serial.println(pitchGyroAngle);
      Serial.println("The setpoints ");
      Serial.println(setpointPitchAngle);
      Serial.println("The pid output ");
      Serial.println(pitchPIDOutput);
    #endif
void rotateMotor(int speed1, int speed2)
  if (speed1 < 0)
    digitalWrite(motor1Pin1,LOW);
    digitalWrite(motor1Pin2,HIGH);
  else if (speed1 >= 0)
    digitalWrite(motor1Pin1,HIGH);
    digitalWrite(motor1Pin2,LOW);
  if (speed2 < 0)
    digitalWrite(motor2Pin1,LOW);
    digitalWrite(motor2Pin2,HIGH);
  else if (speed2 >= 0)
    digitalWrite(motor2Pin1,HIGH);
    digitalWrite(motor2Pin2,LOW);
  speed1 = abs(speed1) + MIN_ABSOLUTE_SPEED;
  speed2 = abs(speed2) + MIN_ABSOLUTE_SPEED;
  speed1 = constrain(speed1, MIN_ABSOLUTE_SPEED, 255);
  speed2 = constrain(speed2, MIN_ABSOLUTE_SPEED, 255);
  analogWrite(enableMotor1,speed1);
  analogWrite(enableMotor2,speed2);
The Error mensage is :
C:\Users\AUGUSTA ~\Documents\Arduino\Fotoresistor com serial monito e map\Fotoresistor com serial monito e map.ino: In function 'void loop()':
C:\Users\AUGUSTA ~\Documents\Arduino\Fotoresistor com serial monito e map\Fotoresistor com serial monito e map.ino:176:26: error: no matching function for call to 'PID::Compute(bool)'
In file included from C:\Users\AUGUSTA ~\Documents\Arduino\Fotoresistor com serial monito e map\Fotoresistor com serial monito e map.ino:4:0:
C:\Users\AUGUSTA ~\Documents\Arduino\libraries\PID_v1/PID_v1.h:23:10: note: candidate: void PID::Compute()
void Compute(); // * performs the PID calculation. it should be
C:\Users\AUGUSTA ~\Documents\Arduino\libraries\PID_v1/PID_v1.h:23:10: note: candidate expects 0 arguments, 1 provided
C:\Users\AUGUSTA ~\Documents\Arduino\Fotoresistor com serial monito e map\Fotoresistor com serial monito e map.ino:177:24: error: no matching function for call to 'PID::Compute(bool)'
exit status 1
Compilation error: no matching function for call to 'PID::Compute(bool)'
Could somebody help me, this is super important!
The Compute() function of the PID class does not take an argument. From PID_v1.h:
    bool Compute();                       // * performs the PID calculation.  it should be
                                          //   called every time loop() cycles. ON/OFF and
                                          //   calculation frequency can be set using SetMode
                                          //   SetSampleTime respectively
The error message that you included in the post is not contains this error:
Make sure that you compiled exact the same code that produce this message.
You probably downloaded and included the wrong MPU6050 library. There are many.
