Error message on Compile "display does not name type"
I am trying to combine two sketches, one which uses a rotary encoder to select an output frequency on an SI5351 programable oscillator and another which displays that frequency on an OLED display.My code is below. I am getting the following error message on compile:
"display does not name a type." the compiler highlights the below line.
display.begin(SSD1306_SWITCHCAPVCC, 0x3D);
the line intends to initialize the OLED display.
I believe that this message has to do with a variable type, but the two variables which this function takes are defined in the h header file. I think that I am missing something obvious but I cannot seem to find it. can anyone offer any advice? At this point I am just trying to get the display working and will then uncomment the other lines of code and tweak them for the OLED display rather than an LCD.
code:
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
This entire program is taken from Jason Mildrum, NT7S and Przemek Sadowski, SQ9NJE.
There is not enough original code written by me to make it worth mentioning.
http://nt7s.com/
#include <Rotary.h>
#include <si5351.h>
#include <Wire.h>
#include <LiquidCrystal.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define F_MIN 100000000UL // Lower frequency limit
#define F_MAX 5000000000UL
#define ENCODER_A 10 // Encoder pin A
#define ENCODER_B 9.
// Encoder pin B
#define ENCODER_BTN 12
//#define LCD_RS 5
//#define LCD_E 6
//#define LCD_D4 7
//#define LCD_D5 8
//#define LCD_D6 9
//#define LCD_D7 10
//LiquidCrystal lcd(LCD_RS, LCD_E, LCD_D4, LCD_D5, LCD_D6, LCD_D7); // LCD - pin assignement in
Si5351 si5351;
Rotary r = Rotary(ENCODER_A, ENCODER_B);
volatile uint32_t LSB = 899950000ULL;
volatile uint32_t USB = 900150000ULL;
volatile uint32_t bfo = 900150000ULL; //start in usb
//These USB/LSB frequencies are added to or subtracted from the vfo frequency in the "Loop()"
//In this example my start frequency will be 14.20000 plus 9.001500 or clk0 = 23.2015Mhz
volatile uint32_t vfo = 1420000000ULL / SI5351_FREQ_MULT; //start freq - change to suit
volatile uint32_t radix = 100000; //start step size - change to suit
boolean changed_f = 0;
String tbfo = "";
//------------------------------- Set Optional Features here --------------------------------------
//Remove comment (//) from the option you want to use. Pick only one
//#define IF_Offset //Output is the display plus or minus the bfo frequency
#define Direct_conversion //What you see on display is what you get
//#define FreqX4 //output is four times the display frequency
/* Interrupt service routine for /
encoder frequency change */
ISR(PCINT2_vect) {
unsigned char result = r.process();
if (result == DIR_CW)
set_frequency(1);
else if (result == DIR_CCW)
set_frequency(-1);
/* Change the frequency /
dir = 1 Increment /
dir = -1 Decrement */
void set_frequency(short dir)
if (dir == 1)
vfo += radix;
if (dir == -1)
vfo -= radix;
// if(vfo > F_MAX)
// vfo = F_MAX;
// if(vfo < F_MIN)
// vfo = F_MIN;
changed_f = 1;
/* Read the button with debouncing */
boolean get_button()
if (!digitalRead(ENCODER_BTN))
delay(20);
while (!digitalRead(ENCODER_BTN));
return 1;
return 0;
/* Displays the frequency */
void display_frequency()
uint16_t f,g;
f = vfo / 1000000; //variable is now vfo instead of 'frequency'
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print(f);
display.display();
/* Displays the frequency change step */
//void display_radix()
// lcd.setCursor(9, 1);
// switch (radix)
// case 1:
// lcd.print(" 1");
// break;
//case 10:
// lcd.print(" 10");
// break;
// case 100:
// lcd.print(" 100");
// break;
//case 1000:
// lcd.print(" 1k");
// break;
// case 10000:
// lcd.print(" 10k");
// break;
// case 100000:
//lcd.setCursor(10, 1);
// lcd.print(" 100k");
// break;
//case 1000000:
//lcd.setCursor(9, 1);
//lcd.print("1000k"); //1MHz increments
//break;
// lcd.print("Hz");
Serial.begin(19200);
// lcd.begin(16, 2); // Initialize and clear the LCD
// lcd.clear();
Wire.begin();
si5351.set_correction(140); //**mine. There is a calibration sketch in File/Examples/si5351Arduino-Jason
//where you can determine the correction by using the serial monitor.
//initialize the Si5351
si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0); //If you're using a 27Mhz crystal, put in 27000000 instead of 0
// 0 is the default crystal frequency of 25Mhz.
si5351.set_pll(SI5351_PLL_FIXED, SI5351_PLLA);
// Set CLK0 to output the starting "vfo" frequency as set above by vfo = ?
#ifdef IF_Offset
si5351.set_freq((vfo * SI5351_FREQ_MULT) + bfo, SI5351_PLL_FIXED, SI5351_CLK0);
volatile uint32_t vfoT = (vfo * SI5351_FREQ_MULT) + bfo;
tbfo = "USB";
// Set CLK2 to output bfo frequency
si5351.set_freq( bfo, 0, SI5351_CLK2);
//si5351.drive_strength(SI5351_CLK0,SI5351_DRIVE_2MA); //you can set this to 2MA, 4MA, 6MA or 8MA
//si5351.drive_strength(SI5351_CLK1,SI5351_DRIVE_2MA); //be careful though - measure into 50ohms
//si5351.drive_strength(SI5351_CLK2,SI5351_DRIVE_2MA); //
#endif
#ifdef Direct_conversion
si5351.set_freq((vfo * SI5351_FREQ_MULT), SI5351_PLL_FIXED, SI5351_CLK0);
#endif
#ifdef FreqX4
si5351.set_freq((vfo * SI5351_FREQ_MULT) * 4, SI5351_PLL_FIXED, SI5351_CLK0);
#endif
pinMode(ENCODER_BTN, INPUT_PULLUP);
PCICR |= (1 << PCIE2); // Enable pin change interrupt for the encoder
PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
sei();
display_frequency(); // Update the display
//display_radix();
// Update the display if the frequency has been changed
if (changed_f)
#ifdef IF_Offset
//you can also subtract the bfo to suit your needs
//si5351.set_freq((vfo * SI5351_FREQ_MULT) - bfo , SI5351_PLL_FIXED, SI5351_CLK0);
if (vfo >= 10000000ULL & tbfo != "USB")
bfo = USB;
tbfo = "USB";
Serial.println("We've switched from LSB to USB");
else if (vfo < 10000000ULL & tbfo != "LSB")
bfo = LSB;
tbfo = "LSB";
Serial.println("We've switched from USB to LSB");
#endif
tbfo = "";
#endif
#ifdef FreqX4
tbfo = "";
#endif
changed_f = 0;
// Button press changes the frequency change step for 1 Hz steps
// if (get_button())
// switch (radix)
// case 1:
// radix = 10;
// break;
// case 10:
// radix = 100;
// break;
// case 100:
// radix = 1000;
// break;
// case 1000:
// radix = 10000;
// break;
// case 10000:
// radix = 100000;
// break;
// case 100000:
// radix = 1;
// break;
// display_radix();
Welcome to the Forum. Please read Nick Gammon's two posts at the top of this Forum about guidelines for posting here, especially the use of code tags when posting source code. It will help us help you.
It would seem that you're missing the Adafruit_SSD1306 library.
Thanks, I suspected that it might be a library issue. I have deleted the prior version of the library in the library folder and re-downloaded itfrom the GitHub site link on Adafruit. . Renamed it. Closed out of the Ide and then reopened the sketch. I included the library from the IDE menu and I am still getting the same error message.I have confirmed that the library contains both the header file and cpp file. One of the sketches that I am modifying is an example sketch and that sketch compiles just fine. I am sure that it is a library problem. This time I attached the code file to this message. Can you provide further guidance?
Thanks,
Second_Trial_MultiFeaturedVFO_oled.ino (7.2 KB)
What did you rename the Adafruit library? Usually, the library directory name is the same as the header (*.h) and the C++ (*cpp) file names. I cannot compile your file because I don't use those libraries. However, I am getting multiple LiquidCrystal library calls.
Move display.begin(...) into setup().
The library is called: #include <Adafruit_SSD1306.h>.
Moving the display.begin function into set up cleared the error message. Amazing, many thanks.
