Error message???
I can't even get past first base with this, what's this error and why?
I done everything right and included the sensor info into the library, but it's not happening when I verify it.
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"[/i]
In file included from C:\Users\gary\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:22:0:
C:\Users\gary\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
fatal error: Adafruit_Sensor.h: No such file or directorySo, where did you put it?
The compiler doesn't agree with your opinion.
Looks like the library is not installed or is installed incorrectly
Thanks for looking at my error guys, I used the ADD .Zip Library, anyway I will have to look at it a little closer. So frustrating for a NOOby. Cheers...Gary
If you go into Sketch/Include Library can you see it ?
If not then it is not properly installed
Yes I can see it....
DHT sensor library
It strange how it does not work.
Thanks
DHT sensor library
What about Adafruit_Sensor.h ?
Instead of putting the include <Adafruit_Sensor.h> put #include "DHT.h" or #include <DHT.h>
That should work fine
Of course, it would help if the OP had read this before posting a programming question and followed the advice contained in it
